Old 05-22-2015, 09:53 AM   #1
propav8r
F*ck Edgar
propav8r's Avatar
Default Improve your 240's Wipers
Maybe everyone else has already figured this out, but I still thought I'd share.
My 90 245s wipers were ridiculously slow. Borderline dangerous in anything but a light shower. When I bought the car, there were boxes of spare parts that came with it, including a better looking OE Volvo wiper motor. After being unable to see the road last night on the way home, I pulled into the shop and removed the old wiper motor.
When I put the new one in, I was disappointed to see that the wipers were only marginally better...still painfully slow.
Then I noticed that this new motor had a spot for a ground lug. I didn't realize before now that the motor grounded through the body.
I hooked up an extra ground wire and voila! Speedy, smooth wipers! I've owned 6 240s and never had windsheild wipers work this well.
Originally Posted by Manbeard
My year of VW ownership has been 100% problem free, therefore all VW products are 100% problem free.
Originally Posted by Quin
i improved my life by just getting rid of my 940
nipple farts
My Project
K-Jet to Megasquirt Article
Old 05-22-2015, 10:48 AM   #2
towerymt
the real Towery
towerymt's Avatar
I've definitely replaced a lazy motor once. Wonder if this would have helped it. They've always been pretty slow on my 240s.
Old 05-22-2015, 11:01 AM   #3
M.H. Yount
M.H. Yount's Avatar
Headed to garage to have a look-see....
Old 05-22-2015, 11:36 AM   #4
Harry Tuttle
This looks like a good idea.
I'm curious, how was the motor grounded before you added the ground wire? All the 240 wiper motors I have seen were grounded by a brass tab under one of the mounting lugs. Those tabs can fail, and when they do, the motor generally stops dead, because it is isolated by the rubber mounting grommets.
I have never seen a ground lug like that on one of these motors, including the ones I just looked at (this is likely because my cars are extra old). It is easy enough, though, to put a ground wire on one of the screws holding the cover plate on.
Originally Posted by sbabbs
just gutless low compression k-junk
Old 05-22-2015, 11:38 AM   #5
propav8r
F*ck Edgar
propav8r's Avatar
Yeah, my wipers actually stopped once before. The tab looked OK, but there was a lot of crap built up. I tried to clean it up, but it had little to no effect. Adding the separate ground strap made all the difference.
Old 05-22-2015, 11:49 AM   #6
Harry Tuttle
Originally Posted by propav8r View Post
The tab looked OK
I can dig it. I had my wipers stop once because the little peened lugs holding the ground tab to the motor body had become loose.
This make-your-own-ground could eliminate many problems.
Old 05-22-2015, 12:38 PM   #7
eparayno
eparayno's Avatar
Don't the newer 240's have a ground strap on the motor? My 92 did and my 77 does not so I will be adding a ground as well.
eparayno is offline   Reply With Quote
Old 05-22-2015, 12:43 PM   #8
Kjets On a Plane
Kjets On a Plane's Avatar
Later motors have the ground strap.
I just use early SWF motors and clean the ground tab and add a strap...
More importantly, if the seals have failed and wiper post grease has washed out and they are binding, no amount of messing with the motor will cure that...
How PSI a stock can support?
Always Be Crushing!
Old 05-22-2015, 12:43 PM   #9
Sharingan 19
Sharingan 19's Avatar
There are a couple different wiper motors. An early style that grounds through the mounting tabs (up until around 88'-89' iirc) and the later style with the separate ground lug.
http://forums.turbobricks.com/showthread.php?t=293022
I pulled one off a 93' in the yard and replaced my older style motor which was quite slow. Looking back, I wonder if it was actually the motor, or if cleaning the grounds would have yielded a similar improvement.
Sharingan 19 is offline   Reply With Quote
Old 05-22-2015, 02:51 PM   #10
1choice
That's awesome. Mine aren't fast either, this is a really good idea!
I think that same night when it was downpouring over here, I almost considered getting some rainX, and I really hate that stuff...
(ppl spray it on their windshields while driving, and it gets all over everyone else's)
Funny thing, I installed a front view camera in the grill a week ago, and I could actually see like 80% better through the little 5"x4" screen. (Now I think maybe I should get a bigger screen and mount it over the plastic radio hatch grill thing.)
1choice is offline   Reply With Quote
Old 05-22-2015, 05:44 PM   #11
ellist
Where did you run the ground wire to?
ellist is offline   Reply With Quote
Old 05-22-2015, 06:57 PM   #12
propav8r
F*ck Edgar
propav8r's Avatar
There was a threaded hole close to the passenger side hood hinge. It's where the ignition coil was mounted on some early cars. I used that.
Old 05-23-2015, 11:53 AM   #13
Mr. V
Mr. V's Avatar
I've disassembled, cleaned, lubed, and reassembled these wiper motors to good effect.
Not too difficult.
As for a ground, I fabricated one with thick gauge wire and round grommets on each end.
Not slow at all.
Old 05-23-2015, 02:35 PM   #14
volvowagoon
volvowagoon's Avatar
My '89 had a ground strap on it when I bought the car. When I replaced the motor, it came with a new ground wire, but I reused the old strap. It's a pretty critical thing to implement if you ask me. My wipers didn't really work without it.
1986 Buick Grand National - The show car
2002 Camaro V6 T5 +T - The fun car
2010 C30 T5 - My daily
IG: @v6buick
Old 07-02-2015, 12:33 PM   #15
oldschoolvolvo
oldschoolvolvo's Avatar
on the early wiper motors, is only one of the 3 mounting bolts assigned to ground? if so, which one?
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 07-02-2015, 01:01 PM   #16
cleanflametrap
cleanflametrap's Avatar
It is the top one.
-Art
