Old 06-02-2015, 04:16 AM   #1
Alex Buchka
8 cylinders
Alex Buchka's Avatar
Default The Buchka 242 Daily Driver
I bought this '83 DL about a while back ago from Chris (duder) here on the forums. I had recently moved to LA for work and needed something to drive around. It was all stock when I got it and had about 290k on the clock. Chris rescued it from the crusher, got it basically road worthy and past california smog testing. I took care of some other basic maintenance items and installed a short throw shifter along with a MOMO R-Sport steering wheel just for the hell of it.
After commuting with it for a while I really started to dislike how crappy the car was to drive. All the bushings were blown out, the struts and shocks were used up, the tie rods and rack boots were annihilated, and the brakes squealed like a garbage truck.
Suspension was first up. Basic mod list:
Front:
Koni 8610-1437RACE short strut inserts
500lb/in springs
Kaplhenke roll center correction spacers
25mm iPD bar
Coilover bits from Coleman Racing
Delrin control arm bushings
Chromoly strut tubes
Upper spring perches with 740 thrust bearings
Group-A style camber plates
Rear:
Bilstein F4-B46-0930-H5 dampers
250lb/in 5" ID springs (~375lb/in wheel rate)
Adjustable perches from Coleman Racing
Panhard bar and torque rods with spherical bearings
3/4" shortened lower trailing arms
Stock 19mm bar
Also replaced all the tie rods and the rack boots while I was in there, plus installed some cheapo parts store pads and insulating goop to fix the squealing brakes.
After this it was time for wheels and tires. I covered this in detail in my "Best damn garage in town" thread. Click Here. Basically made a set of 17x8 two piece Gemini wheels using BMW Style 5 barrels and a 10lb box of TIG filler rod. Never again. Karl and Homer helped out a bunch so props to them.
Tires are 235/40-17 Falken Azenis RT615K
Sometime between then and now I put a flathood on it with 7" round Hella H4's
In the beginning of January 2015 I went to Sweden for couple of months to study a few classes in college. Without my knowledge or consent my sneaky brother decided to completely replace the dull beige interior and restore the paint as a surprise.
Interior bits:
Black carpet and rear seat
Manual C30 seats in black T-Tec
Sound deadening mat inside the entire car
Repaired and flocked 1992 black dashboard
All the interior plastic was either replaced with black parts or painted to match
Suede headliner and hat shelf
Replaced the heater box with a 1992 model
New late model windshield
Keyless entry using all 850 hardware
Blaupunkt tape deck with bluetooth line in
MB Quart speakers
Paint:
The paint on the car is all original single stage 139 white. It was seriously neglected by most of the previous owners and myself. I washed it a few times but it never really got clean, there were always specs of crud stuck in the paint that no amount of washing would get off. I've never been one to have nice cars or take care of paint so I didn't really care.
Karl and Chris went to town fixing and painting a few rust spots which turned out awesome. They then got a bunch of friends together for a paint restoration party. I heard it involved absurd amounts of clay bar, DA cutting, buffing, and waxing. The results were staggering, the paint actually shines now.
Karl did a kick-ass job and the car is now an absolute pleasure to drive around in.
Alden took this picture at the Davis meet:
That more or less brings this to the present. I have a few more pictures of stuff to show for the next evolution of the car, I'll add that in the next post.
Old 06-02-2015, 04:43 AM   #2
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
ha.. and again the buchkas got some **** done nice looking car !
Old 06-02-2015, 05:10 AM   #3
crogthomas
crogthomas's Avatar
I like this. A lot.
You have strange friends. Mine would have filled the interior with balloons and silly string.
Is it my imagination or is that Panhard rod straight? How does it clear the differential housing?
crogthomas is offline   Reply With Quote
Old 06-02-2015, 06:37 AM   #4
Råda
Volvoretard/Partshoarder
Råda's Avatar
Thats a damn nice ride
Jonas
Old 06-02-2015, 07:53 AM   #5
The Full Banana
not yet good enough
The Full Banana's Avatar
Wow, that looks excellent. Spot on interior, too.
-Tom 1980 242 T5
Old 06-02-2015, 10:26 AM   #6
Homer
OEMplus++
Homer's Avatar
Hmm. I dunno.
That should work.
-Jacob:
2017 allroad - Comfy DD
Old 06-02-2015, 10:56 AM   #7
Pete.M
Slow Member
Pete.M's Avatar
That must be a joy to drive. You've got me wondering how/where to source those widened spherical bearings. They look ideal.
Pete.M is offline   Reply With Quote
Old 06-02-2015, 12:39 PM   #8
Neat. Any plans to make this smog excempt?
Old 06-02-2015, 12:40 PM   #9
SquareD
An Anomaly
SquareD's Avatar
Those 2 piece Gems are so dang baller. I want some.
1994 945ti | 15g @ 15psi, Turbosmart EBC, AEM Failsafe WB, 3"/2.5" exhaust, do88 intercooler, iPd cam, STS cam gear, Ostrich LH tune, sbabbs EZK chip, green giants, K&N, Yoshifab CCV/Can/Cap, iPd SS brake lines, TME, Eibach, BNE, Koni suspension, iPd sways, iPd panhard, TME upper/CT lower braces, forged BBS RG-Rs, Michelin Pilot SS, ecodes, V90 bits.
Old 06-02-2015, 12:44 PM   #10
towerymt
the real Towery
towerymt's Avatar
Same here. My '92 is looking really neglected now, and I have to do something. Going to be spending some quality time with the clay bar soon, it really does wonders to that embedded crud.
Davis 2015
Old 06-02-2015, 12:45 PM   #11
towerymt
the real Towery
towerymt's Avatar
Oh yeah, make some center caps please.
Old 06-02-2015, 01:33 PM   #12
oldschoolvolvo
oldschoolvolvo's Avatar
rock on! great work as usual!
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 06-02-2015, 02:29 PM   #13
Tuff240
240 Ninja
Tuff240's Avatar
Curious to see how the Delrin bushings do.
-Patrick
Old 06-02-2015, 02:33 PM   #14
adomz
Volvo 486 owner :D
adomz's Avatar
That is great!! And i didn't believe what a clay bar and a few hours can do to the car untill we did my 244... Keep up the good work! ;)
ADam
Errr.... 242... No engine no cringdingding...
=->Adam's youtube channel<-=
adomz is offline   Reply With Quote
Old 06-02-2015, 02:36 PM   #15
Acurry6
Acurry6's Avatar
Looks fantastic! Love the wheels
My build thread: Orange 1976 242 http://forums.turbobricks.com/showthread.php?t=297360
Acurry6 is offline   Reply With Quote
Old 06-02-2015, 06:37 PM   #16
Duder
Comes with a free Frogurt
Duder's Avatar
Just posting here because I feel it's appropriate to assert myself on the front page of what will become an epic thread. Millions of years from now, our children's children will regale their children with tales of Ernesto, the slammed 242 on 3-pc Geminis.
For anyone who wants more back story on the car, see the Daily Turismo Project Car posts here: http://www.dailyturismo.com/search/label/DTPC
Fun facts: it was a San Diego car from new, I was the 3rd owner, the 2nd owner was a graphic designer guy in the film industry and the car was featured in some tiny-budget Indie flick that probably never got released called "51 West." It was entered in the ipd $25k build-off and was the 1st or 2nd runner up.
Old 06-02-2015, 07:16 PM   #17
fortbrick
fortbrick's Avatar
I've been craving more of this car since the custom gemini build thread. Needless to say, the work done to the car so far looks great and I'm sure only more is to come.
Old 06-02-2015, 07:20 PM   #18
Stiggy Pop
Stiggy Pop's Avatar
White always cleans up so well. Looks great, and nice pictures.
'79 242
943 pickup
Old 06-02-2015, 07:43 PM   #19
petiww
petiww's Avatar
Nice job! Love the wheels.
Jelly about those rustfree original paint cars.
I want to ask also, how are those delring bushings do in the front control arms? Doesn't it make the ride much much harsher?
1980 Brown 244 GL
Old 06-02-2015, 10:18 PM   #20
turbotankshane
I'm not a wheel guy, but those are pretty ****ing incredible. Like the rest of your car. Good work.
Old 06-02-2015, 10:39 PM   #21
Old Iron
I Roll
Old Iron's Avatar
Looking good! Widen my Propus C's like that and give me some lip!
Turbobricked
Originally Posted by Anonymous View Post
No sarcastic replies from Redwood Chair necessary
Old 06-02-2015, 11:28 PM   #22
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
Adjustable torque rods and trailing rods (arms?). If so would you make your favorite Sacramento friend a set too?
Old 06-03-2015, 02:09 AM   #23
12david34
2 piece Gemini wheels? so much awesomeness! also very nice car.
12david34 is offline   Reply With Quote
Old 06-03-2015, 02:35 AM   #24
Alex Buchka
8 cylinders
Thanks for the kind words dudes, really means a lot!
Originally Posted by crogthomas View Post
I like this. A lot.
The panhard rod is completely straight. I massaged the diff cover with a hammer to get some clearance. It was very close but just worked. Once I shortened the lower trailing arms it got a lot better.
I turned spacers/adapters to fit 5/8" rod ends into the stock mounting locations. The spacer ID was reamed to 12mm for a tight fit with the standard M12 fasteners.
It is already registered out of state where smog is not a concern.
I have center caps, just been too lazy to refinish them. I would also need new lug nuts, the shiny chrome ones I got from Homer don't work with the center caps
I have put over 10k miles on the car so far and the bushings are holding up great. I greased them on assembly and they haven't started squeaking. The bushings have grease zerks on them in case I ever need to lube them up.
I don't have any stuff to make more. All the bits are available on www.midwestcontrol.com for very short money. They even make threaded aluminum hex rod in different lengths, you could put together a set that doesn't require any welding at all.
The next evolution for the car is a six cylinder whiteblock swap. I got the engine out of Chris Wiita's 960 wagon. It was rebuilt no more than 5k miles ago and is an ideal specimen. Chris also never hooked up the EGR or smog pump so the engine is really clean inside.
The transmission is a five speed Toyota W58 out of an MK3 turbo supra, clutch is a twin-disc Quartermaster Rally-V mounted to a steel flywheel I got from AndyEG several years ago. Coincidentally the automatic transmission in a 960 has the same bolt pattern as the trans used in 1UZ-FE powered lexus cars. This meant I could take a commonly available lexus v8 to W58 adapter plate and bolt the manual transmission to the volvo bellhousing. Some minor clearancing on the bellhousing was required.
For clutch release I'm using a 260 master cylinder and a concentric release bearing for some roundy-round application. The pilot bearing was made with a mish mash of a ball bearing and an oilite flanged bushing from McMaster.
I got most of the driveline parts came from my good friend Justin, the hookup on parts was a massive help so huge props to him for that.
Getting the stack-height correct for the hydraulic release bearing was interesting. Karl and I had to mill down the input shaft bearing retainer and make a backplate to take the thrust load. The bearing floats on the input shaft sleeve and the moment is reacted by a shoulder bolt I modified for proper thread engagement. The hydraulic feed and bleed lines are plumbed to some AN4 bulkhead fittings bolted to the bellhousing.
Old 06-03-2015, 02:59 AM   #25
BillyMaysHere
BillyMaysHere's Avatar
Wow
