is DeeWorks.ca
![]() Join Date: Aug 2006
![]() We almost all need to make a circuit to get the stock tach to work. Here's what I did with mine, completely tossed inside a standard automotive relay.
![]() Compact!
94 944T - 16v turbo - 12,14@122 Lm7 5.3, S475, Ms3Pro, 4l80e - 10,36 @ 134 / 6,70 @ 107 www.deeworks.ca Need T5 Adapter? T5 Speedometer Plug? Gm Torque Converter Adapter? Freeze plug retainer? HE351 solenoid plug? Pm me! |
Mere Drab Mob
![]() Nice!
Mine's not as small, but I put an optoisolator on it for some reason. ![]()
I have a Volvo with some half-done, homemade crap in it. http://forums.turbobricks.com/showthread.php?t=244534 |
![]() Join Date: Oct 2004
![]() My solution...
http://forums.turbobricks.com/showthread.php?t=99420
RIP Doug Williams "Mr. Doug" 4/15/2009 Pete Fluitman "fivehundred" 7/14/2013 Mick Starkey "TrickMick" 1/10/14 Mark Baldwin "blue850t5" 7/19/18 Nick Fengler "fengler" 8/6/18 Thomas Fritz "stealthfti" 10/11/18 Bob Davi "bob davi" 10/2021 74 144 B20 http://forums.turbobricks.com/showthread.php?t=224983 90 745Ti http://forums.turbobricks.com/showthread.php?t=334698 If you need Superpro bushings PM me for price and availability! |
#4 |
![]() I used a Mitsubishi tack adapter that comes with my eclipse/talon coil pack, works great!
#5 |
What, me worry?
![]() Join Date: May 2003
![]() Got a schematic of that?
I coulda had a V8! |
#6 |
![]() Nice packaging!
The standard circuit, but not showing the relay package pinout, is: If you're going to build this, using the alternate MPSA42 or ZTX458 transistors, instead of a 2N5551, will be slightly more reliable. If you're picking up noise on your radio from this, add a 1K resistor across the relay coil - http://forums.turbobricks.com/showthread.php?t=303082 |
#7 | |
is DeeWorks.ca
![]() Quote:
#8 |
#9 |
What, me worry?
![]() Ok- so running a jumper from spare pin-say pin three to js10 would provide a signal to enable this circuit?
#10 |
What, me worry?
![]() Never mind- looks like pin 36 is js10
