Old 09-20-2015, 01:08 AM   #1
thebornotaku
( ͡° ͜ʖ ͡°)
thebornotaku's Avatar
Default 1987 244DL M47 "Turd Ferguson"
Just got it. Needs a ton of work. Combination of age and neglect.
Engine runs pretty solidly. The motor mounts are shot and so are the shifter bushings so it doesn't drive very well. Wicked shake in the front end over 55 or so. Power steering doesn't work, one of the windows is broken and it has a bunch of other little "normal 28 year old Volvo" problems.
Eventual idea is possibly lifting it and putting slightly bigger tires on it, but who knows. First step: Stage 0. Which for this car, is a lot...
Stay tuned.
2009 Volkswagen Rabbit 2.5 "Snowbunny"
thebornotaku is offline   Reply With Quote
Old 09-20-2015, 01:21 AM   #2
Xeroni
MPG?
Xeroni's Avatar
Balloon A/T tires on the MSWs and a three inch lift.
1990 765T; sent off
1989 744T; parted out
1985 245; The Battlewagon;+t, B21/AW71L, back at it again with the megasquirt
1999 V70XC; token whiteblock noisemaker
2016 Ford Mustang GT; V8 stickshift cruiser
Xeroni is offline   Reply With Quote
Old 09-20-2015, 01:38 AM   #3
thebornotaku
( ͡° ͜ʖ ͡°)
that's the plan! Jeep springs, MSWs and some cheapo decent size A/Ts.
Just ordered the engine and trans mounts and shifter bushings. I'm also gonna look in to a set of bronze bushings because **** it why not.
Old 09-21-2015, 07:14 PM   #4
thebornotaku
( ͡° ͜ʖ ͡°)
mini ****ty update.
I got a window, door handle and wagon springs from Ken yesterday down in SF. Figured I wanted to be able to actually close my car up so we got the window in today. I didn't know what was wrong with the driver's side door handle... turns out the linkage just came undone. So we popped that back in. And then threw the wagon springs in.
The rear fender arches were pretty much right in line with the tires and after the wagon springs there's a solid ~2in gap. It matches the front in terms of wheel gap. It's not a huge, drastic difference but it's notably higher than it used to be.
****ty pictures but pictures nonetheless:
before:
after:
bonus pic: tylor cleaning the glass out of the window run channel:
So Bret told me yesterday that the window was broken by his ex (who was driving/"financing" the car) because she locked the keys in it while it was running. Tylor was trying to clean out the run channel with a screwdriver when I yanked the channel out of the door and brushed all the glass out. Then I showed him the trick of using soapy water in a spray bottle to lubricate the metal "frame" for the run channel so you could get it back in easily. I turned around to scrape some stickers off of the rear glass and when I turned back he had the new window in and working mint.
Also apparently this car has quite a history of being passed around. According to Bret...
Noah got this car for essentially nothing. He swapped the trans out (It's actually an 86, AW70 car) with the M47 from an '88. Noah did the maintenance on it while his then-wife was driving it. They got divorced and Noah kept the car. Then Bret got it for free from Noah. Bret did some work on it too (front end work, ball joints, new clutch) and made an agreement with his ex. She wasn't keeping up her side of the deal though and the car was being beat pretty badly. She was unable to keep up with the maintenance on it. Also she's living out of a Winnebago and stopped driving the Volvo for the most part.
When we went to Sebastopol to go get it, she was using it as a closet. The back seat and trunk were full of clothes and other knick-knacks.
Turns out too that it does have some sort of running issue. When it was idling cold today it bogged down a bit. It did respond to throttle though.
It has some problems and it's pretty beat on the outside but underneath it's pretty solid. The trans and driveline were all pretty good with the exception of the trailing arm bushings but no surprise there. The guibo seems pretty new. It did run really well when it was warmed up before I drove it home. Once I get the mounts in it (next weekend, hopefully) I'll have a better feel for what's happening and can go through and do a stage 0 on it.
Old 09-21-2015, 07:15 PM   #5
thebornotaku
( ͡° ͜ʖ ͡°)
dubbel
Old 09-21-2015, 07:42 PM   #6
You gonna get some 79 242GT front springs from FCP scrotum?
Old 09-21-2015, 07:53 PM   #7
122power
dude
122power's Avatar
Hope it doesnt need a dizzy, lol.
Old 09-21-2015, 08:09 PM   #8
thebornotaku
( ͡° ͜ʖ ͡°)
maybe, but down the road. it has more pressing issues currently.
har.
this isn't my daily driver, so really if it's out of commission for a while or whatever I'm not worried about it. I would have kept the wagon after buying the VW too if I had the funds but I needed to replenish my savings + was under the impression I couldn't keep an extra car at my parent's house. Now I don't keep the VW there and my mom is okay with me keeping another car so it's whatever.
Old 09-25-2015, 12:06 AM   #9
thebornotaku
( ͡° ͜ʖ ͡°)
poopy parts for a poopy car
this is what $50 gets you on iPd. All three mounts, all four shifter cage bushings and the shifter linkage bushings.
Old 09-25-2015, 01:14 AM   #10
Xeroni
MPG?
Xeroni's Avatar
Those don't look like uro brand. Did you get something that wasn't bottom of the barrel!?
Old 09-25-2015, 01:15 AM   #11
thebornotaku
( ͡° ͜ʖ ͡°)
$8/ea, MTC
Old 09-25-2015, 02:02 AM   #12
rough. But was a funny read! I am not gonna lie.
hahaha. **** ken, your jokes are pretty solid right now. I hope I get to see you again soon and hear the noob trash talking in person!
Let me guess...OP has some scrotey engine mounts coming that will fail in under 6 months! hahahaha
Old 09-25-2015, 02:14 AM   #13
thebornotaku
( ͡° ͜ʖ ͡°)
honestly it was awkward as **** turning up to pick up the car because I'm sitting in the VW, just off work and still wearing my nice watch and playing on my phone to be greeted by Bret's ex kind of doing a hem-haw oh woe is me kind of thing and "oh the car was so nice to have" and all that...
but I also knew his ex back when they were dating and everything and frankly I don't feel bad about anything, but the situation at the moment was awkward as hell.
he actually wasn't kidding, we were talking about it while I was in the city and told him I was looking at getting a little more stiff and a little more tall out of this car and he made a few suggestions. If you wanna talk about suspension meant for doing work, or big tall tires, then ken is the man. We also talked about rear gearing and about how I could probably expect to see pretty decent mileage even with the tall tires because of the M47 and auto rear-end.
Oh and it turns out the car is actually a 1986 AW70 delivered car, but during the time Noah owned it he swapped in the M47 out of what Bret believes was an 88. So I'm just gonna say eff it, and call the car an '87 M47 car because that's essentially the configuration it's in right now. The swap is all stock stuff and for all intents and purposes it's probably identical to an 87 M47 car, with the exception of the rear gear ratio which is not anything I have to worry about for now.
Also I have bronze shift bushings on order, another "eff it" moment already and figured I'd drop a little coin to get the nice stuff right off the bat for that.
Talked to David and I'm probably getting my old MSWs back from him some time tomorrow as well as possibly more parts out of his garage? So if nothing else this car will look a lot less turd hopefully.
Exterior plan is pretty much rip off all the cladding, probably remove the air dam too. On the turbobricks facebook page somebody suggested spraying the area where the lower cladding used to be with bedliner. I like that idea. I'm probably gonna clean up the paint as best as I can (read: as best as I can be bothered to) and get it looking halfway decent since it's honestly not that far aside from a few derelict things. But any exterior enhancements are purely low-dollar.
Interior I'd like to get new seats all around since the fronts are toast and the rear ass-cushion is pretty dirty and saggy. I don't care about color or anything and it's entirely likely that I'm gonna find some mexican blankets or something to put over the seats anyway just because. Have a little fun with it.
Old 09-25-2015, 02:25 AM   #14
thebornotaku
( ͡° ͜ʖ ͡°)
And just for clarification before I keep this thread rolling:
This is not my daily driver. This is not even a planned "weekend car" or anything like that. This is literally a toy for me to play around with. I already have a way nicer DD and another project car, but I was looking at a Volvo (an entirely different one) and then this one came up.
It has a hilariously turbobricks history to it, it was dirt cheap and it'll be a good way to kill what little free time and money I have left.
I'm already pretty stupid as I work and go to school full time. I'm in a committed relationship (which the Volvo has already strained a little, lol) and working on my photography. Then to top it all off, I don't make very much money and I spend about 75% of what I already do make on rent, car payment and insurance and everything. So I have very little money left over. Seriously, I'm one of the stupidest people I know.
But still, it's gonna be fun having a Volvo again, really having a reason to interact with this community more and spend time with all the great people here, as well as having a cheap project car.
Old 09-25-2015, 11:18 AM   #15
Lord_Athlon
Just damn
I'm already pretty stupid as I work and go to school full time. I'm in a committed relationship (which the Volvo has already strained a little, lol) and working on my photography. Then to top it all off, I don't make very much money and I spend about 75% of what I already do make on rent, car payment and insurance and everything. So I have very little money left over. Seriously, I'm one of the stupidest people I know..
What is this?
84 242 turbo msII
My build https://forums.tbforums.com/showthread.php?t=8675309
Old 09-25-2015, 11:27 AM   #16
I think that is the way most people feel when they work for somebody else.
I have heard the sob stories so many times when people have to pay to fix their car. I usually don't even give a crap to be honest. I don't feel bad when people neglect their car and then cry about when it breaks and how they have to pay to fix it. I feel bad if it's an accident or they got stuck with a lemon, but when people complain about having to fix their blown out suspension or neglected engine maintenance on a 150k mile car DGAF. Suck it up and fix it.
Old 09-25-2015, 01:30 PM   #17
thebornotaku
( ͡° ͜ʖ ͡°)
Originally Posted by Lord_Athlon View Post
What is this?
external monologue
Well it doesn't help that I really don't make that much money and I live in a pretty expensive area. My apartment's rent is more than a lot of people's mortgages.
that was pretty much just a whole "what am I even getting in to" kinda thing but eff it, I like having something I know I can wrench on without worrying if I can get to work the next day.
Old 09-25-2015, 05:01 PM   #18
VulvaDipper
VulvaDipper's Avatar
Sub'd. Lol..
'85 245
I Bet You Hate It
Instagram: @VulvaDipper
Originally Posted by travisminchew View Post
So far they work awesome, I've been driving them hard, even hit a dead deer on accident and nothin broke
Build Thread
Feedback Thread
VulvaDipper is offline   Reply With Quote
Old 09-25-2015, 09:53 PM   #19
thebornotaku
( ͡° ͜ʖ ͡°)
So in lieu of the poopy parts I ordered, I ordered some nice parts.
M47 bronze bushings:
which oddly enough cost as much as the rest of those other parts too
Old 09-25-2015, 11:17 PM   #20
VulvaDipper
Tell me how you like them! I wanna get some soon!
Old 09-26-2015, 01:22 AM   #21
thebornotaku
( ͡° ͜ʖ ͡°)
Picked up the MSWs that were on my old wagon.
Also got a box of cheap **** Volvo parts from David. All four shocks, some belts, engine mounts (herp) and some other stuff.
The rear shocks are totally toast on this sedan so even the Monroes will make a nice change from that. I assume the fronts are probably gone too but I'm not gonna bother for a while.
Old 09-26-2015, 10:02 AM   #22
Oh my turdy 1990 245 is a squirrley bastard. Blown out rear bushings. Blown out front bushings. Inner tie rods probably sloppy. Putting a full tank of gas in it makes the back squat and affects handling significantly. Ha, such a bucket, but it's fun.
"External monologue." Hilarious. That justification will always get you in trouble with the GF or wife! Ha.
Old 09-26-2015, 10:19 AM   #23
thebornotaku
( ͡° ͜ʖ ͡°)
this car doesn't enjoy going in to first or second gear, or anything above 55 or so. Only one of the rear shocks is blown but that one is totally dead. No idea on the fronts but I'm sure they're not great. It's a pretty sketchy car.
Yeah she's already had a few kinda iffy moments with me about it. But it's not a huge deal thankfully. I think her not having to see the car every day and being reminded it exists helps that fact
Old 09-26-2015, 10:27 AM   #24
AKA Verbal Vomit.
I overheard this one recently, "I just say it how I see it." Retort, "NEVER tell your significant other that!" ha. It can be a matter of what you DON'T say, vs. what you do say. It's one reason I am self-banned from OT. My fat mouth will just get me the banhammer if I were to hang out there.
Down in Mexico, whomever has the biggest beater has right of way! Oh and it's true. If you have a nice car, watch the hell out! You will get cut off left and right by the American turd buckets that are the the majority of the population on the road.
Old 09-26-2015, 11:26 AM   #25
thebornotaku
( ͡° ͜ʖ ͡°)
oh word. I'm pretty cautious about how I word things with the girlie. Nothing dishonest, just sometimes I make things sound a little more attractive.
edit:
though it's important not to lie or say anything dishonest because it's easy to get in a lot of **** quick that way.
I loved driving a beater. Ever since I got the VW it's been different. The car drives way nicer but I kind of miss the complete not giving a ****, park wherever I want, take no **** from other drivers on the road kind of attitude. With the VW I'm so worried about keeping it nice and straight that I don't even wanna chance it. But with the Volvo, it's already a turd so if it gets some door dings or somebody wants to play "who has the ****tier car", I have zero issues.
I did it when I had the wagon. Zero issues cutting people off or getting right on their ass when they cut me off. Zero issues parking right up against other people who were in multiple spots or too close to the edge. What are you gonna do? Risk your much nicer car? I can go to the junkyard, pull a fender for $40 or whatever and be on with my day. I don't even care if it's the same color. Try me.
Back on topic:
So far the docket for this weekend:
engine and transmission mounts
shifter bushings (rubber cage bushings / bronze linkage bushings)
rear shocks
all 4 wheels
investigate tail light wiring
possibly rip plastic cladding off of vehicle and begin preperations to bedline the lower areas of the vehicle
I was planning on doing this stuff tomorrow but I'm going camping tonight at the KOA in Petaluma and I need an easy/rest day anyways. I've been going strong for about 3-4 weeks straight now through the weekends too. Plus I still have around 200 wedding photos I need to go through and edit and everything.
So hopefully on Monday I can get some time and a buddy or two together to help me bang out the work on this thing (motor mounts in a driveway solo = not fun, motor mounts in a driveway with buddies and beer = not so bad) so we can see how much difference in drivability it makes.
