![]() NO START:
![]() Photo courtesy of cleanflametrap - STEP 1: Check for spark! Safest for you and your car is a timing light, but without one, unplug ignition wire going from the coil to the distributor. Ground it very close to a strut tower stud like in the picture above. Crank the engine. Do you see spark? If you see a consistent spark, go to the next step and do the starting fluid test. If no spark, inspect Crankshaft Sensor/Hall Sensor and do ignition diagnosis. -STEP 2: STARTING FLUID! This will confirm that ignition, timing and mechanicals of the engine are good with one fast and easy test: TO USE STARTING FLUID: Unplug the fuel injectors, pull the spark plugs and clean them of any fuel, crank the engine and air out the cylinders. (This will clear out any flooding of the cylinders from trying to start the engine.) Then reinstall the spark plugs, LEAVE INJECTORS UNPLUGGED, disconnect intake hose at throttle body, open throttle body, give it two long sprays, crank. Start? If so, you have a fuel system issue. YOUTUBE VIDEO ("test fire without any fuel lines even installed in the car yet.) If your car runs on starting fluid, the fuel system is suspect. Check for 12v at the fuel pumps/fuel pump fuse with the engine cranking. Check fuel pressure. A gauge that will bolt onto the fuel filter outlet (12mm banjo) is available from auto parts stores for a refundable deposit. -Nothing wrong with doing a compression test! -Check belt timing. The cam, crank, and aux shaft (on 240) all need to be aligned correctly. -Check ignition timing. Approx 12 degrees BTDC. NO CRANK: 1: Battery above 12v? 2: Still no crank? Backprobe yel/blu wire at starter. Crank. Have 12v? If not, neutral safety switch (if auto) or ignition switch suspect. 3. 12v at signal wire to starter and STILL no crank? Starter, battery, primary/ground wire issues. Last edited by ZVOLV; 01-24-2017 at 12:43 AM.. |
#2 | |
The MP
![]() Quote:
If you rule out all other problems and have poor cold starting and idle, take the injectors to have the pattern checked, or do it the way you describe in a container of some sort. Trust me, I have seen fires and other silliness with ignition disabled. |
![]() Do you think your crank sensor is bad?
Peel back rubber insulation on crank sensor connector at firewall. Backprobe the center wire, red/yellow, pin 2 with one lead, send other lead to battery ground. Multimeter to AC Volts, NOT DC, and crank engine. You should get approximately 0.4V AC cranking. -Backprobe between Red/Yellow center wire and Blue/Yellow (pin 3). Check resistance. Spec should be around 200ohms (further data needed. Can vary), but if you see an open circuit here, sensor is bad. Last edited by ZVOLV; 01-28-2016 at 11:24 AM.. |
#4 | |
![]() Quote:
#5 |
![]() Last edited by ZVOLV; 01-28-2016 at 04:10 AM.. |
#6 |
![]() Wow that is very helpful, I would have never known. That will definitely come in handy for working on my 240. Thanks.
#7 |
#8 |
![]() My car, after passed the shop runs fine but it can't start. It cranks OK ,it has spark, new rotor, new spark plugs, fuel pumps working fine, distributor works, injectors OK, FPR new... Ehat else can be??
#9 | |
board member
![]() Quote:
CPS ? Last edited by Otto Mattik; 09-24-2018 at 04:44 PM.. |
#10 | |
![]() Quote:
Use DVOM, high impedance, on computer side circuits and test light for B+ and switched Good "T" pins for plug back probes also make it easier Also test for good ground(s) to relay, like one for RSR if voltage/trigger is good |
#11 | |
![]() Quote:
Anyway Three parts of equation - FUEL FIRE COMPRESSION and all at right time If injectors are pulsing and you have fuel on rail next thing to check is that the engine has compression if everything else you say is fact Remove oil cap and look in hole to see if cam is turning while engine is cranking or being turned over by hand If not turning it is seized up or your timing belt has broken |
