Got Boost?
![]() Images should be updated soon... for the time being, you can view the story here: https://www.projectmoro.com/1975-242[/B]
More images are here: https://imgur.com/a/ucHSz I bought a supposedly running car from a forum member to replace my totaled 82 244turbo. 1975 242 DL with a B20, k-jet, auto, and only 49,800 original miles supposedly. Here is the car when I got it. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Nothing worked on the car. Mold in the carpets. Rear calipers frozen, Distributor drive gear broke, Fiber gear was missing teeth. Engine was gross. Carbon build up and slugged oil. Gas tank rusted. Injector and feed lines ruined. ![]() ![]() ![]() ![]() ![]() Rust on the headliner. Cleaned up some of it. ![]() The interior was leaking water, hence the rust and mold. Fixed that problem. ![]() Some quick paint in the bay. ![]() ![]() ![]() ![]() Fresh carpet. ![]() ![]() ![]() ![]() ![]() Added Better looking mirrors ![]() ![]() Brand new GT (R-sport) gauge cluster to go in very soon. ![]() Transferred the parts from another car, and my old totaled 244turbo. ![]() ![]() ![]() ![]() ![]() Finishing rust removal and the under coating. ![]() ![]() ![]() New seals: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Yoshifab x member. Modified. ![]() Last edited by TIPSP; 11-04-2017 at 02:57 AM.. |
Got Boost?
![]() Custom Drive shaft
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Finished cleaning the rear end ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Lower mounts for the engine. ![]() ![]() ![]() Was going to mill them, but somethings happened and the machinist was busy. ![]() ![]() ![]() ![]() ![]() ![]() ![]() New exhaust ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Learning to tig on this car. ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by TIPSP; 11-02-2017 at 12:38 AM.. |
Got Boost?
![]() ![]() ![]() ![]() ![]() ![]() ![]() RSI adapters didn't fit right ![]() ![]() ![]() ![]() New Master ![]() ![]() ![]() New Fuel Lines everywhere ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Stereo Modeling ![]() ![]() Fuel filler neck adapter I made ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Stereo Continued.. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by TIPSP; 11-02-2017 at 01:05 AM.. |
#4 |
Got Boost?
![]() Stereo Cont...
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Cleaned up some of the wiring ![]() New Rims: ![]() ![]() ![]() ![]() ![]() ![]() ![]() Added a resonator to keep it more street friendly. ![]() ![]() ![]() ![]() Teaser: ![]() Alignment. Left over 80-20 works great. ![]() First Trip to the station. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() It took way to long to get it running, but it is running now. Some wiring is left, and the supercharger and rear brakes. Then it will be done. 2.5 years of waiting to drive it. It is fun to drive. Last edited by TIPSP; 11-02-2017 at 01:22 AM.. |
#5 |
1 throttle plate per cyl!
![]() Looks amazing. Nice work
DD's 2010 Jeep Patriot 2015 Dodge Journey Currently restoring: '66 122s 2dr - B20 dual webers/M41 Projects: '83 245 - SBC 388 stroker with Jenvey 45 ITB's |
#6 |
![]() What was leaking causing the molding carpet?
#7 |
Got Boost?
![]() Here is when it was first started after 2.3 years.
Without resonator. and first rebuilt fuel distributor I did. We Rebuilt Kjet distributor once, and cleaned out the injectors (thanks Ian). Also opened and cleaned the CPR. I bought a new rebuilt distributor because I had to open the other one back up again. Didn't have a new plate for it. Ran like crap the second time I took it apart. I will have to get more videos later. Last edited by TIPSP; 01-03-2016 at 09:10 PM.. |
#8 |
Got Boost?
#9 |
†John3:16
![]() Join Date: Jan 2009
![]() very well done. Great work on everything.
#10 |
Got Boost?
![]() Thanks,
And thanks to all the people that helped me get it done. Me and my dad did most of the work. somethings like machining and the drive shaft where out sourced. I learned(ing) to tig weld on this car. Ian (hiperfauto) played a major rolled with awesome parts and advice. Ben helped with custom awesome parts, and some other people not on this forum help source parts. oh, and this is my daily drive so it will not see too much boost. The pulley is designed to run the charger at 14,000 rpms (which is like 10 psi), but I can control that with the bypass valve on the charger. probably 5-7psi. should be like 160 crank hp. Last edited by TIPSP; 01-03-2016 at 09:41 PM.. |
#11 |
not yet good enough
![]() Wow, this is a really neat car. Very well done, I can't wait to see more!
#12 |
The Librarian
![]() That looks amazing. I had no idea you put so much work into this car. I'm glad you finally got it all sorted out.
And what's this about a supercharger? You never said anything about it. |
#13 |
Been here for too long
![]() Beautiful work. Beautiful.
80 242- 2.5L 16V, NIW intake/exhaust, T5, Porsche brakes, short billies and Kaplenkhe suspension, Trutrack. Project Thread- http://www.turbobricks.com/forums/sh...d.php?t=324470 |
#14 |
![]() Awesome work, car looks great!
1983 245DL, 2011 WRX, 1978 SR500 |
#15 |
![]() This car is hands down the sexiest 240 I have ever seen. That interior is the sex.
#16 |
ihazkoolaid
![]() A+
Thanks for keeping the b20 in there! |
#17 |
300+ Clurb
![]() Nothing I could possibly say holds a candle to the craftsman ship put forth; This car is stunning beyond all comprehension.
#18 |
![]() Oh. My. Lord.
Truly impressive, I'm gonna post some of these pics in the inspiration thread, you've more than earned it. What made you want to stick with the b20? |
#19 | |
Hnnnnnng
![]() I love that interior. So awesome.
1990 745tic 1984 244DL (parts) 1989 245 slicktop M47 drift missile- ratty as hell 1967 220 amazon station wagon. 1990 244GL M47 summer DD project. Quote:
Poopie scissors
#20 |
![]() Fantastic! So stoked to see someone revive a '75 and keep the b20.
#21 |
junkman
![]() really good job there.
what did you do to the undercarriage .... or I should say... how did you do it ? |
#22 | |||
Got Boost?
![]() Thank you guys. Means a lot. Most of the cars on here are my inspiration.
But it is fun to throw in a teaser image here and there. Quote:
It took a month of trouble shooting to figure out why it would not start. We were tempted to rip it out and stick a V8 to match the transmission in the car now. I like the idea of the original engine in it also... Plus, not many people have a 75 242 with an Eaton supercharged B20 ;) I haven't seen one yet... Quote:
Edit: I used goof off, and acetone to the underside after the clean up so the undercoating had a better stick. Then I did a very light coat of summit racing black spray paint over the undercoating. The axle was a more wire brushing. a lot more rust on that part. Last edited by TIPSP; 01-05-2016 at 02:28 PM.. |
#23 |
dude
![]() Wow nice work and car dude. First 75' 242 Ive seen in that color.
#24 |
![]() Join Date: May 2007
![]() Suddenly one of my favorites. Good going, man.
#25 |
![]() Oh finally!
![]() I liked this car from the beginning, even from the progress pictures of the 244 turbo you could tell this 242 is in good hands. Although I was a bit curious about the titan rimpz on it at first. Fortunately you did not disappoint me! Tasty, classic looking with a perfect ride height and a pushrod engine. ![]() Hats off for you and your father, really nice work! I hope this one won't get messed up by some idiot driver...
1980 Brown 244 GL ![]() |
