runslikeapenguin
- Sep 10, 2008
- Tacoma WA
I've been reading as much as i can on building up a rear end for my car and man, NONE of the threads are clear about anything. I might need some help here for getting everything together. I'm sure someone can chime in with some answers, or some insults.
**UPDATE**
This ended up being a 1030 axle, all signs were wrong. I really wish there were a good way to identify these things.
Car: 1978 262c
Engine: B21+T, should be in the 300 ftlbs territory.
Trans: T5z, .68 5th. 2.95 1st.
Clutch: JVAB flywheel, KEP 228mm organic disk, Stage 3 pressure plate.
Car will be semi-daily driven. Always on street tires and i don't plan on launching it . . . often.
So for starters, the hardest question to answer is this one.
This is a 1031 right?
Sensor on the diff cover, two ribs, no fins on the bottom, larger no hump housing?
So assuming this is a 1031, i want to put 4.10's in it.
Can i just get any Dana 30 R&P?
like this?
http://www.summitracing.com/parts/mgr-d30-410f
Also, if i get a truetrac. Is this the one? There are two kinds right, depending on the R&P ratio right?
http://www.summitracing.com/parts/dtl-912a588
Now for axles . . . this is one i didn't do any searching on.
Is there a need? Are there options for this out there?
Finally the argument territory. This rear end has the 3.7something in it right now (did the spin test) Should i keep it or go 4.10?
**UPDATE**
Car: 1978 262c
like this?
