Old 03-08-2016, 06:22 PM   #1
soclosenotnear
Default 1995 940 turbo *longterm* daily driver
Currently setup as of 8/26/18
Suspension:
Kaplhenke front coil overs w/ konis
Kaplhenke adjustable strut mounts
Kaplhenke quick steer roll correctors
Kaplhenke panhard bar
Poly control arm bushings
Ipd sway bars
960 braces
Lower chassis brace
Cherry turbos upper strut brace
Enkeir rpf1 17x8 and 17x9 +35
Motorsport tech 25mm adapters
215/45r17 front, 225/45r17 rear
Drive train:
Ipd turbo cam
Ipd adjustable gear 2.5 degrees advanced
Td04hl-16t at 20ish psi
Bosch 42 pound green giant injectors
All flexible stainless oil/water lines
3" downpipe
Tme catback
Chipped computers
Buchka wasted spark
Tlao silicone hose set
Silicone vacuum lines
Do88 intercooler piping
Do88 3" inlet hose
Do88 idle valve hoses
Do88 pcv hose
Do88 intercooler
Aem dry flow 3" filter 21-2036dk
3" 012 AMM
BSR heat shield
M47 swap
Spec stage 2 clutch
Short throw shifter
STS machining bronze shifter bushings with delrin inserts
3.31 gears
Old style 740 engine mounts
Interior:
Ipd triple gauge pod with volt, oil press., and boost gauges
Instrument cluster/map lights replaced with led's
Lighted window switches
AEM Uego wideband in 3d printed vent gauge pod
Exterior:
Ecode headlights with hid projectors
960 taillights
Side markers
Tag lights replaced with led's
Snowcap
Rear decor panel
S/v 90 door handle swap
Last edited by soclosenotnear; 08-26-2018 at 08:32 PM.. Reason: new goodies installed
soclosenotnear is online now   Reply With Quote
Old 03-08-2016, 06:23 PM   #2
soclosenotnear
Hello, my name is Joseph. I've had quite a few volvos over the last few years; sold a couple, and ruined a couple if I'm honest. Some things I've learned are that I'm not personally inclined enough to do custom work involving fabricating, solving problems, etc. However, I have much better luck when I stick to bolt ons and direct swaps. It's just something I have to be honest with myself about.
I recently acquired a nice white 1995 940 turbo sedan, with an m47. It's already had a lot done to it between the last two previous owners. Lots of headlight work, front suspension, m47 swap, among other things. The interior is dark colored cloth and the air conditioning works well, both things I was looking for in a car. Most importantly, the car seat fits in the back to carry our new little one around.
My goal for this car and this project thread are just to continue with tasteful mods, that will continue to keep the car reliable and mildly fun. Maintenance *hopefully* remains a priority as I'd love to hold on to this one for a while to come.
The first thing that bothered me was a clicking noise I heard on acceleration. I determined it was the exhaust manifold gaskets. This job scared me as I did not want to snap an exhaust stud. Being very patient and using p'blaster, they all came out easily enough. I didn't want to disturb anything else so was very careful pulling the manifold away. The old gaskets literally crumbled to the touch. Let me tell you just how terrible the bracket holding the manifold to the block is to get to. And twice that difficult to get back on (I only got one of the two bolts back in holding that bracket to the block). But I'm so glad the job is more or less done. No more clicking noise; acceleration is nice and quiet.
http://forums.turbobricks.com/showthread.php?t=319182
I also picked up and installed some 960 braces to reinforce the control arm brackets. This was a nice easy install, even though where the driver side bolts to was slightly bent.
http://forums.turbobricks.com/showthread.php?t=319020
Lastly, I noticed the engine and transmission mounts are in poor shape. I have an m47 mount sitting around but have to order the engine mounts. Is it worthwhile to convert to the older 740 style mounts at this time? I know the price difference on the rubber portion of the mount would nearly pay for the old style brackets if there's any benefit.
Old 03-08-2016, 06:48 PM   #3
fortbrick
fortbrick's Avatar
Happy to see that the car stayed with a board member. Looks like there's a lot of worthwhile modifications that have given you a good head start. I like the solid mounts in my car, personally. I'd buy them again.
Old 03-08-2016, 07:55 PM   #4
okoye
okoye's Avatar
Yeah go with the solid mounds man. Looks good I can't wait to see this car with some nicer wheels.
Also I'd paint the pan so it doesn't rust out. I had to replace a pan because it rusted through because of lack of paint.
Old 03-09-2016, 01:37 PM   #5
soclosenotnear
I was happy to get it. And yes, this car has mostly had everything gone through.
I'm leaning toward buying the old style mounts. I had some on my second volvo, a factory m46 '91 744 turbo. It's been a while, and at the time, I didn't know there was anything different, so I can't really compare the two different styles.
Or, are you talking about new style solid mounts? Like ipd sells?
Short term plans include figuring out new mounts, as much chassis bracing as I can buy, and an ipd turbo cam and gear I've already got.
Long term plans are definitely adjustable rear perches/springs, nice shocks (something shorter?), and wheels. The rear setup, as of now, is just cut springs, and sits much higher than the front.
I have enkei rpf1's and adapters that I could throw on if I could get the energy to peel some old plastidip off.
Old 03-09-2016, 02:17 PM   #6
okoye
okoye's Avatar
I've wondered how these cars would look with those wheels as they usually come up for cheap in decent offsets. ( totally do a mock up)
Old 03-09-2016, 05:27 PM   #7
soclosenotnear
I bought them originally for my civic, but didn't care for them on that car. Here they were on my girlfriend's '90 745, before they were plastidipped pink. I've had them on my 242 also. 17x8 and 17x9 +35 w/ 25mm adapters.
Old 03-09-2016, 06:55 PM   #8
fortbrick
fortbrick's Avatar
Old style mounts, definitely. I forget the years they came on but I got mine from a JY and got some new rubber for them. As for the shocks, if you want to go low you'll be wanting short struts. I'm kicking myself now for running stock height housings.
Old 03-09-2016, 07:20 PM   #9
soclosenotnear
The front is already taken care of, so yeah, i need to find a shorter shock for the rear. I bet adjustable perches and springs, with koni sports would make me happy with height and give me enough travel. That's down the line at the moment right now though.
I need to post a wanted ad for some old mounts if I'm gonna do it. I think the last set I saw was around a bill. Hopefully I can find a a little better deal to justify not just buying new rubber mounts for what I have.
Old 03-12-2016, 04:02 PM   #10
soclosenotnear
So, running some errands with the family yesterday, I noticed my volt meter seeming to drop out every time I came to an idle. My a/c started acting up and the SRS light came on. Eventually it just dropped to a steady ten or so volts. With more driving, ended up around 8-9v. I got everyone home and took her up to o'reilly's. They tested the alternator as having a bad voltage regulator. I had a spare alternator on an engine in the garage so I opted for that one.
Once I got both pulled, I noticed the tensioner bracket had snapped. My other engine was last setup for a 240 so I didn't have another bracket laying around. I decided to test my recently acquired wire feed welder that I picked up from my pawn shop. I won't show you guys what it ended up looking like, but I couldn't bend it with a couple sets of pliers.
Thinking the broken tensioner bracket could have caused all my problems, I put the original back on. No dice and a wasted twenty or so minutes. Put the spare on, and all is well, thank goodness.
After that, I added a couple goodies I swapped for on here. Some rear decor-
And crawled under the car to add some more bracing. Might have it on upside down ?
I bought some old style 740 engine mount brackets. Now I'm waiting on an ipd order for the rubber 164 mounts I got for them. Also, a cherry upper brace is on its way, and I think that covers all the chassis braces I've seen. After that, and an ipd cam eventually, hopefully just lots of driving ensues.
Old 03-12-2016, 09:07 PM   #11
okoye
okoye's Avatar
You've put it on wrong turn it over.
Old 03-13-2016, 12:11 PM   #12
soclosenotnear
I thought so too when looking at it in the picture, but I just double checked. It only goes on one way. I've only ever had the ipd brace before this one.
Old 03-17-2016, 08:21 PM   #13
soclosenotnear
Today, I fought and conquered new engine and transmission mounts. I decided to upgrade to the old (pre-87?) style 740 mount brackets. I went with 164 rubber mounts. Everything came together pretty nicely and boy did the car need new rubber.
For reference with part numbers:
http://forums.turbobricks.com/showthread.php?t=319342
Now, the transmission mount wasn't so cooperative. It was something I had laying around that I had bought from ipd long ago for another m47. Really just poor fit and quality, but got it on there, and it's much better than the cracked and oil soaked old one.
Old 03-17-2016, 08:56 PM   #14
oldschoolvolvo
oldschoolvolvo's Avatar
nice work! clean car as well.
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 04-13-2016, 10:02 PM   #15
soclosenotnear
So, I started getting the faint smell of coolant with the heat on. Loss of coolant followed. And finally, damp carpets told all. I had to do the dreaded heater core. This was my first endeavor with a heater core. I researched and found the copper cores to be best, but couldn't find any, without buying from the stealership. I went with an all aluminum spectra core.
http://forums.turbobricks.com/showthread.php?t=319968
It took me and a friend about eight hours total, split between two days, in a weeks time. It was a pain, for certain. The new core was very difficult to get through far enough to put the hoses on, but it seems like they sealed. I used these directions to get through it. It was very thorough.
https://www.volvoclub.org.uk/faq/Hea...eplacement.htm
Here are some pictures of the carnage/that I took for reference:
We took our time, followed the directions to the t, and labeled everything. It worked out for the most part. Everything went back together except this. I had these left over; the 13 corresponds to the step number in the above directions. They take a star bit. What did I miss?
Old 04-14-2016, 01:21 PM   #16
soclosenotnear
When I bought the car, the expansion tank hose crumbled and burst. I cut it, and shoved the new end on... Since I needed this already, and wanted to do the heater core hoses also, I started looking into silicone hose sets. I found a set of tlao silicone hoses in blue from a group buy that happened a few years back. I picked up new vacuum lines also and went to town.
I replaced my engine coolant temp sensor at the same time, as well as the intake manifold gasket. Hopefully this fixes a sporadic high idle I'd get at times. I'm resetting the ecu right now, as I got a check engine light after finishing the heater core. The diagnostic box said "no fault found", so we'll see if it comes back on in a few hours.
I also put the cherry upper brace on, and an old school oil cap.
Old 04-15-2016, 07:22 PM   #17
soclosenotnear
Engine coolant temp sensor didn't fix my problem. I drove the car probably 4 times with no issues, and on the way home tonight, it did it. I'm not sure where to look to next to fix the issue.
http://forums.turbobricks.com/showthread.php?t=319459
Old 04-17-2016, 12:00 PM   #18
brickyard92
Regular Contributor
brickyard92's Avatar
Have you tried cleaning the idle control valve?
"Sometimes you just have to play the role of a fool to fool the fool who thinks they are fooling you"
brickyard92 is offline   Reply With Quote
Old 04-22-2016, 09:36 AM   #19
soclosenotnear
That's next on my list. I replaced the radio noise suppression relay to no avail.
I need to replace it's connector though...
Old 04-24-2016, 05:33 PM   #20
soclosenotnear
So, you know when you're driving with your old lady and your infant daughter, and then you glance down, and your temp gauge is pegged on the hot side.
So you pull over, pop the hood and realize your coolant is missing. Then you look and you realize your heater control valve broke.
The same one you thought about replacing when you just did the heater core and hoses. So, after getting the girls home, I picked up a new one at the o'reilly's. The coolant cost twice as much as the part that needed replaced. I then proceeded to fix it in A McDonald's parking lot.
It wasn't too bad really, but frustrating when I knew I ought to have just grabbed one a week ago and replaced it at the same time.
Old 04-28-2016, 03:29 PM   #21
soclosenotnear
I cleaned my IAC valve in an attempt to fix my sporadic high idle. I used a 50/50 mix of wd-40 and throttle body cleaner, which I read on here is best. We'll see if there's any change over the next few days.
I also tried to solve my only oil leak which was at or near the oil filter. It's the only place on the entire engine that leaks and I can smell it every time I shut off the car. I decided I thought it was the gasket between the relocator arm and the oil cooler sandwich plate. I read that the green gaskets are the best, which is what I bought. The one I pulled off, however, was black. Any thoughts or preferences on that one tricky gasket? I'll check in a few days if I have any seepage.
EDIT::// seepage is an understatement. That little green gasket did not work for me. I proceeded to pour all of my oil all over my driveway. Went and bought the right gasket from the dealership which I should have done to begin with. And more oil. And more filter. Now I have to clean everything in that area all over again. Time to get dirty.
Old 05-04-2016, 06:23 PM   #22
eurotrash940
Nice looking car - all the same stuff I am fighting, trying to do as well. How and where did you snag those silicone hoses? I have been looking for months...
1993 945T - 253K - money pit, nightmare, one day DD
1994 944T - 272K - about to be out tha' door
TB the new home of the internet special olympics.
eurotrash940 is offline   Reply With Quote
Old 05-05-2016, 12:46 AM   #23
JerryJS8
der Junge
JerryJS8's Avatar
Silicone hoses to make you drool (and empty your bank account)
- 1992 480 (Renault disaster)
- 1989 745 16v
- 1991 744 (SE) 16v Turbo
Old 05-05-2016, 01:04 AM   #24
DarkKratoz
DarkKratoz's Avatar
Regarding your high idle, if it's available to you, try swapping ECUs with one you know is good. I had terrible idling issues (seeking, high idles and terrible running) for nearly a year, and it turned out that the aftermarket replacement ECU (I think the brand was "Reboota" or something) had a couple bad circuits in it. Tossed in an OE ECU and all the issues disappeared. That's my $.02.
1995 Volvo 960 - Absolute turd that I despise
DarkKratoz is offline   Reply With Quote
Old 05-05-2016, 05:01 PM   #25
soclosenotnear
I posted in the tlao silicone hose group buy and a user randomly had a set in blue laying around unused that I snagged as quickly as possible. Blue wasn't my first choice but since I found that set, I bought everything else to match.
I know about them. My pressure hoses needed replacing so I picked up a set of intercooler pipez from them. Just got them on today actually.
I couldn't be happier with the fit and finish from them.
That, along with an aggravating oil leak are my main priorities right now:
http://forums.turbobricks.com/showthread.php?t=321108
I haven't got a spare computer around. Once I finish replacing the last bits of rubber (intake hose and idle hoses), and I can write off vacuum leaks, I'll start focusing elsewhere.
Regarding the high idle, having my air con on keeps the idle around 1300 when it's in that mood. If I cut the AC off, it's back to bouncing to 2k rpms. How bizarre.
Also, now with more window switch lights.
And less cupholder
If anyone needs a grey cupholder armrest, $45 shipped?
