Old 05-06-2016, 04:26 PM   #1
940Orlando
940Orlando's Avatar
Default Simple locker mod G80
Hello, I just did my own version of the locker mod on the g80. Not sure if anyone has done this, but it can be done in probably less than an hour.
All I did was drill and tap the carrier and install a set screw (5/16), ground the set screw until it recesses into the carrier and staked it in. The set screw keeps the weighted arm from springing out and disabling the locking mechanism.
1994 940 Turbo, stock stock stock.. i know.. ewww
Sold: 1992 940 Turbo, ChinaBay T3/T4 .63A/R Turbine .50A/R Comressor, Ported 90+, Ported Head, RSI Stage 1 Turbo Cam, RC 550cc Injectors, 3" Turbo Back Exh, Cherry Bomb Vortex, Ebay 29x11x3 FMIC, Gotech Standalone EMS, Dual Coil Wasted Spark Ignition, Accel 8mm RS Wires, Walbro 255LPH Inline, -6AN SS Braided Fuel Lines
940Orlando is offline   Reply With Quote
Old 05-06-2016, 05:38 PM   #2
centason
Knipex=welfare queen
centason's Avatar
Doesn't look like a lot of meat on the top of that set screw. I'm just worried if that lets go, the kool-aid man is going to take pay a visit with a grenade.
Member: TBCCS
“The demagogue is one who preaches doctrines he knows to be untrue to men he knows to be idiots.” -H.L. Mencken
Old 05-06-2016, 10:00 PM   #3
BoostedBrick563
BoostedBrick563's Avatar
Sure looks like it will last for minutes and then break
1994 940- pretty much stock.
1985 740- (crushed)
BoostedBrick563 is offline   Reply With Quote
Old 05-06-2016, 10:49 PM   #4
sim
Mere Drab Mob
sim's Avatar
That will work just fine, nice idea.
I used a piece of 3/32 welding rod tacked to the housing to hold the weight down. No problem.
I have a Volvo with some half-done, homemade crap in it.
http://forums.turbobricks.com/showthread.php?t=244534
sim is offline   Reply With Quote
Old 05-06-2016, 10:50 PM   #5
NO_SPRK
ihazkoolaid
NO_SPRK's Avatar
Might as well swap a open diff and do a Lincoln locker.
Won't that chirp the wheels when turning?
69' 145 / 73' 142 / 84' 244
Buyer/Seller Feedback
NO_SPRK is offline   Reply With Quote
Old 05-06-2016, 11:52 PM   #6
Canadan
Canadan's Avatar
No it doesnt lock it, it just keeps it in lsd mode where factory operation that paw flies out over 25mph and makes the g80 basically an open diff. This mod and any other with the spur/paw whatever you want to call it makes it behave like a normal locker at all speeds and not just under 25mph
Canadan is offline   Reply With Quote
Old 05-07-2016, 12:02 AM   #7
Kjets On a Plane
Devoid of Luxury
Kjets On a Plane's Avatar
You can just lop the weight off no? Seems easier, IDK. Just stick it in the vice and death wheel the weight off? Same difference no?
The "always locked" more or less "always locked" G80 is a lot easier on the axle splines than the welded and a lot less of a PITA to move around the parking lot.
How PSI a stock can support?
Always Be Crushing!
Old 05-07-2016, 12:04 AM   #8
Canadan
Canadan's Avatar
Yep for sure, different ways to do the same basic thing.
Old 05-07-2016, 12:07 AM   #9
NO_SPRK
ihazkoolaid
NO_SPRK's Avatar
okay i didnt know it has different settings.
but yeah good mod but i would be worred about that thing coming out
Old 05-07-2016, 12:11 AM   #10
Kjets On a Plane
Devoid of Luxury
^Yes, 2 tools (vice/death wheel) and subtraction sounds safer than addition and many tools, chips, (drill and tap) + modified set screw.
Just takes a second to take the hat off of it to lop the weight, though you do have to dig the ring gear off of it I guess, and that's it's own set of tools to get the oil slinger off of there (press the bearing off carefully or snip the oil slinger).
Old 05-07-2016, 12:31 AM   #11
sim
Mere Drab Mob
sim's Avatar
Nope. The beauty of a G80 is it's only welded when necessary.
Yep.
Not easier than welding a tab on to keep the weight down.
Probably easier than drilling and tapping, though I suspect the
OP did not remove the carrier from the housing.
Dismantling and cleaning the parts is always recommended.
And yes, no issues at parking speeds.
I would for sure worry about the debris from drilling/tapping. OP
should change the oil back there shortly.
Old 05-07-2016, 03:41 AM   #12
Hoggster
Hoggster's Avatar
That's what I did, there used to be a writeup with pics that even showed where to cut the weight. I never had any problems with mine and have 50+ hours of track time on it.
Hoggster is offline   Reply With Quote
Old 05-09-2016, 01:49 PM   #13
940Orlando
940Orlando's Avatar
The point was you don't need to take anything apart. Just remove the cover, drill a hole, tap it and put a set screw in it. Adjust the screw height by grinding it until the set screw recesses into the carrier, set it so it just touches the arm, and stake it in. Not going anywhere.
I was able to flush it out and wipe it all down, then reassemble the cover.
