Old 06-10-2016, 11:56 AM   #1
holdenjp
Default Sound dampening recommendations
I'm replacing all the carpet front to back in my 245 wagon and I need suggestions for sound dampening to put in while everything is out of the way.
1987 240 - Sold. Had it for 15 years. Car that turned me into a car guy.
1991 245 - Daily Driver, IPD Turbo cam advanced 2 deg, B230FT with 15G, TLAO Chips, MBC, AW71, Upper and Lower braces, IPD 25mm sways, Lowered on H&R springs and Bilstein HD's, Mille Miglia's 205/55/16
1986 Porsche 944 Turbo
Link to my feedback thread.
holdenjp is offline   Reply With Quote
Old 06-10-2016, 12:11 PM   #2
iHateVolvoPeople
Roofing tape from Home Depot is cheap.
Feedback Thread
Current:
93' 244T m47
93' 245 m47
90' 744 AW70
94' M-Edition Miata, 93k
95' Camry auto, 246k
Past:
80' 242gt m46
88' 245T m47
92' 945T AW71
94' 945T AW71
Old 06-10-2016, 12:19 PM   #3
cwdodson88
Window flashing is cheap too, less smelly since is butyl instead of asphalt, bad thing is its thin, so 2 or 3 layers. Just did a friends nova. 3 rolls at 12$ each and interior sound went from ~100db (open headers, no interior) to ~70 db at idle.
The Build Thread
SVEA - PUSHROD TURBO!
Old 06-10-2016, 12:42 PM   #4
oifish
I'm feeling extra zazzzy
oifish's Avatar
That's what I used. Helps to pick up a little wooden roller for a good seal
1990 Volvo 744T M46 - Daily Driver - ( ͡° ͜ʖ ͡°)
1996 Chevy C1500
__________________________________________
Buy/Sell Feedback
oifish is offline   Reply With Quote
Old 06-13-2016, 01:36 AM   #5
ogamer777
ogamer777's Avatar
cant go wrong with dynamat or a similar product
ogamer777 is offline   Reply With Quote
Old 06-13-2016, 01:51 AM   #6
Tfrasca
Tfrasca's Avatar
If sound damping is what you're after, I can recommend this fairly cheap stuff from Amazon:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 06-13-2016, 02:09 AM   #7
Jack
junkman
Jack's Avatar
I used both
DYNAMAT is FTW by far
starts middle of page 1
http://forums.turbobricks.com/showthread.php?t=262585
starts bottom of page 9
http://forums.turbobricks.com/showth...=262585&page=9
Old 06-13-2016, 02:51 AM   #8
Karl Buchka
Never go full retard.
Karl Buchka's Avatar
I used RAAMmat on my brother's 242 and it worked very well to cut down on interior noise. It's also a lot cheaper than equivalent dynamat. It doesn't give off any smell and is pretty easy to work with.
"Package #2" (http://www.raamaudio.com/package-2-3...ensolite-foam/) was enough to cover the entire floor, firewall, rear seatback, parcel shelf, doors, and parts of the areas under the rear "door cards."
Fake Race Car
Old 06-13-2016, 10:21 AM   #9
driedle
driedle's Avatar
Dynamat is the best, by far.
Karl is correct, though, that RAAMmat is a great deal less expensive, and almost as good.
I have used Dynamat several times on different cars, and it has always worked great!
Dave Riedle
driedle is offline   Reply With Quote
Old 06-13-2016, 05:29 PM   #10
holdenjp
Sound deadening, dampening, heat reduction....
Anyone have any experience with Eastwood XMat? It's pretty inexpensive
Old 06-13-2016, 08:02 PM   #11
Lord_Athlon
Just damn
Dynamat isnt actually that great.
Ive used SecondSkinAudio Damplifier Pro with great results, and it comes highly recommended.
84 242 turbo msII
My build https://forums.tbforums.com/showthread.php?t=8675309
Old 06-14-2016, 01:08 AM   #12
Jack
junkman
Jack's Avatar
um yes it is..
lost of independent testing shows dynamat far superior
Old 06-14-2016, 01:44 AM   #13
Lord_Athlon
Just damn
Show me.
Old 06-14-2016, 02:12 AM   #14
Jack
junkman
Jack's Avatar
no
Old 06-15-2016, 04:28 PM   #15
TempleUWS6
TempleUWS6's Avatar
I'm going to try this. Eastwood is my go-to since they're 15 min from my Parents house and offer great products across the board.
'90 245 325k mile DD
'79 242DL
'02 Trans Am WS6-Konis+Stranos, full exhaust, 353rwhp/373rwtq, Fikse FM5
'76 BMW R75/6
TempleUWS6 is offline   Reply With Quote
Old 06-15-2016, 11:31 PM   #16
holdenjp
Great. Let me know how you like it. I'm planning on doing mine in the next month or two but obviously don't want to spend hours for a poor result.
Old 06-16-2016, 08:20 AM   #17
MoCounselor
MoCounselor's Avatar
Another vote for Raammat. I used to sell and install car audio in the mid-90's and have been into it ever since. Used pretty much all of the brand name stuff, including dynamat, accumat, etc. Raam is by far the best value. If you couple it with some of his ensolite closed cell foam and some mlv you will have a VERY quiet car.
-Ben
MoCounselor is offline   Reply With Quote
Old 06-16-2016, 08:41 AM   #18
Stiggy Pop
Stiggy Pop's Avatar
This is what I used and I was very happy with it. I did pieces of it on the entire inside of my 242 including the roof. I read a test where 50% coverage with RAAMmat was more effective then 100% coverage with peel-n-seal style roofing products.
That took a ton of the drum out of the panels. Then I did a 100% coverage layer of the floor of the car with Frost King duct insulation, which is a foil backed closed cell foam. Thought being this would be my noise layer.
The underside of my car has no undercoating/is painted so when I was first driving it I could hear every grain of sand hit underneath, this all made a huge difference. The RAAM is nice stuff.
Also my favorite tip I picked up was to wad up some butyl rope and jam it between the support beam and the outer door skin. The difference in the sound when closing the door was so impressive.
'79 242
943 pickup
Old 06-18-2016, 11:11 AM   #19
holdenjp
-Ben
Anyone have any feedback on heat reduction with RAAMat?
Old 06-18-2016, 11:44 AM   #20
NO_SPRK
ihazkoolaid
NO_SPRK's Avatar
wow looks good. i need this in my 144. not much from the factory and even less left now.
did you find any issues re-installing the interior? mostly carpet
69' 145 / 73' 142 / 84' 244
Buyer/Seller Feedback
NO_SPRK is offline   Reply With Quote
Old 01-20-2017, 12:10 PM   #21
holdenjp
Reviving an old thread to see if there is any more input. I got an email from Eastwood today about a discount on XMat and since my summer project is to install new carpet and something to kill some sound I thought I might buy it now.
