Old 01-25-2005, 06:52 PM   #1
ovlov760
ovlov760's Avatar
Default Glass pack louver direction Q?
I bought a 3" glass pack muffler that says it can be installed in either direction. It's the louver type. I'm curious which direction of install would be best on a turbo car? Open side of the louvers facing the direction of exhaust flow or facing away?
2006 V70R GT
2011 XC90 R-design
1998 V70 AWD
1966 M-B 230
2011 C30 T5M
2006 XC70
1997 850 T5
1988 760 Turbo
Old 01-25-2005, 08:56 PM   #2
grebnut
TheSlovo
grebnut's Avatar
if you mount it with the louvres so they will catch air and suck it out to the packing around the outside, it will be quieter but not flow as well. if you mount it the other way, visa versa. i would say the latter would be better but i am already deaf from my car so its your call if they say its ok to mount either way. have fun. later,
ben
Pics
grebnut is offline   Reply With Quote
Old 01-25-2005, 09:11 PM   #3
ovlov760
ovlov760's Avatar
Thumbs up
I mounted it with the louvers facing away from the flow of exhaust. So far i'm pleased with the results. It's not a whole lot quieter at idle but driving wise it seems a lot quiter and under acceleration it has a nicer sound. I didn't drive it a lot but i'm not feeling any loss of power. It is a Summit brand and unlike the other 3" ones I looked at it is actually 3" all the way through and not just at the inlet/outlets.
Old 01-26-2005, 12:35 AM   #4
yozsi
yozsi's Avatar
normally i would not use that type of glasspack on a turboed car, i would stick to the cherry bomb type.
yozsi is offline   Reply With Quote
Old 01-26-2005, 12:45 AM   #5
ovlov760
ovlov760's Avatar
It does not look like it would be that restrictive as it is really 3" inside and the baffles don't stick up much.
Old 01-26-2005, 01:10 AM   #6
yozsi
yozsi's Avatar
dont you think it would cause turbulence of the exhaust gasses?
Old 01-26-2005, 02:57 AM   #7
ovlov760
ovlov760's Avatar
dunno? The baffles are facing away from the flow of exhaust and it's a side exit exhaust with no other mufflers or a cat.
