Old 01-03-2017, 01:38 PM   #1
rom
rom's Avatar
Default What grille is this and where do i get one.
This is the exact grille i want, i can't seem to find any information about one and i'd like one.
Religious people scare me.
rom is offline   Reply With Quote
Old 01-03-2017, 01:52 PM   #2
sbabbs
sbabbs's Avatar
If that's a 240 then it's a 240 eggcrate grill probably from europe.
Old 01-03-2017, 01:54 PM   #3
Matt
ICY HOT STUNTA
Matt's Avatar
you have to make it.
SHOtime - '90 744 Turbo
The LowCar - '93 945 Turbo
Ghetto Superstar/SkidCar - '88 740
Brown - '85 740 Turbo
Matt is offline   Reply With Quote
Old 01-03-2017, 02:21 PM   #4
rom
rom's Avatar
ahh. that was my second guess. that it was a flathood eggcrate grille shoved into an 86+ frame.
Old 01-03-2017, 03:05 PM   #5
No they're out there but not Tbricks cheap.
Old 01-03-2017, 07:17 PM   #6
p18002.5t
thats Mathias Vxs car, he works for koenigsegg ....in the design department, so making his own gill probably isnt a stretch.
That car has tones of small things done to it, like front fenders sectioned and welded in to the rear wheel arches, it was one of the first if not the first 240 to be legally registered with a t6 engine.
The list is long you, you can read about the car on speedhunters
p18002.5t is offline   Reply With Quote
Old 01-03-2017, 07:48 PM   #7
Euro grill part number 1304353. Priced appropriately and available from Europe.
Old 01-03-2017, 08:02 PM   #8
Matt
ICY HOT STUNTA
Matt's Avatar
still needs to be modified heavily...
Old 01-03-2017, 08:30 PM   #9
The euro models got the 86-> front sheet metal in 81. So the grill would only need to be modified to fit up to the front of the hood. This grill was used with a flathood but shouldn't need much to work with the 86 and newer hood. I saw a nice red 242 turbo with this grill a Carlisle a couple times. But the car was fitted with a flathood.
Old 01-03-2017, 08:38 PM   #10
Matt
ICY HOT STUNTA
Matt's Avatar
do you not see that the slash is gone and the indents where it would have been have been filled in?
Old 01-03-2017, 10:02 PM   #11
I see that but he started with that grill. The rest is up to you.
Old 01-04-2017, 12:16 AM   #12
Tuff240
240 Ninja
Tuff240's Avatar
It's a 240 surround with a 740 turbo insert fitted to it. It's not a euro 240 eggcrate grill.
-Patrick
Old 01-04-2017, 12:24 AM   #13
vlvosavr
^^ Quite right. Still requires modding. The 740T grille is flatter than the 240 surround, so the rib across the bottom has to be removed to allow it to bend a bit more. Other trimmage is required to adapt it to the 240 surround. I'm right in the middle of doing all this now...
vlvosavr is offline   Reply With Quote
Old 01-04-2017, 01:05 AM   #14
LC4CARL
Aero challenged
LC4CARL's Avatar
Any idea how he blacks out the light trim?
@PDXvolvo on IG
Old 01-04-2017, 01:27 AM   #15
Tuff240
240 Ninja
Tuff240's Avatar
Judging by the way the front bumper trim is peeling away at the edges, he probably just painted it.
The e-code headlight and turn signal trim were available in black also (for turbo cars).
Cheapest and easiest way to do it yourself is Plastidip.
I've done and tried all kinds of methods of painting them. The plastidip holds up the best.
I used to have to repaint the black trim on the front of this car every 6 months. Since using plastidip it's been almost 2 years and I haven't had to touch it. It's also commute to work daily driven 356 days a year and sits outside all year long.
Old 01-04-2017, 01:51 AM   #16
LC4CARL
Aero challenged
LC4CARL's Avatar
Plasti Dip is an air-dry, specialty rubber coating. In fact, its the original peelable, flexible, insulating, non-slip, durable rubber coating. The Plasti Dip product line provides a wide range of coating solutions from automotive customization to home improvement. With over 50 colors and enhancers of Plasti Dip, including a Create Your Color Kit, the possibilities are endless!
Sounds great. Just scuff the chrome and apply?
Old 01-04-2017, 02:47 AM   #17
Tuff240
240 Ninja
Tuff240's Avatar
Even easier. Just wash, dry, tape off what you don't want it on and shoot it. No scuffing or prep (other than being clean) is necessary.
Lowes and Home Depot carry it in spray cans.
Old 01-04-2017, 03:02 AM   #18
2fast242gt
Do you have a cobalt?
My eggcrate has no indent factory.
1983 242dl
*6.0 lq4 swaped* Build thread
Old 01-04-2017, 03:04 AM   #19
Jack
junkman
Jack's Avatar
doesn't even need to be clean
+1 on longevity of it ... spray it on trim and forget about it
I love you even more Jack.
Dont bother, I would literally rather throw them away than give you the pleasure. I will never sell to you.
