Old 01-09-2017, 10:16 PM   #1
Simi
Upsetti Spaghetti
Simi's Avatar
Default 1988 745 Turbo "Work Moose"
I guess I can make a thread about this car since I am kind of modding it...
I bought it from another turbobricks member as a DD because the AC worked really good and I figured that modding your DD wasn't the best idea anymore. Wanting to keep the paint of my 240 in decent shape still I went for something I could not care about at all.
Meet the bone stock 1988 745 Turbo wagon with a 13c, the only things going for it being that it ran and it had working AC. Interior was gone, exterior was gone, 5psi slow and it was automatic.
I even wanted to sell it and get something different for a bit.
But I cant sell it... Its a curse
First day I got it, no suspension, no abs, exhaust full of holes and various little things wrong with it. 329K miles
Matching wagons
Broke the damn hood cable, ended up swapping everything over from a later 940, that was a pain in the ass
Gross Headliner
Aside from the intake filter, fixing the pcv and stuff, I got this (its silicone):
Also installed my spare MBC and set it to 12psi, did suspension work, fluids and basic maintenance here and there, after that it sat like this for a long time, doing basically nothing to it including washing it.
In the meantime, I ran it without exhaust cause it was destroyed anyways and full of holes. I then put in a good exhaust.
The AW71 acted up briefly when I did a tailshaft seal when it didn't want to go back into first, it eventually fixed itself.
Then all of a sudden I started taking interest in the car, found a mint interior in the junkyard, not just any interior. Fastest i've ever pulled one, sadly couldn't get the mint dash though.
Then I got tired of looking at terrible paint every day, so we all did something about it. $100 later, some rollers and 1.5 cans of rustoleum later....
End result...
Then the headgasket went...
Once that was done, I replaced the plugs while I was at it, seemed fine till I shot one out the cylinder head, now the whole thing comes off again cause it turns out all 4 are stripped, they are glued into the head but I still have compression loss.
Anyway, being bored of the automatic and its ****ty gas mileage.
Started a manual conversion,
Then finished
Put in the first m46, that exploded in 2 days due to something with the bearings and the shift forks.
Put in a 2nd m46 from a 240, good to go except for a questionable overdrive which seems okay now. (now I can do a swap mostly alone in ~6 hours from start to finish.
The M46 really makes these more fun to drive, also a lot more responsive
Now its at 362k miles and I drive it everyday, right now chasing a high idle, not as good as it should be gas mileage and fuel cut at high throttle high rpm pulls.
1989 240 Turbo
1988 745 Turbo - SOLD
1991 940SE - SOLD
1995 850 T5-R - SOLD
1991 740 Turbo - SOLD
1987 240 - Crushed
1989 740 "Satan"
1987 760 Turbo
Leave Me Feedback
Simi is offline   Reply With Quote
Old 01-11-2017, 03:26 PM   #2
volvonyc
ouch that's alot of orange peel. what rollers and what did you use to reduce the oil base paint? also did you use a hardener?
if not then you will have to wait a long while before attempting to wet sand and polish
volvonyc is offline   Reply With Quote
Old 01-14-2017, 07:01 PM   #3
Simi
Upsetti Spaghetti
Simi's Avatar
I didn't reduce the oil based paint initially, it went on really thick. Didn't use a hardener, took about a month to fully cure. Not going to bother sanding it, I like the fact it feels like a fridge and for 100 bucks its honestly a lot better than how it looked before.
Old 01-14-2017, 07:20 PM   #4
BR1CKHOUS3
I like the tuna here
BR1CKHOUS3's Avatar
Nice 7! I did the same interior swap (black leather to checkered cloth) and love it. Jelly of your driver's seat being so nice.
We don't do it for the glory.
Only two ways to find out...18 bolts or 18psi
BR1CKHOUS3 is offline   Reply With Quote
Old 01-14-2017, 07:27 PM   #5
Simi
Upsetti Spaghetti
Simi's Avatar
The bolster near the door needs to be redone and vinyl on that side too isnt perfect but repairable, otherwise the seats are mint, they came from a 180k car, the speaker monts on the door panels are even undamaged.
Old 01-14-2017, 09:25 PM   #6
soclosenotnear
Nice wagon. That's a lot of work. I wouldn't mind owning an 88-89 m46 wagon with the early front end and better wiring harnesses.
check my feedback here
Old 01-30-2017, 12:37 AM   #7
Simi
Upsetti Spaghetti
Simi's Avatar
Wiring harness is perfect on this one, aside from the damage I did to it.
Also added this
Started on the next project, a cylinder head that doesn't shoot plugs out. Just replaced all the studs today with really nice aftermarket ones, threw in an A cam too.
High idle was sort of fixed with throttle body linkage from a 240, i am amazed at the better throttle response it has with it.
Throttle body is main suspect.
Still havent fixed the cut i'm having at full throttle, may be knock sensor.
Old 02-06-2017, 03:43 PM   #8
Simi
Upsetti Spaghetti
Simi's Avatar
Fixed the m46, swapped the overdrive for another unit, this is what I found on the old one.
Old 02-13-2017, 08:45 PM   #9
Simi
Upsetti Spaghetti
Simi's Avatar
And this is where I am at now, partout may be soon.
Old 02-13-2017, 09:05 PM   #10
okoye
okoye's Avatar
what happened to it?
Old 02-15-2017, 01:33 AM   #11
Simi
Upsetti Spaghetti
Simi's Avatar
Rear ended
Old 04-01-2017, 09:11 AM   #12
Simi
Upsetti Spaghetti
Simi's Avatar
And it's back from the dead
Old 04-01-2017, 10:40 AM   #13
soclosenotnear
Awesome. A great feeling I'm sure.
Old 04-03-2017, 03:25 AM   #14
nordmaschine
forced instruction
nordmaschine's Avatar
That minor scratch didn't even qualify for "rear ended"...
Good luck. Liked the gold, but I know what you mean with being tired of horrible paint...
Jetronic is romantic.
- '86 780 TDIc - Bertone #301
Whiteblocks
Old 04-13-2017, 07:06 PM   #15
Simi
Upsetti Spaghetti
Simi's Avatar
Also found out what the WOT cut was, bad tps combined with a bad tps wire (red/white) Cut the wire and replaced the TPS and its perfect and happily boosting.
SOLD
