Old 03-11-2017, 08:44 PM   #1
DET17
Reformed SAABaholic
Default Is the 3.31 final gear too tall for my 19t and AW71?
Just began today with a surgical reconstruction of the DD, my 940 that has served me well the last 4 years.
Of course the 3.73 final gear is presently installed in the 1041 Dana..... Volvo seems to have chosen this ratio for all the turbo 7's and 9's with the AW71. I'm sure they had their reasons to do so.
I've got a low mile '92 complete rear end fitted with the Eaton LSD and ABS tone ring (a rare bird); my current plan is to pull the LSD, remove the 3.31 ring gear and install the 3.73, set the backlash & preload those carrier bearings. Much less aggravation to just install the carrier, rather than the full pinion install.
With her sky high sitting on 6ton jackstands, I wondered if the complete 3.31 rear end assembly swap wouldn't be less work... perhaps? I've set up ring & pinions, so no worries there. I know the 3.31 final gear would give some relief to my 70mph cruise RPM of 3100.
However I wonder if the planned 19t turbo will be negatively affected by that tall final gear.
I'm guessing that the last 2 series cars with the B21 turbo didn't offer an automatic option.... but I don't know that for a fact. If they did, were they also fitted with the 3.73?
Anyone tried it? Please share your experience.
Old 03-11-2017, 08:52 PM   #2
cosbySweater
cosbySweater's Avatar
Honestly I would just swap the diff over. You won't have to set back lash or anything since you are just swapping the carrier
Old 03-11-2017, 09:18 PM   #3
To old for this
Keep the 3:73 I went tru this. The 331 seem to lug the motor while the 3:73 seemed to keep it just on the edge of the sweet spot. Mpg also suffered. I reinstalled the 3:73 and swapped the carrier to keep the alb and correct speedo.
To old for this is offline   Reply With Quote
Old 03-11-2017, 11:25 PM   #4
It'll never spool.
Old 03-12-2017, 01:19 AM   #5
Wilford Brimley
LOCAL ONLY
Wilford Brimley's Avatar
Nope
'91 744t...it's fast as phuck
Old 03-12-2017, 09:34 AM   #6
DET17
Reformed SAABaholic
Well I had forgotten the granny first gear in the AW70/71..... must have had 700r4 on the brain (first gear is 3.06)
From WIKI:
Gear Ratios
Gear AW70/71 AW72
1st 2.45 2.83
2nd 1.45 1.49
3rd 1.00 1.00
4th 0.69 0.73
Rev 2.22 2.70
Typically first gear * final gearing = 10~10.5 for a performance application
The AW70/71 provides 2.45 * 3.73 = 9.14, still a bit low of target
The AW70/71 provides with OPTIONAL rear gear is 2.45 * 3.31 = 8.11, really low
The AW72 looks better yet with 2.83 * 3.73 = 10.55, right on target
I'll keep the 3.73 final gear and watch for a 95 AW72 at my local PnP
Old 03-12-2017, 10:30 AM   #7
connorb850
I believe the AW72 only came in the B234 powered cars.
connorb850 is offline   Reply With Quote
Old 03-12-2017, 11:21 AM   #8
Kjets On a Plane
Devoid of Luxury
Kjets On a Plane's Avatar
^Correct for USA market.
If you don't tow in 3rd a lot, I didn't notice much (if any) actual difference in cruise RPM (and really no MPG difference) with the 4.10 axle which I liked in the turbo car everywhere else with the auto.
16V converter and AW-71L with a 4.10 is nice if you want to have a nice compromise for power and economy. I thought the converter lockup speed and shift points were weird with the 3.73 and considered the 4.10 basically mandatory with a stockfish B230FT car with the AW-71L. The 8V stock AW-71L converter is woefully dreadful for performance use. Good for N/A MPG though....just very, very slow.
How PSI a stock can support?
Old 03-12-2017, 07:54 PM   #9
DET17
Reformed SAABaholic
By the numbers, the 4.10 final gear with the AW71 first gear 2.45 is nearly at the performance target with 10.05 torque multiplication. K-J is right, with the lockup converter of the AW71L it would balance out nicely with that final gear.... better performance "running thru the gears" and cruise OD nearly same as a plain Jane AW71 and 3.73 final. If you know the P/N for the 16V converter, would be nice to have in this thread. Perhaps TASCA can still get it.....
Was it the 960s that got the 4.10?
Old 03-12-2017, 08:08 PM   #10
cosbySweater
N/a lh2.4 740s and n/a 940s got them iirc. I think I still have a 4.10 r&p if you are interested
Old 03-15-2017, 08:33 AM   #11
Janspeed
a 3.31 rear end with a bigger then stock turbo and hotter then a T-cam in the head will be a dog to drive in top gear. 3.31 is way to tall.
if you want to accelerate from 50 to 75mph in top gear you will be forced to downshift because in top gear the engine will not turn in boost-rpm-range. If you mash the throttle in top gear you will be waiting, waiting, waiting for the boost to kick in and the real boost will only start building at speeds in excess of 75mph. That gets annoying realy quick.
3.73 is nice but a 4.10 will make the whole car even more punchy and enjoyable to drive. That would be my choice.
Old 03-15-2017, 05:49 PM   #12
B20Paul
Originally Posted by DET17 View Post
....the 3.73 final gear is presently installed in the 1041 Dana..... Volvo seems to have chosen this ratio for all the turbo 7's and 9's with the AW71. I'm sure they had their reasons to do so..... I know the 3.31 final gear would give some relief to my 70mph cruise RPM of 3100.
3.73 is the shortest diff for your carrier, 3.91, 4.10, 4.30, etc. has a different carrier.
So you have AW71, 3.73 and that gave you cruise rpm of 3100 @ 70mph? That seem very wrong to me. Speedo, Tacho or Gearbox has a problem. With my 205/60x15", AW71 + 3.73 = 2670rpm, which is 16% less, very wrong.
B20Paul is offline   Reply With Quote
Old 03-15-2017, 05:54 PM   #13
B20Paul
Agreed, I think 3.73 for T cam, 4.10 for a decent street cam.
Old 03-16-2017, 02:33 AM   #14
Kjets On a Plane
Devoid of Luxury
Volvos all use the "3.73+" D30 carrier. They make up the difference with the ring gear thickness...
Ratios are pretty close on the O3-71 gears 1-3, except OD is a big jump from 3rd.
Old 03-16-2017, 09:48 AM   #15
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
3.31 isn't that rare, 960's have em, some 940's got em, etc.
I swapped one in to offset the .75 OD from the 4L80e
Megasquirt Tuning!
Old 03-16-2017, 12:57 PM   #16
DET17
Reformed SAABaholic
Nice catch B20! Bad case of brain flatulence.... I was thinking of my 70 Malibu with TH350 and 3.55 final gear (3100 RPM at 70)
Here is the calculation from my Excel spreadsheet of trans. & gearing options for my 940; this option the AW71 and various final gears. Actually with the 3.73 final it calculates out just above 2400 RPM:
[IMG][/IMG]
Last night I pulled the G80 out of the installed 1041, and it slid out with not much of a pull (preload on carrier bearings). Couldn't have been an .006" preload on those bearings, as is spec'd in the greenbook. Then I went into the donor 1041 with the 3.31 and removed this:
[IMG][/IMG]
Now THAT guy had some preload! It took a good grunt with a pair of levers to disengage it from the housing. As K-J noted, this carrier should be good to accept all the Volvo ratios..... so that has me in a quandry. This discussion about how "peppy" the 4.10 final would be in my application..... only costs me another 240 rpm at 70mph cruise while hitting the performance target torque multiplication value of 10.05. DAMN it, y'all have me thinking to go find a boneyard 4.10!!!! I'm only 14 bolts away from having the 1041 housing out.
However, if the only donors are NA 740s and 940s, those have become suddenly scarce in these parts. I thought for sure there was also a 960 fixed axle that came with the 4.10 final gearing. The window is open right now, as I could put the rear work on the back burner while I source one. All help appreciated to confirm the exact suitable donors.....
Old 03-16-2017, 01:09 PM   #17
linuxman51
linuxman51's Avatar
I've got one in the back end of a 1990 740. swap the diff cover, chunk, and ring gear and roll out.
*to clarify, I've got a rear end. I've got no plans to use another volvo 4.10 any time soon for any of my current or future projects
Old 03-16-2017, 02:01 PM   #18
sbabbs
sbabbs's Avatar
THis ain't a G80, looks like the rare factory LSD.. Powerlock. My 91 NA 740 had 4.10 ratio rear end gears.
[IMG][/IMG]
1990 745 B230FT Getrag JohnV flywheel 240mm clutch 13c A-cam 3.54 G80 544K MILES
Old 03-16-2017, 03:14 PM   #19
DET17
Reformed SAABaholic
Keen observation Simon! The G80 is sittin' on my workbench. Yup, only one of them thar' 48 tone ring LSD's that I've seen.
"Hoping" the AW71 will protect those cross shafts from exploding..... or I might as well install the TrueTrac 588.
Old 03-16-2017, 04:21 PM   #20
Powder>Paint
verified, +1 on 940 na for sure, no more single tire fire.
personally, most fun gear there is. I love the mechanical advantage in the 60ft, never looked back since i put the na rear in my turbo wag. i dont know if anybody really commutes these cars much(distances), phuck miles per gallon. Smiles per gallon is where its at.
Powder>Paint is offline   Reply With Quote
Old 03-16-2017, 04:28 PM   #21
linuxman51
linuxman51's Avatar
running out of gear is a real mother****er.
Old 03-16-2017, 06:20 PM   #22
Broke4speed
Broke4speed's Avatar
I've got a 3.54 in my sedan currently, from the BW55 days. Now I've swapped in the AW71L and am going to try it out with the tall rear end. I do a LOT of highway cruising, but speed limits peg at 60mph up here...so that's where I'll be staying. I'm a bit concerned my RPMs will be too low at that point...but I won't know until I try. The 16T will probably spool fine, and I'm not really concerned if it doesn't, so my only concern is whether or not it will be lugging too hard to remain fuel efficient at highway speeds.
1984 B21T (formerly A), AW71(minus L).
Old 03-16-2017, 06:40 PM   #23
culberro
culberro's Avatar
SAM, KG Trimning, or similar makes new cross-shafts for not much $. FYI.
Old 03-18-2017, 04:36 AM   #24
per0lund
per0lund's Avatar
With a 3,31 ratio and a AW71L, at cruising, lock up at 3rd will go in at 115 km/h and rev is some 2400 rpm, you hardly get any boost at all with a -19T from there, you have to make a kickdown.
I find it the best way to describe it.
At the other hand, its quiet fun to do kickdown in 165 km/h or more.
Volvo 745 -90 B-230FK , M90, 3,31:1 Eaton diff,-MS3X 83 lbs/hr injectors TD04HL-20T
S60 2,5T AWD
SAAB 9-5 2,3T
Ford Thunderbird LX -95
per0lund is offline   Reply With Quote
Old 03-18-2017, 08:36 AM   #25
DET17
Reformed SAABaholic
Side by side comparison of the Power LOK LSD and the G80, both with ABS tone ring:
[IMG][/IMG]
[IMG][/IMG]
Looks the majority of folks has cast their votes for the 4.10 final gear..... I'll start watching the ATL pull-a-parts for a 90-95 NA 7/9, and/or the hen's teeth GLE 16V cars. My UK source also shows the 95 960 with an option for the 4.10. Might as well do the job right, since I plan to be DONE with this car and move onto the next this coming winter.
