Old 10-25-2017, 06:13 PM   #1
Patestrickland
Patestrickland's Avatar
Default Classicswede Lowering Springs
Hey, I recently bought a 245 and have been considering the classicswede lowering springs. I am torn between the 60/40 mm and the 80/60mm lowering springs. If anyone has these springs on there car could you post them please?
Patestrickland is offline   Reply With Quote
Old 10-25-2017, 06:51 PM   #2
KeizerBrickGuy
Sh*t pot stirrer
KeizerBrickGuy's Avatar
The question is how low do you want to go? Remember you will need to get adjustable panhard and torque rods to keep the geometry proper. 60/40mm = ~2.3/1.5". 80/60mm = ~3.1/2.3". How's your driving style? Road surface quality? Goals?
-Stephen
#mclovethesenuts
-My car: White 1991 244, 330k miles. B230F LH2.4, AW70, R134a retro
-Wife's car: White 1990 244DL, T cam, 200k miles.B230F LH2.4, AW70 w/aux cooler, Virgos, tow hitch
-PSM 2002 Subaru WRX wagon: EJ205, 5MT, 120k miles, Perrin TBE
-1997 Subaru Legacy Brighton: EJ22, 5MT, 236k miles
Old 10-25-2017, 07:28 PM   #3
Patestrickland
I keep hearing about the geometry of the 240. Could you explain to me what that is?
Old 10-25-2017, 07:32 PM   #4
Patestrickland
Also is your Volvo lowered?
Old 10-25-2017, 07:56 PM   #5
Tuff240
240 Ninja
Tuff240's Avatar
Save the money for real coil-overs and just cut your springs for now. Bonus is you get to choose your exact ride height.
-Patrick
Old 10-25-2017, 08:14 PM   #6
thatcher.hubbard
thatcher.hubbard's Avatar
The 240 has a solid rear axle and a five-link suspension system. One of those links is the panhard bar, which bolts to the body at one end and the axle at the other. It runs from side-to-side. It locates the rear axle in a vertical plane across the back of the car. What this means is that the rear axle moves side-to-side slightly as the suspension compresses and rebounds. If you crawl under your car and look around it's pretty obvious.
If you lower the car without shortening the panhard bar in any way, it will hold the axle off-center towards the passenger side of the car.
The torque rods are the same story, just front-to-back. IPD has sold a boatload of both over the years because everybody looks at these cars and thinks they need to get lowered.
Kaplhenke sells version of both as well.
thatcher.hubbard is offline   Reply With Quote
Old 10-25-2017, 08:18 PM   #7
Patestrickland
The coilovers I’ve seen seem like the require welding which I don’t know how to do. Are there any that just bolt in?
Old 10-25-2017, 08:29 PM   #8
Tuff240
240 Ninja
Tuff240's Avatar
Originally Posted by Patestrickland View Post
The coilovers Iíve seen seem like the require welding which I donít know how to do. Are there any that just bolt in?
https://www.kaplhenke.com/collection.../240-coilovers
Old 10-25-2017, 08:32 PM   #9
Patestrickland
I’ve seen the kaplhenke coilovers before but do they require any type of welding or can I just put them in right out of the box?
Old 10-25-2017, 08:34 PM   #10
Tuff240
240 Ninja
Tuff240's Avatar
Iíve seen the kaplhenke coilovers before but do they require any type of welding or can I just put them in right out of the box?
He sells several different options from do it yourself up to a very high end solution. Yes, he has kits that bolt in.
Old 10-25-2017, 08:35 PM   #11
CAPT_BLOTTO
#Crush It
CAPT_BLOTTO's Avatar
I wouldn't buy anything from classic swede. The owner tells people they should kill themselves and makes homophobic remarks.
Hello My Glorious!
Old 10-25-2017, 08:37 PM   #12
Patestrickland
Ok thank you for your help. I think I’ll just deal with stock ride height and save up for real coilovers.
Old 10-25-2017, 08:39 PM   #13
Tuff240
240 Ninja
Tuff240's Avatar
Ok thank you for your help. I think Iíll just deal with stock ride height and save up for real coilovers.
Where are you located? USA or?
It's pretty simple to cut your springs and as long as you don't get carried away and you trim the bump stops down, it will still ride fine and actually handle better.
Old 10-25-2017, 08:42 PM   #14
Patestrickland
I live in North Carolina
Old 10-25-2017, 08:43 PM   #15
Patestrickland
I considered cutting the springs but I heard that is kind of dangerous.
Old 10-25-2017, 08:46 PM   #16
Tuff240
240 Ninja
Tuff240's Avatar
On a 240 it's not that big of a deal. I've had 240's with cut springs for 20+ years. I tracked them, auto-x'd them and driven quickly in the mountains where I grew up with out a single problem. I have 3 teenage boys, all drive 240's with cut springs daily.
Old 10-25-2017, 08:47 PM   #17
Patestrickland
About how many coils did you cut off?
Old 10-25-2017, 08:49 PM   #18
Patestrickland
And I live on the coast so it’s just flat around here.
Old 10-25-2017, 08:53 PM   #19
Tuff240
240 Ninja
Tuff240's Avatar
Every 240 is a little different and it depends on how low you want to be. I cut 1.5 off of my parent's (67 years old) 90 245. Rides better and handles better. Hardly notice it's lowered. My personal cars are usually 2.5-3 coils. If you don't want to be very low, 2 coils is a good place to start. That is close to the IPD sport spring height. Trim off more if you want to go lower. At 3+ you will really start to compromise ride quality as you will be running out of suspension travel.
Old 10-25-2017, 08:56 PM   #20
Patestrickland
I want to be about 2 fingers in between the wheel and the fender. How many coils would that be?
Old 10-25-2017, 08:56 PM   #21
Patestrickland
And you send a picture of your personal car so I can see what 2.5 or 3 coils does?
Old 10-25-2017, 08:59 PM   #22
FezMonki
That kind of makes me want to buy from him more. Not that I have any problem whatsover with homosexuals, I just reserve my right to make homophobic jokes. And to tell a lot of people they should kill themselves. Daily almost.
Looking for S90 fat armrest.
FezMonki is offline   Reply With Quote
Old 10-25-2017, 09:05 PM   #23
Tuff240
240 Ninja
Tuff240's Avatar
I've literally lowered over 100 240's with anything from cut springs to high end custom race coil-overs. They are ALL different. You don't sound like you want it really low, so just do 2 in front and 1.5 in back.
My oldest son's daily driver 1983 245 DL with 17x8/9's and 245/40-17's all around. It's cut roughly 3 coils.
Old 10-25-2017, 09:07 PM   #24
Patestrickland
I really like the look of he blue 245.
Old 10-25-2017, 09:08 PM   #25
Patestrickland
Does he bottom out or hit bump stops often?
