Old 11-16-2017, 09:17 AM   #1
eebird
Default 240 dash crack
No doubt this has been discussed elsewhere and I looked through some old threads. I have some cracks in my 92 240 dash. The one creeping towards the front edge is what concerns me. I would like to arrest the crack spreading and then put a cover over it, but what materials should I use to fill the crack that would stop it from spreading?
I don't think I want to spend the money on a replacement dash because I assume that may crack as well...?
eebird is offline   Reply With Quote
Old 11-16-2017, 09:40 AM   #2
57plymouth
57plymouth's Avatar
Once they start to crack, you really can't stop them. Put a dash rug on it if you can't find a good uncracked dash.
Sven, the 1991 245
Old 11-16-2017, 09:47 AM   #3
240 Dash Mat Cover
Old 11-16-2017, 09:57 AM   #4
They're boxy but good!
There's also dash caps available
http://www.americandashcaps.com/volvo.html
I paid $46 for one probably 8 years ago, it cracked in the same place as the original crack, so ymmv
Over the hump of Truth and through the flaming hoop!
Old 11-16-2017, 10:13 AM   #5
TWD
TWD's Avatar
I have had success stopping cracks from growing and minimizing their appearance by:
Carefully put wide painters tape exactly on the margins of the crack.
Using a quality black RTV such as Permatex or JB Weld, slightly overfill the crack.
Let it settle for a couple of minutes and then use a putty knife or similar to level it and force the RTV deep into the crack. The excess will be on the tape.
Give it a minute or two and carefully pull up the tape.
After it dries install the dash cover from RWC.
TWD is offline   Reply With Quote
Old 11-16-2017, 10:23 AM   #6
Vincent Gagnon
Vincent Gagnon's Avatar
Member of TBCCS
Old 11-16-2017, 09:16 PM   #7
nel621
http://forums.turbobricks.com/showpo...4&postcount=17
Old 11-16-2017, 09:17 PM   #8
Flock it.
Old 11-16-2017, 11:49 PM   #9
EivlEvo
If you really want to ATTEMPT to stop the crack you need to stop drill it.
The logic is that once it's splitting, it's effectively easy for it to continue to split. Because it's tearing at a finite point. If you drill a small hole in the end of the crack (as they do for airplanes) then it's basically trying to tear a rounded hole... which is much more difficult obviously.
That said, our dash isn't metal.
Old 11-16-2017, 11:52 PM   #10
Brick15
Brick15's Avatar
If you replace the dash the cracks will never come back if you use this consistently.
303 Aerospace UV Protectant
https://www.premereautodetail.com/wh...hboards-crack/
https://www.wholesalemarine.com/303-...iABEgIxHPD_BwE
https://boingboing.net/2015/09/03/30...ant-reall.html
Brick15 is offline   Reply With Quote
Old 11-17-2017, 08:18 AM   #11
TestPoint
TestPoint's Avatar
The Coverlay brand dash covers are about as good as it gets for serious restoration.
http://coverlaymfg.com/lookup.html?c...sh+Board+Cover
These things were about $90 shipped a couple years ago.
My efforts start in post #147
http://forums.turbobricks.com/showth...=256460&page=8
Ford V8 Conversion Manual -
Old 11-17-2017, 01:32 PM   #12
Mr. V
Mr. V's Avatar
I just checked their online search function and it shows none available for an '82 244 GLT.
Guess I'll have to call; you sourced one for your '78 a couple years ago, so you'd think they'd have it.
Old 11-17-2017, 11:28 PM   #13
eebird
Thanks for all the info/thoughs. I have looked at the Coverlay covers, I may get one....I believe the reason the 1992 is not listed is that it does not have the center vent, but the covers that fit up to 1988 240s still fit 1989-1993, just with that hole for the center vent. I am not 100% certain, but that is my understanding.
