Old 01-15-2018, 05:29 PM   #1
klork
Default T-5 to white block throw out bearing.
What are you guys using for a hydraulic throwout bearing when using a T-5 behind a white block? This is what I came up with. http://transmission.moderndriveline....ip-on-p508.htm
Wasnt sure if there is a cheaper option out there or not.
Looks like the 850r single mass flywheel is the one to use. What clutch are you guys using. I should be around 300 hp. Wouldnt mind going a little over kill on the clutch but nothing crazy as it is a daily driver. This is going in a 745.
klork is offline   Reply With Quote
Old 01-15-2018, 09:08 PM   #2
DET17
Reformed SAABaholic
Reach out to "theFullBanana". He is the only actual user with a T5 behind the Whiteblock. I seem to recall that he used a McLeod hydro release bearing.
I should say, he has a running setup, not a jack stand queen.
Old 01-15-2018, 09:18 PM   #3
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
try this first: You can use a bearing retainer from the 05-up V6 cars to convert it to a hydraulic internal slave cylinder .
Now that being said it will depend on adapter and space available. Also Howe and Speedway Motors make some economical choices.
... I haven't gotten far enough to have a good answer yet... Still stuck on a flywheel before spending the other coin.
#79WDP
2010 Porsche Cayenne S - DD
2010 Cadillac Escalade ESV - Wifeys ride - 194k stock
2006 Cadillac DTS - Sons ride - 193k stock mint
1979 Porsche 911SC - stock
1948 Spartan Mansion travel trailer - aluminum greatness
Old 01-15-2018, 10:23 PM   #4
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
Yeah, a lot of chatter on this one, but I agree that not many have completed it that I am aware of. DeeWorks has an adapter available, but no install instructions.
Short list:
960 AT bellhousing
850 Flywheel
850 PP
Pilot Bearing?
DeeWorks adapter plate
Ford clutch disc (they came in multiple diameter sizes over the years, just a matter of finding the right one)
TO bearing... Hydraulic internal stock or a universal.
Not sure any of that helped but there you go.
Old 01-16-2018, 08:55 AM   #5
klork
I had most of that figured out. I like how deeworks website says the swap has been well documented but I have yet to find much of anything documented.
Old 01-16-2018, 11:08 AM   #6
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
THIS! So true, its a WTF are you referencing blow-off sales pitch. LOL
