Old 03-11-2018, 03:17 PM   #1
soclosenotnear
Default Spark plug wires
This is trivial I'm sure. 1995 944 turbo with wasted spark. I originally placed my Bosch coil where a 240 distributor lives so I could use factory 240 wires. The problem is 240 and 7/9 wires have different fittings. 7/9 wires "click" into place on the coil while 240 wires do not.
I was forced to relocate my coil pack. It's temporarily attached to my strut brace right over the valve cover. I need to find new plug wires that work better than the 240 wires or the old 940 wires I had that we're falling apart.
A new set of 7/9 wires will probably work ok. What brand works well? Volvo, bougicord, ngk? Also, size? Seems like stock is 7 mm but I see aftermarket unbranded options in 8 mm?
check my feedback here
Old 03-11-2018, 05:38 PM   #2
nitroboie
https://www.kingsbornewires.com/product-p/271483.htm
I'm running those in 8mm on my ws setup.
'90 244
'94 945T ipd cam, springs, sways, brace, 16T, TLAO chips, wasted spark, do88 IC
nitroboie is offline   Reply With Quote
Old 03-11-2018, 09:19 PM   #3
soclosenotnear
Look nice enough. Nice price. Are you using a Bosch 2x2 coil? I think mine was from some range Rover or something.
Old 03-12-2018, 07:47 AM   #4
nitroboie
Yep, the Bosch 2x2 from a range rover. They click into the coil just fine.
Old 03-12-2018, 09:33 AM   #5
gsellstr
gsellstr's Avatar
+2 on the Kingsborne's, got them on a couple of mine and know several others running them as well. Kingsborne will also do custom sets for you, different ends, lengths, boot styles, whatever, and they are easy to work with, located here in Cali. Had my wires in 4 days, including a custom coil wire.
FWIW, with the coil mounted on the driver side strut tower in a 7, with a block mount dizzy, yes, a 240 wireset works nicely.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 03-12-2018, 10:50 PM   #6
soclosenotnear
Thanks all. Ordered.
Old 03-12-2018, 11:42 PM   #7
thelostartof
unbalanced chemical
thelostartof's Avatar
You could also just call kingsborne and give them the coil and lengths of the wires and they can custom make them also.
Old 03-12-2018, 11:56 PM   #8
tryingbe
Boosting along.
tryingbe's Avatar
I'm using junkyard found 7mm resistor wires with a 420A coil and resistor plugs making 367whp...
So, I wouldn't spend too much money on spark plug wires.
85 GLH 367whp
00 Insight mpg > yours.
Old 03-13-2018, 09:32 AM   #9
Dirty Rick
Dirty Rick's Avatar
Watch out! You can easily out trick yourself in this area.
The current fad is replacing carbon core wires with "low resistance" spiral wound wires or even Copper strand wires.
Make sure you get a guarantee they won't interfere with the electronics.
I have it on good word that they don't work well with a MegaSquirt.
The marketing dweebs are playing on folks lack of understanding regarding high voltage behaviour.
Old 03-13-2018, 03:03 PM   #10
gsellstr
gsellstr's Avatar
Depends on brand I guess but I've got Accel's on the 140, running 100-500 ohms depending on length, fed by a wasted spark setup on MS1V3, and the Kingsborne's on the wagon caused no issues with MS, running 300-1k depending on length, fed by an MSD6A, BlasterSS, and at the time, MS2V3.
