#Crush It
![]() So I purchased this Mustard Yellow 77 244 after looking for an early 240 for nearly a year. This one fit all my criteria of being a sedan stripped out model with no a/c or power steering, as well as manual. So in the Fall of 2016 I flew out to Colorado and bought it sight unseen at the airport and drove it home. Overdrive didn't work but drove home great. Starting when cold was a big problem so I hotwired the cold start injector.
![]() ![]() I drove it for a short while before the winter and salt came. Next summer I tried to start it and it was puking coolant, barely would start, and was running pretty poorly even when it did start. So that's when I decided to start all over and build it with all the parts I had just lying around or available to me in the local junkyards. And everyone that knows me knows how I live in the junkyards. So began Phase 1: The pure junkyard build. PHASE I So Phase 1 consists of as purely* junkyard parts as I could get. Junkyard sourced 93 b230ft squirter block from a 940. Completely untouched bottom end Junkyard m46 from a 240 because I couldn't use the old m46 that came with the car Junkyard clutch and flywheel unknown miles Hand ported 530 head with stock valves and springs. Porting kit bought at harbor freight RSI Stage 2 cam although new was bought from RSI instead was traded for a set of junkyard C70 speakers and amp Running LH 2.4 and ezk with TLAO chips that was from the 92 volvo 940 project car that I bought just to part out 90+ mani from junkyard or the 940 K24 turbo from a wrecked V70R in the junkyard. Reclocked and modified slightly to work with the red block. *IPD k24 vband adapter Home made down pipe made with parts of various junkyard pipes. *3 inch exhaust with the cheapest thrush muffler from amazon. Stock 240 intercooler and 7/9 pipes modified S70 T5 injectors *AEM wideband bought new from amazon Boost gauge from the 940 I parted *Sitting on 16" BBS RS 16" wheels with Bridgestone Potenzas *New gaskets and seals for engine *Ipd 8mm plug wires Nardi vintage wood wheel found in a 70's Jaguar XJ12 ![]() ![]() ![]() Results were a Dyno pull of 184 whp and 263 ft lbs of torque on a broken wastegate actuator and only making around 5 psi. ![]() Phase II Phase II is moving into the new parts section beyond the limitations of the stock junkyard parts. But a lot of this is "old school" TB style. First step is to fix that wastegate with an aftermarket T3 style and bracket that TLAO made. Rx-7 front calipers with 940 vented rotors Getrag 5 speed swap to hold more power than the m46. Upgraded clutch for the getrag swap STS Machining flat flywheel Larger and modified 2" driveshaft Redo the exhaust with a better muffler, proper exhaust dump, and better supports to stop breaking studs on the turbo Microsquirt Eaton trutrac diff locker and a better ratio Maybe some suspension upgrades still figuring that out
Hello My Glorious! ![]() Junkyard Parts request thread! Mesquite FB page! Constant updates! Da Yellow Sold | $800 245 | 77 244 |
![]() oddest looking turbo I have seen. So that came stock on the v70r you are saying?
#Crush It
![]() What's odd about it? It's reclocked and a few other things I was going to document. If you look up a Volvo K24 turbo on google they look about the same.
#4 |
#Crush It
![]() From using cross sections and guides read online I used a die grinder and kit from harbor freight to port the head as well as a little bit of the exhaust manifold. I do recommend from experience to get a really good compressor. Mine could not keep up which slowed down the process considerably. Its very time consuming but it is sort of relaxing in a way. You just slowly work the metal to get the shape and the finish appropriate for what you're working on. I polished the exhaust and combustion chambers and let a rougher finish on the intake. Turned out pretty well I think.
Make sure you protect the valve seats too. I stuck old valves in to keep them from getting damaged. ![]() ![]() ![]() ![]() |
#5 |
![]() 17¢ has never looked so good congratulations.
#6 |
#Crush It
![]() With this being such an early 240 a lot of information was scarce and not a lot of changes were documented.
Ripping out the b21 wasn't bad. And I started putting together the squirt block. Replaced all the gaskets and sprayed some cleaner on the piston tops as well as the sides of the block. Aux shaft from a junkyard 240 to run the block distributor BE CAREFUL when torquing down the cover on the aux shaft and crank. The bolts break easily and then you have to wait for a machine shop to get it out. Ask me how I know. The early M46 will not work with LH 2.4. The bell housings are different and not interchangeable. I also had to swap the output flanges for the smaller driveshaft. They are interchangeable though. With it being an early M46 it does take some wiring work to make OD work. The later cars are setup for the self canceling push button OD. I had to buy a new shift knob and slider switch and wire it in. However the early shifters don't interchange with the later gearboxes due to a change in diameters. And the early knobs won't slide on a later shifter. So I had the machinists at work turn down the inside of the knob so it would slide on. Now it works like a charm! Now onto the LH 2.4 With the early car there's only a small fuse panel so I made a small expansion panel and some relays for the LH and fuel pump. A piece of ABS sheet and some various parts from amazon gave me plenty for what I need. The power for the fuse block is fused and comes straight off the B+ dist block by the headlight relay. I followed a guide on TB for the wiring and there's a few switched Red and red/white wires for that go to the under glove box connector coming from the engine harness. The last thing was wiring to the fuel pump. The early cars have the relay up way behind the left hand kick panel. There's a yellow wire IIRC that goes into the fuse wiring. The problem is in the 70s it seems Volvo only had access to 4 colors of wires. So through trial and error I found the wire that powers the fuel pump and wired to the new fuse panel. Another recommendation is ALWAYS use plenty of zip ties, clips, etc to hold your hanrness on. Mine fell off the second time I was driving and melted to the downpipe. It melted through the AMM and a few other sensor wires and kept blowing fuses. I ended up needing a whole new harness and a new AMM. Stupid mistake, but maybe others can learn from it. Oil cooler in a 240 was a pain. I didn't want to use the 240 style since those don't make oil changes any easier and clearance was already an issue in the area. The 740 ones that don't have coolant going through was the easiest. I could not seem to find the correct fittings to use the original oil cooler and it didn't want to mount by the battery with the intercooler and other pieces in the way. I ended up just cutting up some of the solid lines and uses high pressure oil hose with clamps on either end. I mounted it behind the grille on the sheetmetal that goes in front of the intercooler. The lines were routed underneath the RH headlight where an A/C line would normally go. So far it has been working out. No leaks. ![]() ![]() ![]() ![]() |
#7 |
![]() Great project!
1988 745T http://forums.turbobricks.com/showthread.php?t=356096 1972 142S http://www.turbobricks.com/forums/sh...d.php?t=311926 1991 780 Sold 1979 244DL Sold 1986 740+T Sold 1983 242T Sold |
#8 |
![]() Awesome build. This is something I've always wanted to do...a pure junkyard build...no shiny new parts.... Good luck!
2007 V70 2.4 1989 245 DL |
#9 |
![]() I dig it. Nice recycling work.
#10 |
Hey Shiny!!
![]() I'm liking this a lot, I was wondering who the other recipient of that tlao bracket was.
1991 Volvo 745SE Turbo 1992 Volvo 745 Turbo - Totaled 1994 Volvo 855 Turbo - Sold 1981 Volvo 245 Turbo - Sold |
#11 |
![]() All the starz *****
#12 |
#Crush It
![]() I think ansel made that because of my hatred for pineapple pizza.
#13 |
dude
![]() nice ride bro.
#14 |
Reformed SAABaholic
![]() Great boneyard build! HotRod used to build engines they dubbed "Junkyard Jewels"..... you are true to their intent. Low coinage & sweat, and they always wrapped with the dyno data.
What cam, stocker T? Pics of your trouble with the oil cooler? I helped my son fit a true 240 TIC oiler cooler & and lines to his 92 940 Turbo engine in his 89 245, and it bolted up with minimal issues. He was used a cut down 9 series E-fan, but the Setrab coiler bolted right up to the 89 sheet metal. "I am also, loving this build......."
Project "cheap thrills" build thread: http://forums.turbobricks.com/showth...67#post4211467 Feedback thread: http://forums.turbobricks.com/showthread.php?t=198746 |
#15 |
![]() Daddy like
'93 944 T - #TrophyVo '00 XC70 SE - Slow '11 XC90 V8 - Torque Monster |
#16 |
![]() Your car is almost as attractive as you, Captain Blotto
#17 |
#Crush It
![]() Thanks I guess?
I'll post more pictures this week of the oil cooler and other stuff that's been done. Like the MR2 seats. |
#18 |
#Crush It
![]() Pictures of the oil cooler setup.
![]() ![]() ![]() ![]() Oil feed for turbo, oil pressure sender, and the oil cooler lines. ![]() Oil feed is a 45° AN adapter for the tight clearance. ![]() Thin jam nuts for the valve cover hidden underneath brass acorn nuts. The acorn nuts are so soft they are basically hand tightened. Looks good though. ![]() Fuse/Relay board under the glove box. Still needs a little better cable management and tidying. ![]() Main power is fused right off the B+ junction ![]() AMM relocated to other side of the engine bay ![]() Had to modify the firewall slightly for the LH harness. Unplugged because the exhaust and O2 sensors are off the car right now. ![]() 5 wires to make the Harness work ![]() Here's the junkyard MR2 seat. I wouldn't recommend swapping these seats. They're essentially backwards of the 240 seats and required a lot of extra fabbing, cutting, and drilling to make it fit. I've only done the driver's side so far and it's really sturdy. I added extra reinforcements to keep them safe. ![]() |
#19 |
#Crush It
![]() Microsquirt and PNP harness came in the mail yesterday. New flowmaster muffler came. V band and flex joint come today.
Had a little trouble installing the RX-7 calipers. I didn't realize there was two version of the 940 rotors. They're kinda like the 302 mm rotors on P80s. The brakes threw me off because the'yre different for 75-77. So instead of undoing the soft lines just reuse all the lines and use the old line in the new caliper. After that is the getrag swap to tackle. |
#20 |
Reformed SAABaholic
![]() Sure hope all of your crimped electrical connectors last long term..... I converted to the " crimp tinned copper connector, solder, heatshrink" as per the gospel of MADELECTRICAL.com. Guy with 40 plus years building harnesses and upgrading vehicles to EFI, racing background. I think you can download his "how to make connections" for free.
More time consuming for sure, but long haul reliable. Carry on, I like the MR2 seat! |
#21 |
#Crush It
![]() I work with a lot of electrical connections at the Ford plant and have started using the modern OEM crimp connectors a little more. The multi pin latching connectors with weatherpack seals. They're not too bad time wise to put together and are a little more pricey but they work really well and are good for servicing. Otherwise I try to avoid as much crimping, cutting, or modifying of any harnesses I can.
#22 |
Reformed SAABaholic
![]() The weatherpack design I've read is designed for 50 connect/disconnect cycles total.... way more than enough for our needs.
#23 |
![]() Join Date: May 2007
![]() Brnbrn, did it to 184 whp with the ported head?
#24 |
#Crush It
![]() Yes
#25 |
#Crush It
![]() Everything with the "phase 1" was the 184 hp
