Old 04-12-2018, 12:42 PM   #1
745T+
745T+'s Avatar
Default Electric Power Assist Steering (EPAS) in P1800
One of our members, Volvero, made this power steering conversion in a 1970 1800E. I shipped the Electric Power Assist Steering parts to him in Santiago, Chile. The EPAS parts are hidden under the dash.
745T+ is offline   Reply With Quote
Old 04-12-2018, 12:56 PM   #2
CAPT_BLOTTO
#Crush It
CAPT_BLOTTO's Avatar
Wow! Is the EPAS from an existing vehicle or is this more like an aftermarket "universal" part?
Hello My Glorious!
Old 04-12-2018, 01:10 PM   #3
745T+
745T+'s Avatar
I deal in used EPAS units from Saturn Vues. Chevrolet Equinox, and Pontiac Torrent. They require an electronic adapter to send a simulated electronic speedometer signal to the EPAS unit. The level of assist is adjustable. The used units require adaption into the existing steering column. I sell cores to http://www.epowersteering.com/index.html. Ken makes really nice kits from the same basic EPAS units, but the cost is higher.
Old 04-12-2018, 01:15 PM   #4
volvero
volvero's Avatar
745T+ is the man, he sent everything I needed, the electric motor, column couplings, control unit, potentiometer, etc. The installation requires welding and creativity but the effort is really worth it.
850 Turbo '95
M56 swaped, Rica tune, 16T turbo, angled flange, 3" downpipe, IPD swaybars, 302 mm brakes.
PV544 '61 (B20, R cam, twin Solex C.45 DDH carbs, FI head, electronic ignition, 122 disc brakes, IPD front swaybar)
http://forums.turbobricks.com/showth...=1#post4398485
volvero is offline   Reply With Quote
Old 04-12-2018, 01:46 PM   #5
MDVLN
Kapitän Klugscheißer
MDVLN's Avatar
That's pretty crafty boys, nice stuff.
Old 04-12-2018, 01:56 PM   #6
culberro
culberro's Avatar
EPAS is becoming a really popular swap in rally cars. Quick manual rack and EPAS is reasonable inexpensive for most cars.
Old 04-13-2018, 11:36 AM   #7
Kjets On a Plane
Devoid of Luxury
Kjets On a Plane's Avatar
How PSI a stock can support?
Always Be Crushing!
Old 04-13-2018, 03:50 PM   #8
Tfrasca
Tfrasca's Avatar
That's really tidy. I agree with Kjets; the manual steering on my 140 is by far its worse feature. I thought I counted almost 4 turns last time I had the front in the air.
Old 04-13-2018, 04:07 PM   #9
4.15 for 140's actually. 1800's and 122's are 3¼.
Old 04-13-2018, 04:59 PM   #10
Tfrasca
Tfrasca's Avatar
That makes sense. I'd love to address that at some point. This looks like a possible option.
Any idea what the current draw is on one of these?
Old 04-13-2018, 07:40 PM   #11
745T+
745T+'s Avatar
With the key on, and no steering effort, the electronics require fractions of an amp. This unit is usually fused at 50-60 amps, and the fuse never blows from steering use. The amps required will be dependent on load. The power to the motor needs to be connected directly to the battery. Under heavy load the battery supplies current if the alternator can't keep up. The motor draws current only under steering load. Under steering load, the motor is silent.
Old 04-24-2018, 07:14 PM   #12
Brandonium
Definitely interested in something like this on my 142e as I will be running 235's. Did you install a dial or switch to adjust sensitivity? Would be nice to see pics of where the welding and required modifications are.
2016 Toyota 4Runner Trail Premium
1971 Volvo 142e
1977 International Scout II
Wish List
Saab Sonnet III
1979 Toyota Landcruiser (FJ60)
Whatever else tickles my fancy.
Brandonium is offline   Reply With Quote
Old 04-25-2018, 04:08 AM   #13
Janspeed
understandable.
a hydraulic setup robs power from the crank even when the car drives straight.
Also, stock hydraulic powersteering setups do not like sustained high revs, the hot oil tends to trap airbubbles. i have seen this happen on a 740 rally car. Hydraulic assisted racks also seem to resist really fast steering inputs.
yeah, you could instal an underdrive pulley and an oil cooler but having an EPAS seems to be the better solution.
Old 04-25-2018, 04:51 PM   #14
LloydDobler
LloydDobler's Avatar
I'm not ready yet but I definitely want to do this in my 122.
'66 122 - Collectible project
Old 04-25-2018, 05:08 PM   #15
745T+
745T+'s Avatar
A potentiometer is used to adjust the amount of assist. Most people set it and forget it, but you can adjust from full assist for parking, no zero assist at highway speeds.
Old 05-30-2018, 06:50 PM   #16
Harrison
Question Electric Power Steering
I read that we can install Ford Focus 2012-2015 electric rack and pinion assembly on the Amazon.
Do any member know of such information. If true, it will be a major saving than using the ez power unit.
Harrison is offline   Reply With Quote
Old 05-31-2018, 03:40 AM   #17
mck1117
The focus is a rear-mount rack, behind the front wheels/subframe. This means that if you put it in front like on a Volvo, it will go the wrong way. Turning right on a Volvo rack makes the left tie rod shorter, and on the Focus rack it will make the left tie rod longer.
Edit: oops, the steering arms are behind the axle on the Amazon/1800. The above only applies to 2/7/9 which have the rack in front.
mck1117 is offline   Reply With Quote
Old 05-31-2018, 03:18 PM   #18
They're boxy but good!
The guy with the super nice 240Z at autocross put the Saturn/torrent one with the kit on his car. Said he has it set at 1/4 and it's plenty of assist.
Me for President
First candidacy driven entirely by smart phone.
Campaign slogan
"Trump, I wouldn't piss on him if he were on fire!"
Old 05-31-2018, 03:32 PM   #19
Cwazywazy
Single jingle
Cwazywazy's Avatar
How's the steering feel though? My only experience with EPAS is in a RAV4, and it sucks.
I don't know what I have
Old 05-31-2018, 03:46 PM   #20
89_740Turbo
89_740Turbo's Avatar
Well, this is probably one of the niftiest things I have seen. A++ for creativity and implementation!
Imagine all of the p1800 owners out there who have no idea this exists
Old 05-31-2018, 04:14 PM   #21
Brandonium
I believe there are other factors at play here such as the Rav4 having ****ty overall steering feel to begin with. EPAS in various vintage make/models should not take away that steering feel if you have it dialed so that it mostly assists at lower speeds. I would not want any EPAS system to assist my 142 at any speed over 15MPH it's only that slow speed parking lot BS that gets to me.
Old 05-31-2018, 04:30 PM   #22
Cwazywazy
Single jingle
Cwazywazy's Avatar
Yeah, that's what I was thinking. The Yota's steering is completely lifeless and indirect feeling.
Old 05-31-2018, 04:31 PM   #23
cwdodson88
122/1800/142/145 all front steer. Sure you can flip the arm on the back of the spindle, but factory is front.
The Build Thread
SVEA - PUSHROD TURBO!
Old 06-01-2018, 09:38 AM   #24
Brandonium
True! And I feel you could get yourself into trouble if you have too much assist at faster speeds. Feedback from the road and how the vehicle handles tells me how we are doing road vs car wise and having that feeling removed could put you in a ballsy situation you're not really prepared for.
