laziest worldwide
![]() This story starts back in 2005 when I got my first full time job as a CAD designer. I worked for several months on a twin turbo kit for the 2005+ Mustang GT, with twin GT2860RS (Disco Potatos) added to the base V8 car to make something that would compete with a Cobra. I designed the exhaust manifolds, downpipes, and was working on charge plumbing to & from the intercooler when the kit scope changed and it was decided that this was as far as it would go. Originally the idea was a complete solution with tuning and everything, but the version that got sold to the public was a "tuner kit" with exhaust side parts and turbos only, including oil and water lines.
![]() ![]() The de-scope was a bit of a letdown for me but I was able to drive the development mule car extensively and was amazed by the power. It made 490whp at <10psi on a Dynojet with this system, plus recalibration of the stock ECU, fueling upgrades, larger throttle body, and deletion of the tumble valves in the intake tract. You would just barely think about touching the throttle and the rear tires would haze. I learned how to keep the car under some semblance of control and had a great time helping develop the kit and taking data. More than the average CAD designer got to ever think about. I ended up in an aftermarket performance application engineer position a few years later but by that time the kit had mostly run its course. ![]() ![]() I was pretty proud of the exhaust system design. The manifolds were reverse engineered from the original Ford geometry, and the downpipe outlets are located precisely where the original manifold flanges were. This means any OE or aftermarket exhaust system designed for the stock manifolds would also work with the turbo kit. In 2010 or 2011 there was still a SEMA display engine gathering dust at work, which had the turbo kit installed. It had not seen the show circuit in several years but was intact and seemingly forgotten. How does this relate to Volvos? Well I was able work out a deal and take the engine home, with nefarious plans in mind. The mule car still exists but this is not the engine from that car; it was only ever used as a display engine for the kit. ![]() Good news is this is basically a zero-mile 2005 3-valve 4.6. It was bought by my friend in marketing from a dismantler in late 2005 or early '06. The story was the original car was out on a test drive when the prospective customer wrecked it. Car got parted out, including the super fresh V8. Here it sits almost 13 years later. Still fresh. ![]() In 2014 I found a 1984 Diesel 245 for sale up in Olympia Washington on craigslist. Diesels are the only post-1975 240s that are smog exempt in CA, meaning engine swaps are feasible. Poik (Eric) offered to check out the wagon in person for me since he was much closer, and reported back its condition. I agreed to buy it sight unseen, sent a deposit, and planned to pick it up a few weeks later when I'd be up in Seattle anyway. Alex Buchka offered to help me drive it back so we made it an interesting 75hp road trip all the way from Seattle to LA over 3 days. I put up this thread about the trip: http://forums.turbobricks.com/showthread.php?t=301120 ![]() The wagon got driven around here and there but the plan all along was to put this 4.6 in it. Diesel got pulled in late 2015 and has been around the block a few times since then. The car, however, hasn't gone much of anywhere. It has mostly been in my garage. At some point I thought that if I left the engine close enough to the engineless shell it would start to assemble itself, but no such luck. ![]() I pressure washed the engine bay and successfully got rid of most of the diesel oily shmutz. It still has some in the tank though. ![]() ![]() Update April 2019: plans have changed! The donor car is now my '75 245 pea green survivor car that I've been putting around in for a few years, rescued from a field in Colorado by Luke (122power) in 2015 or so. Pea Green Survivor thread here: http://forums.turbobricks.com/showthread.php?t=327998 ![]() ![]() The blue car lives in SFO now with my friend Nate; it's now getting a single-turbo LS swap. His build thread is here: http://forums.turbobricks.com/showthread.php?t=348446
laziest worldwide
![]() A few weeks ago I did the first fit-try. Front end of the car came apart and I pulled the brake booster. Then plucked the engine off of its display stand and removed the turbo kit and oil pan. I took some measurements a long time ago which told me the pan would interfere with the crossmember, and the left valve cover would foul the booster.
Spoiler alert; both of these things were verified. ![]() ![]() ![]() The sad part of this whole deal is that there's no way the Mustang turbo manifolds or downpipes will fit in a 240. Mustang engine bay is much wider and there's a huge space behind the passenger side shock tower for the right hand turbo to live in, where the battery was originally in that car. No dice on a 240. So my nifty castings and pipuses will have to get hung on the wall or find some other silly use somewhere. I think the turbos will have to live just ahead of the shock towers in this car. Good news is that the passenger side header/manifold will be pretty straightforward. Lots of room for activities. ![]() Driver's side will not be so easy. Steering shaft is quite close to the exhaust ports on this side. Not to mention the booster thing. I'm considering hydraboost, but I've also heard tell of electric boosters and might investigate that angle. ![]() Master cylinder is just hanging out for now. ![]() ![]() The 4.6 oil pan has a radiused edge as the front shallow section drops down into the sump. Rear sump, which is nice, but the pan will need a notch cut out and a squared-off patch welded in. Should be fine. When I pulled the pan, I found out this engine is missing the oil pickup tube. Must have been removed for SEMA prep long ago. Good thing I never tried to start it! ![]() 2x4 engine mounts are spacing the block up off the crossmember for now. The pan may also need a clearance hump for the steering rack. And I haven't even tried fitting the hood yet. Might need subframe spacers to create a little more breathing room. Last edited by Duder; 02-28-2021 at 03:12 PM.. Reason: relinking images |
![]() That's a WIDE engine! Is this because of the V angle of the 4.6L?
Nice project though! This thing will be a blast! We're you able to weight the engine at some time?
![]() 1990, Volvo 740 16v +T 1991, Volvo 745T 16V - crushed build thread: http://forums.turbobricks.com/showthread.php?t=249553 |
#4 |
![]() No - 90 degree V8 just like most of 'em -- but the overhead cams make the heads that big.
'82 242 6.2L; '17 Mazda3; '16 CrossTrek |
#5 |
An Anomaly
![]() Interdasting. Proceed.
1994 945ti | 15g @ 15psi, Turbosmart EBC, AEM Failsafe WB, 3"/2.5" exhaust, do88 intercooler, iPd cam, STS cam gear, Ostrich LH tune, sbabbs EZK chip, green giants, K&N, Yoshifab CCV/Can/Cap, iPd SS brake lines, TME, Eibach, BNE, Koni suspension, iPd sways, iPd panhard, TME upper/CT lower braces, forged BBS RG-Rs, Michelin Pilot SS, ecodes, V90 bits. 1985 744ti | 13.8 @ 100.5 mph - Sold after 20 years. ![]() |
#6 |
![]() Join Date: May 2004
![]() Neat!
I don't live in Cali so no clue, but is there any chance the car could get flagged and brought in for smog (and failure) in the future? I assume you got it inspected and registered initially as a diesel, but is it a 'wink and a nod' type deal from there on out?
#7 | |||
laziest worldwide
![]() Quote:
Acknowledged. Will do! Quote:
#8 |
![]() Join Date: Jul 2009
![]() Man that turbo kit is sweet! I'm really looking forward to this!
1974 AMC Gremlin, lq4, 7875 billet, ss2 cam, 80e, 3600 stall converter, Holley Terminator x 1984 Volvo 245 Om606td, 722.6, Lifted 1992 GMC Typhoon 1995 Porsche 993 2013 VW Passat TDI |
#9 |
laziest worldwide
#10 |
![]() It’s been forever since someone has tried to stick a 4.6 in.
Daddy like.
'00 XC70 SE - Slow '11 XC90 V8 - Torque Monster ‘12 Mazda5 - Work Car ‘06 E350 Ambulance - Work Car |
#11 |
8v are still cool, right?
![]() Love this. What's with the painters tape checkerboard?
1982 242 Turbo. |
#12 | |
laziest worldwide
![]() Quote:
I was wondering if someone would ask about that. Reverse engineering the 240 engine bay using a Faro arm (Alex's). We took points all over the engine bay and got all of the bolt holes, mounting surfaces, pierce points for the steering, etc. Concentrated more points on the right inner fender to build a surface model there using the grid of tape. It turned out pretty slick and I'm using the bay model to help with my engine mounts and general packaging strategy. |
#13 |
#14 |
laziest worldwide
#15 |
#16 |
dude
![]() Ls destroyer. Sweet build.
#17 |
laziest worldwide
![]() Actually I made a errorz. It was a Romer arm. Owned by a proper Swedish company, not that Floridian FARO stuff!
#18 |
laziest worldwide
![]() Well at the least, it'll be a tire destroyer. Maybe transmission too. I'll post up some details about the trans that I have for it. Looking at this as more of an experiment in budget speed, and if it blows up, then I'll scrounge some coins for a TKO-600 or something.
#19 |
Chubfest 2009 Survivor
![]() Join Date: Nov 2002
![]() Looking forward to this. As much as it pains me as a historically anti-ford guy, I think those v8's are the best sounding ones for domestics out there right now.
Hank Scorpio is from the Simpsons. You can call me Doug ;) Will trade guitars/guitar parts for go fast goodies or stuff I need. Just PM. www.kauerguitars.com the second best way to upset neighbors and alienate people. History: Car 1 (242) | Car 2 (t5r) | Car 3 (255) |
#20 |
dude
![]() There was a 242 at ipd two years ago with a dohc in it. It was tight in there.
#21 | |
laziest worldwide
![]() Quote:
This one isn't quite as tight; the 3-valve leaves a bit more space. I may need to offset the whole thing a little towards the passenger side to clear the column though. |
#22 |
#23 |
![]() It's super cool to see something a bit different. And the turbo kit you designed looks great!
#24 |
![]() You might get a bmw e32 or e38 relocated brake booster to work.
#25 | ||
laziest worldwide
![]() Quote:
![]() Quote:
Cool; thanks for the tip. I'll check into that. |
