Old 06-05-2018, 01:50 AM   #1
Brotkasten
Jonas
Brotkasten's Avatar
Default 945 b230fb+t
I bought my first car and Volvo in 2017 when I was 19 y/o.
1991 945 B230FB with 215.000 miles on it and already installed perfect condition 740 seats and a
KAW Pluskit suspension.
Finally I want to get this thread started! Already lost a lot because I often dont think about taking pictures...
Before putting on the turbo I did the following:
Measured compression, Changed the headgasket and inspected the engine from inside, checked the valve timing.
What's done:
Suspension:
- CMS C4 17" Alus / Peugeot 17" Steelies with 25mm spacers
- KAW Pluskit suspension
- DIY Strut brace
- Lower Turbo Brace
Engine:
- TD04H 13C Turbo (FK Version for now)
- Catchcan install
- Turbo ECU
- Big turbo radiator
- Air oil cooler
- V70 Injectors
- Stock intercooler
- Turbo rebuild
- Wasted Spark conversion kit (BTI)
- HKS SSQV BOV
Gearbox:
- M90 Gearbox
- Single mass flywheel
- Diesel clutch kit
Interior:
- 940 early leather seats
- Custom center console
Exterior:
- Roof rack mounted
- Fog light install
- Turbo grill
Electric:
- Keyless Entry system added
- Gages and Lighting
What I'm going to do:
Interior:
- Redo hanging headliner
Cant really post more images atm. For more you can visit me on Instagram @jag.rullar
Old 06-05-2018, 03:33 AM   #2
Brotkasten
Jonas
Brotkasten's Avatar
I cleaned the crankcase breather box yesterday.
The removal and installation was easier than i thought.
Before the +T I noticed oil leaking out of the oil cap from time to time. After the +T there was a bit of blue smoke for 1-2 seconds sometimes (on a really hot day), but no oil leaking out of the oil cap.
I just hooked up the garden hose to the outlet. It all shot out in a matter of seconds! Probably has never been cleaned. I then flushed it with diesel and left it to dry in the sun.
There was no blue smoke at all on a two hour drive and the idle is much smoother (I could just imagine it).
Old 06-05-2018, 03:40 AM   #3
MrKrabs
MrKrabs's Avatar
Beautiful car man! Black on black looks nice
MrKrabs is offline   Reply With Quote
Old 06-05-2018, 05:03 AM   #4
way2kool
Used
way2kool's Avatar
Sweet looking ride; nice work!
1989 744TI M46
way2kool is offline   Reply With Quote
Old 06-05-2018, 08:05 AM   #5
Brotkasten
Jonas
Brotkasten's Avatar
This is under the hood:
Old 06-05-2018, 08:33 AM   #6
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
your front pos light isnt working ;)
Old 06-05-2018, 08:37 AM   #7
Brotkasten
Jonas
Brotkasten's Avatar
Was not working ;) pics are old
Old 06-05-2018, 09:06 AM   #8
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
so,, you keep us posted with old pics?! brrr :D
Old 06-05-2018, 09:21 AM   #9
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
I am into the black on black look, but that fan without a shroud made my fingys hurt
1980 242 Turbo
2004 V70R
Old 06-05-2018, 09:28 AM   #10
Brotkasten
Jonas
Brotkasten's Avatar
I'll probably delete the fan anyway. So you can pad the engine without breaking your fingers! Just watch out for that timing belt.
Old 06-05-2018, 09:35 AM   #11
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
Minty fresh. Good work
2010 Porsche Cayenne S - My ride - 99k stock
2010 Cadillac Escalade ESV - Wifeys ride - 205k stock
2007 Audi A4 3.2 M6 - daughters ride - 166k stock
2006 Volvo XC70 Wagon - sons ride - 175k stock
1992 Volvo 965 - "Savage Wagon" w LS 5.3 LM7 + LS7 cam + GM T5 swap in progress.
1979 Porsche 911SC - stock
1948 Spartan Mansion travel trailer - aluminum greatness
Old 06-05-2018, 05:04 PM   #12
Brotkasten
Jonas
Brotkasten's Avatar
Installed the oil cooler today.
It's a cheap (160$) ebay one with a thermostat set to ~80°C.
The cooler itself looks and feels to be of really high quality!
The sandwich plate came with a 3/4" extension the the filter thread. To gain clearance with the motor mount I had to use a OC606 oil filter (thank you MadDog!). If your oil filter is relocated there is no reason for that.
The hose was a bit short (40") so my mounting has to wait until I get extensions.
Conclusion:
The water temp gauge stays a tiny bit upfront the middle position while cruising. On load it centers and then quickly returns when off load.
Old 06-05-2018, 05:34 PM   #13
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
noice!
get your dustshield installed again.. cheap at skandix!
Old 06-06-2018, 05:28 AM   #14
Brotkasten
Jonas
Brotkasten's Avatar
I'm thinking I could maybe even repair the broken one...
It looks rat without one tho
Old 06-06-2018, 05:20 PM   #15
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
and it functions rat without one.. even worse when you have no belt cover
Old 06-07-2018, 06:08 PM   #16
iHateVolvoPeople
Hey man looking good! Quick question, is that oil cooler a direct bolt on to the block, have a link to it? My car is in need of a cooler bad..Wondering if it'll clear the mount on a 240 with the big mann filter. I was worried about a universal oil cooler not having the correct length and thread pitch bolt for the cooler>block.
Feedback Thread
Current:
'93 244T M47
'95 Camry A140E, 254k
'99 Camry A140E, 256k
Old 06-07-2018, 06:50 PM   #17
Brotkasten
Jonas
Brotkasten's Avatar
The oil filter has a 3/4" thread. My kit (as most of them) had that sized thread extension . You will need the OC606 filter if you dont have the relocation mount that turbos have.
Old 06-07-2018, 07:02 PM   #18
Brotkasten
Jonas
Brotkasten's Avatar
Found the link.
It's a German seller tho.
https://rover.ebay.com/rover/0/0/0?m...2F222869588132
Old 06-08-2018, 03:29 PM   #19
iHateVolvoPeople
Thanks man. I think it’s different on a 240 mount but I’ll have to look.
Old 06-09-2018, 04:40 PM   #20
Brotkasten
Jonas
Brotkasten's Avatar
For the record: The left on is the old ecu and the right one the new turbo one. Works perfect!
Old 06-15-2018, 02:56 AM   #21
Brotkasten
Jonas
Brotkasten's Avatar
I have the opportunity to get 4 25mm 5x108 spacers really cheap along with some 17" steel rims and Volvo original hub caps.
I think my black Hydras w/o hub caps and 25mm spacers would look nice
I will post some pics once i picked them up in Bielefeld (if that town even exists) later this weekend!
Old 06-15-2018, 05:12 AM   #22
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
haha.. the set from ebayklein? ;)
Old 06-15-2018, 05:14 AM   #23
Brotkasten
Jonas
Brotkasten's Avatar
Yes The spacers alone make up for half the price
Old 06-16-2018, 06:06 PM   #24
Brotkasten
Jonas
Brotkasten's Avatar
I got the wheels:
I will have to repaint them and get some new bolts.
Old 06-16-2018, 06:42 PM   #25
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
nice big hubcaps would look awesome to it.. but for my taste they need more bed ;)
