¯\_( ͡❛ ͜ʖ ͡❛)_/¯
![]() A little over a year ago I bought my 1993 945 Turbo
It was my first car and something that I had long waited to buy while I was in school. Now that I was graduated and had my first big boy job lined up. I needed a way to get there and back each day. The previous owners had taken taken very good care of it since they bought it in 2000(2 owners previous to them). They originally intended to use the car for a short amount of time, but loved it so much that they decided to keep it around. the last couple years of their ownership they used it very little and decided it was time to let poor Putt putt(their name for it) go. At 287,000kms it was super clean, Essentially no rust except for the cowl (Excuse the "glowy" image quality, they will get better) ![]() ![]() ![]() ![]() ![]() First Work I did when I got the car -Full brake job ![]() -New Ball Joints ![]() -Replaced broken indicator light ![]() ![]() -Resolved some issues with the tail light wiring -The cabin fan was fill of leaves... so I cleaned that out ![]() -Used these wheels with spacers for a bit ![]() -Picked up the TSW Blade wheels for $100 ![]() At this point I was getting antsy for some performance mods and began slapping a few of those on throughout the summer I will start posting those in the next update |
¯\_( ͡❛ ͜ʖ ͡❛)_/¯
![]() I’m Going to try to Summarize everything I did from a year ago (June 2017) until October 2017 in this post
Unfortunately most of the photos are crap because of my camera so you'll have to bear with me until I get to more recent work with slightly better photos I was getting sick of the stock crackly radio, so I went ahead and installed a nice pioneer deck and to fit it into the stock radio mounts I designed and 3D printed a custom bezel. Unfortunately my print quality wasn't the greatest, but I was too lazy to spend the 8 or so hours to reprint it. ![]() I can make the 3D file available if anyone would like it Before I got to messing around with upping the boost I put in a boost gauge ![]() with an enclosure I also designed and 3D printed From there I went straight to putting in a simple mbc and raising the boost to 12psi This added some much needed power and made the car a blast to drive. Especially being the first turbo car I had ever driven. I drove it like this for a few thousand kilometers and in that time did some basic maintenance, such as a coolant flush, replaced the fuel filter, synthetic oil and filter also put in new spark plugs and a cold air intake for added whooshing noises. The timing belt was last replaced in 2005 at 214,000kms so with the age alone I figured I should probably replace it. I was also sitting at 295,000kms so it was about time either way. ![]() Also splurged a bit and threw in an IPD Turbo camshaft ![]() Figured now while I was doing the timing belt was as good a time as any ![]() I could immediately tell there was a difference after putting in the camshaft giving me much more high end torque. The engine no longer sounded like it was about to explode above 4000 rpm At this point I had been using my car everyday on my 90 km commute to work for a couple months and was getting pretty tired of the body roll from the stock suspension. I knew this car was something I was going to keep for long time and decided I was okay with putting a little more money into it. After a little saving I bit the bullet and invested in some BC Coilovers. I know they aren't the first choice of most turbobrickers, but they were the easiest to get in Canada and I wanted the adjust-ability. ![]() ![]() It wasn't until they arrived at my door and I opened the package that I realized the front coilovers needed to be welded the the existing knuckles. I didn't have a welder, so this was a slight issue. Lucky for me Canadian tire had their "MasterCrap" brand welder on sale for 60% off so I picked one of those up for a couple hundred bucks and began teaching myself a skill that I had been wanting to learn for a long time ![]() It is a pretty easy welder to use and didn't take me long to get the hang of it. when I felt ready I decided to go ahead and install the coilovers. Doing the rears only took about an hour but the fronts was a full day and a half job. ![]() Really wish I had taken more pictures of the process ![]() Unfortunately I don't have anymore pictures of it right after installing the coilovers....because 2 minutes into My test drive I broke a tie rod end that most have been weakened during the install. This sent me out of control on the wet road and had me drive directly into a curb, where my freshly lowered car hit subframe first deploying the airbags (which did nothing but burn the crap out of my forearms) and did a 180° jump off the road and onto the grass next to it. Here’s the aftermath. The direction that the car is facing is where is was coming from(****ty arrow to illustrate). I hit the Curb hard enough to spin a full 180 ![]() No more than 50 meters up the street someone crashed their bently into a pole within about 10 minutes of my accident. So that made me feel a little better about it(unfortunately didn’t get a picture of this) Here's the damage With my luck, I managed to wreck 3 of my 4 wheels from hitting the curb ![]() ![]() This one got it real bad ![]() ![]() ![]() Here's the subframe where the brunt of the hit was taken (you can see the detached tie rod in the foreground) ![]() so yeah... not good at all ![]() I don't have a picture of this but one of the places where the high pressure line for the steering rack attaches broke right off. I couldn't drive the car so I had it towed the 800meters home. At this point it was the end of October, the weather was getting colder and I didn't have a place to work on the car indoors and I needed a way to get to and from work. So I put off fixing it and decided to buy a cheap reliable car that I could depend on for my long commutes throughout the winter. I swallowed my pride and bought this boring 2005 Base model Matrix with 150k kms on it. complete with manual windows, manual locks, no AC and a manual transmission. ![]() And there my Volvo sat for the winter being no more useful than a brick ![]() |
Våga Vägra 8V
![]() awww man.. that sucks... but nice car.. 93 is best year!
#4 |
¯\_( ͡❛ ͜ʖ ͡❛)_/¯
#5 |
der Junge
![]() Son of a punk rocker, suck to have that happen!
Glad to hear you're getting the parts together for more fun, can't wait to see what plans you have for old Putt Putt. And keep it up with the 3d printing. On that faceplate it looks like your printbed wasn't leveled properly, otherwise cool idea.
- 1989 745 16v - 1991 744 (SE) 16v Turbo |
#6 | |
¯\_( ͡❛ ͜ʖ ͡❛)_/¯
![]() Quote:
Hope to have the thread all up to date soon Yeah that's exactly the problem I had with the print. Just sucks that I didn't notice until after it completed. Hope to reprint it soon when I get a chance. But that is just another low priority item on my long list of things to do |
#7 |
¯\_( ͡❛ ͜ʖ ͡❛)_/¯
![]() Picked all this Junk up for 200 Canadian shekels today
![]() ![]() ![]() ![]() Items include -Strut Brace -IPD Chassis Brace -760 23mm sway bar and poly bushings -Fuse panel with fuses -2 Mann oil filters -Snow Cap/Cover -Complete tool kit -940-960 parts catalog -Recall fix battery lead -Bits to turn my non working electric sunroof into a manual one -Mint condition ash tray (mine is a little melty from fuses) -Driver side seat pocket -Passenger door pocket -Little bit that goes around the seat belt opening Yeah...I think that's everything Quite pleased with this find ![]() Last edited by thessejway; 06-20-2018 at 09:58 PM.. |
#8 |
¯\_( ͡❛ ͜ʖ ͡❛)_/¯
![]() Does anyone know if having these mismatched control arm stay bushing on either side is going to cause a noticeable difference side to side?
#9 |
¯\_( ͡❛ ͜ʖ ͡❛)_/¯
![]() To get myself back into things after winter I started out with some little things here and there
Starting with the good ol' heat gun treatment to the black plastic on the exterior of the car What an easy satisfying difference this made! Testing it out in a not so hidden spot... ![]() ![]() Before ![]() ![]() After ![]() ![]() ![]() Unfortunately didn't work on the part that mounts to the car ![]() Before of the front ![]() ![]() After ![]() ![]() This really shows the difference ![]() As she currently Sits ![]() Got some much needed seatbelt button replacements off of IPD ![]() ![]() ![]() Brake peddle ![]() ![]() ![]() Going to get to this eventually ![]() Splash Guard has seen better days Going to model up a metal one this week and send it out for an RFQ ![]() Now have a complete tool set ![]() Hmmm...Probably not going to work ![]() |
#10 |
![]() Nice job getting the car back into shape and props to you for not giving up on it. I imagine that was discouraging to say the least. Bumpers came out nice!
check my feedback here |
#11 |
¯\_( ͡❛ ͜ʖ ͡❛)_/¯
![]() I managed to get an entire fron subframe and steering assembly from someone who was parting out their 940.
My plan was to cleaning it all up repaint it and get all new bushings in They were in relatively rough shape when I got them Started by taking a wire wheel to everything as I disassembled ![]() Some wire wheeling before and afters ![]() ![]() ![]() ![]() ![]() ![]() ![]() Spent hours trying to get the bushings out myself. Eventually I gave in and took it to a local shop and left it to the professionals. Coulda saved a whole lot of time if I just did that from the beginning. Priming ![]() One of the control arm stays was damaged in the process, so I bought a new one to replace it ![]() Painting ![]() ![]() So shiny ![]() ![]() Fini ![]() Got myself some new engine mounts ![]() ![]() Brought my control arms back to that shop to have the new bushings pressed in Was also entertained by some old guy mechanic banter ![]() While I was there the owner mentioned that they had a couple old Volvo in the back if I was interested Loved the colour on this 240 was in pretty rough shape though ![]() 443,000kms ![]() ![]() Then there was even a 940GLE with the 16v top ![]() 354,000kms ![]() Guess I've got a source if I eventually build up the courage to do the 16v swap ![]() May ask if I can take the lights. They're a little better than mine ![]() Got back home and reassembled everything ![]() Threw some poly bushings in there ![]() This was a proud moment ![]() Hopefully going to swap everything in next weekend ![]() My plan is to use an engine support bar to hold the engine up while I remove everything from underneath Any advice or recommendations? |
#12 |
Våga Vägra 8V
![]() cool job.. it is the next to do on my infinite journey MOTing the 16v ;)
How did you manage to get the front subframe out? Engine still in? Enginebridge over the fenders? Last edited by MadDog_945; 07-09-2018 at 04:45 AM.. |
#13 | |
¯\_( ͡❛ ͜ʖ ͡❛)_/¯
![]() Quote:
Would you say it was worth it? The new subframe is out of a parts car that had no engine, so my car still has the old one in it. Going to be using an engine support bar to hold up the engine while I swap the new one in this weekend. |
#14 |
Våga Vägra 8V
![]() no! dont do it!
#15 |
¯\_( ͡❛ ͜ʖ ͡❛)_/¯
#16 |
¯\_( ͡❛ ͜ʖ ͡❛)_/¯
![]() Going to attempt to fit an 850 wing
![]() ![]() May modify original brackets to mount onto my 940 ![]() Going to trim it to be a tighter fit ![]() Template to cut from ![]() Now I've just got to build up the courage to cut into it |
#17 |
¯\_( ͡❛ ͜ʖ ͡❛)_/¯
![]() Picked up these bad boyz a couple months ago
Epsilon Southern ways came as an option for older ferraris ![]() ![]() ![]() ![]() Currently working out what sized tires to wrap on them Front wheels are 16x7 ET20 Rears are 16x8.5 ET0 They fit super nice ![]() ![]() ![]() ![]() ![]() was thinking 205/55/16 on the front and 225/50/16 on the back Aiming for this sort of fitment ![]() ![]() Anyone with some good tire fitment knowledge able help me out? |
#18 | |
![]() Quote:
235/55/16 in back |
#19 |
¯\_( ͡❛ ͜ʖ ͡❛)_/¯
![]() I think those will be too tall
Also it's hard to find any 16" 235s Picked up a couple sweet 245/45/r16 yesterday for $50 still lots of life left in them ![]() ![]() Versus the tires currently on the car ![]() Going to get 205/55/R16s on the front Excited to see them on the wheels and on the car |
#20 |
¯\_( ͡❛ ͜ʖ ͡❛)_/¯
![]() Here's the old subframe, Obviously in very rough shape
![]() Used an engine support bar to hold engine up while I took the old subframe out ![]() one of the power steering hoses was completely broken off the rack ![]() We have lift off! ![]() ![]() ![]() ![]() Old is out, time to get the new in Huge improvement! ![]() ![]() The subframe was actually squashed around the steering rack ![]() ![]() ![]() Got too busy while mating the new subframe that I didn't get any photos of the process Was quite the task to accomplish on my own But here are some of the finished product ![]() ![]() Got the chassis brace in ![]() Engine Support bar safely off ![]() Back on the ground ![]() On bricks so that I can fit my jack underneith Would not have been able to finish this without this bad boy ![]() |
#21 |
![]() 205/55-16 on 7" wide ET 20 rims in the front with BC:s is a tight fit, but works. The tires almost rubs the BC strut/coil.
Also, that control arm washer seems to be on the wrong way. |
#22 | |
¯\_( ͡❛ ͜ʖ ͡❛)_/¯
![]() Quote:
Yeah it looks a little off, but the indentation for the washer is on that side. may still try it flipped the other way |
#23 |
¯\_( ͡❛ ͜ʖ ͡❛)_/¯
![]() So after installing my "new" steering rack, I noticed that the column was about 3/4" short from where it should be reaching
![]() I'm assuming this is because of the steering collapsed slightly on impact. Does this mean I'll have to replace that upper steering column? Or is there a way of re extending it? You can see here that the u-joint is pushed right up into the fire wall ![]() Against the fire wall inside the cabin ![]() Does anyone know if this sleeved section is where it collapses? ![]() |
#24 |
![]() Nice project!
#25 |
¯\_( ͡❛ ͜ʖ ͡❛)_/¯
