![]() Just raced in the Buttonwillow 24 Hours of Lemons road race last weekend with a CD009 (actually a JK400) attached to my relatively stock '85 745 with B230FT. Car ran all weekend and transmission setup worked great.
My Lemons car was a test bed for a bunch of stuff Yoshifab is working on. We had the Yoshifab prototype 700 shifter, driveshaft adapter, transmission mount, and clutch. We also used the Deeworks adapter to connect the M46 bell housing. We raced 14.5 hours, 224 laps, 560 miles, and 3,000+ shifts. We finished in 68th place out of 116 cars that actually turned laps. Out placement was mostly due to slow driving and leisurely pit stops. I was typically in 3rd, 4th and 5th gear, never needing 6th. With the M46 I was typically in 3rd and 4th and sometimes would get to the top of 4th. I don't have the boost turned up so maybe in will see 6th some day. Closer ratio for the track and the shifting was so much nicer. Josh at Yoshifab did all the designing and fabricating on this, but I am happy to answer any questions. |
![]() Join Date: May 2004
![]() Nice! I was surprised this weekend when someone said the CD009/JK4* has a 1:1 5th. Despite me having one, I'd never actually looked at the ratios, I just ASSumed it was like most other 6 speeds, 1:1 in 4th (or close), two OD gears.
What rear end ratio do you have? The 3.73 I have might end up being a bit too (numerically) high, especially with a turbo V8 spinning things. Hows the shifting feel? 1 piece or 2 piece? I was using a 1 pc on my previous T5, but was pondering a 2 piece for the CD009.
![]() I think the ratios are:
M46 Nissan 1 4.03 3.794 2 2.16 2.324 3 1.37 1.624 4 1.00 1.271 5 0.79 1.00 6 x.xx 0.794 I will need to compare my video of shifting on the same track between the M46 and Nissan to see if I was getting into the 5th gear 1:1 ratio faster than with the M46. I am not sure which rear end I have, but I think it is the 3.5, not the 3.7. Shifting was good. Much crisper than the M46. I don't know what a 1 or 2 piece is. JohnMC, aren't you putting one into a LS swapped 240? My shifter is further back than yours and attaches to the end of the transmission, not on top of that rectangular plate. |
#4 |
![]() 1pc or 2pc driveshaft?
#5 |
![]() 2 Piece driveshaft. Yoshifab supplied a custom front driveshaft that attached to my stock rear piece.
#6 |
#7 |
![]() Yeah, I left out 'driveshaft'. Awesome that Yoshifab is making the swap parts like that for the 7 series.
A 1 pc has some advantages (it's cheaper to have made) but clearance is a bit iffy with the whole length of it moving up and down. I guess it would be better with the CD009 since it's even longer than a T5? I'd have to assume that the shift lever action will feel different on mine since it's using a different setup, I just meant in general, going into gears. Fitting it into the 240 required that top mount shifter, I guess a short rear shifter would work great on a 7/9. How much tunnel bashing did you need to do? I have no idea if the tunnels are any wider on a 7/9. I had to make clearance on mine where the two sections of the trans bolt together, it's a LOT fatter than the T5/M47 was back there. And where those shifter detent springs are at the rear of the trans, a little more bashing there. |
#8 |
![]() Shifting was smooth like a modern transmission should be. Never any grinding, but we weren't hammering it between gears either. The prototype shifter I was using had a really short throw.
Josh said the 7/9 tunnel is a bit bigger than the 2, he didn't have to bash to hard on it to get it to fit. |
#9 |
![]() Pics of car needed.
'93 944 T - #TrophyVo '00 XC70 SE - Slow '11 XC90 V8 - Torque Monster |
#10 |
#11 |
#12 |
![]() This is great information, I was hoping some more would come out on the CD009. I plan on doing a CD009 swap into my my next project 240 wagon and understand there will be tunnel clearance issues and other modifications needed and pretty set on going with the CD009 even if it means cutting the tunnel out of a 7-9 series.
#13 |
![]() The bashing I did was not all that excessive. Part of what I did to limit the bashing, however, was *carefully* (obviously) take an angle grinder to some spots on the transmission where the clearance was tight, but there was some sort of non-functional chunk of the transmissions sticking out.
Also worth noting - the CD009 is just the last version of the CD00* transmission, by reputation the earlier versions are not really worth messing with - the syncros tend to fail. It was a mounting warranty issue, thus they finally redesigned it and may have overbuilt it a bit, resulting in the CD009. The only issue is... it can be really hard to tell a CD009 transmission from any of the earlier versions. There's a white sticker on it, but that's very commonly missing. 'Known' CD009 versions tend to sell for significantly more than a '350Z' transmission. The model year can help, but many early cars got warranty replacements, but even then, the warranty replacement might not have been a CD009. But the JK versions? They're *all* newer. You don't have to try to tell the lemons from the good ones. Anything from a G37 or a 370Z is good. I think there are some small differences in them vs. the CD series, the adapter I got (Collins) has a different kit for the two. Also, it may have changed by now, but when I bought mine (JK41c?) they were still selling for significantly less than the 'known CD009' boxes. Last edited by JohnMc; 10-01-2018 at 02:54 PM.. Reason: fixed |
#14 |
![]() You mean G37 or 370Z?
#15 |
![]() I did indeed. Bad fingers!
#16 |
![]() Mine came out of a 370z/G37. It also had the integrated clutch slave which was removed and the rev match module which we ignored. We also cut/grinded off some of the spots that were sticking out.
#17 | |
![]() Quote:
My JKxx is going in a 1990 740 along with a B6284t engine swap. I don't know if that setup will move the tranny in the tunnel either towards the front or the rear. Which part of the transmission demanded that you modify the tunnel in order to fit properly?
![]() 1990, Volvo 740 16v +T 1991, Volvo 745T 16V - crushed build thread: http://forums.turbobricks.com/showthread.php?t=249553 |
#18 | |
![]() Quote:
#19 | |
![]() Quote:
I plan on cutting the tunnel off where it hits and making it wider in that area. As you can see the rear of this transmission is pretty fat. ![]() |
#20 |
![]() They also make a shifter relocation kit so that you can have the shifter at the rear of the tranny.
https://www.youtube.com/watch?v=Z-0pZXw04r0 |
#21 | |
![]() Quote:
#22 | |
![]() Quote:
Yoshifab is making a shifter that will be in the same location as that for less. I have a prototype. |
#23 | |
![]() Quote:
Once I get a hold of a transmission and an adapter I'll figure out what needs to be done, but I have driven a 370z with a cd009 and loved it I think it will be perfect for my 16v turbo project. |
#24 | |
![]() Quote:
The rear gear on a 2008 Nissian 370Z is 3:54 so if you have the 3.5 it should feel much like the 370 I drove. It was nice it had a usable 1st gear. I am really curious how it will feel mated to a 3:73 set. Thats where I think I am going with it. |
#25 |
![]() This is what I'm doing for my 240 swap:
