Old 04-28-2019, 03:03 PM   #1
E10246
Default 1988 Volvo 240 Wont pass Smog (Smog certificate attached)
I have already replaced the following on my 240 (California Smog check):
Spark plugs
Distributor cap
All filters
Oil change
Mass Air Flow Sensor
Timing belt
The smog cert says Gross Polluter, Ignition timing (FAIL), Vacuum Hoses (FAIL) and the high reading of NOx.
Its not the catalytic converter right?
But my car wont pass smog. I have attached the picture of my smog papers. Please let me know what the problem could be.
E10246 is offline   Reply With Quote
Old 04-28-2019, 03:29 PM   #2
NotSoFresh
Sick ****** T-Brick Prick
NotSoFresh's Avatar
I bet its vacuum lines.
Old 04-28-2019, 07:05 PM   #3
E10246
The Vacuum lines I understand, but what about the ignition timing? how do I fix that?
Old 04-28-2019, 08:14 PM   #4
NotSoFresh
NotSoFresh's Avatar
Vacuum lines are the most basic form of engine management and is used in the ignition system to tell it if the engine is accelerating or decelerating for example. Vacuum is everything.
Old 04-29-2019, 12:04 AM   #5
E10246
Default RE: 1988 Volvo 240 Wont pass Smog (Smog certificate attached)
I'll tackle that first and let you and everyone first. cheap parts too!
Old 04-29-2019, 02:16 AM   #6
OttoB
First I would check fuel pressure.
Is that car with LH 2.4 or 2.2 fuel system?
What was that ignition failure?
Old 04-29-2019, 04:18 AM   #7
svxguy
svxguy's Avatar
Nox is the cat.. go to a muffler only shop to get a new one. I get mine replaced for like $250 max installed here in nor cal
1984 242 turbo sold to sweden
1988 740 turbo wagon white 300k
1992 volvo 240, 5mt flowmaster 17's Sold but bought back 3 years later . D.D
1986 volvo 240 beige - Sold
1994 svx luguna blue 03 wrx 5 speed. Totaled into a tree 😥
1994 svx black - Sold
1994 svx luguna blue -Sold
1992 svx pearl white -Sold
1992 svx Pearl white Junked
svxguy is offline   Reply With Quote
Old 04-29-2019, 04:12 PM   #8
Jake_NZ
Jake_NZ's Avatar
Is their a list/table anywhere that shows the expected vacuum levels at specific conditions?
'80 Volvo 242 GT / '83 Volvo 244 GLT / '87 Volvo 760 / '88 Volvo 245 Propcar / '89 Volvo 245 Propcar / '89 Volvo 245 GLT / '95 Volvo T5R / '04 Volvo S40 2.4i
Jake_NZ is offline   Reply With Quote
Old 04-29-2019, 11:26 PM   #9
speedn_j
Banned
My 88 failed like that then I put a new cat on. Smog emissions numbers barely registered after the 2nd test
speedn_j is offline   Reply With Quote
Old 04-30-2019, 08:04 PM   #10
philski o'flood
philski o'flood's Avatar
seen this many times before on 85-88 240s with Chrysler ignition...
the diaphragm in the ignition ECU (passenger side fender area) is leaking and your ignition timing is too far advanced
plug the vacuum line elbow to the ECU with a small bb and then put it back in to the ECU and your timing will be normal and NOX will drop massively.
You need to fix whatever they said was defective.
Your O2 sensor been replaced lately? Did you warm your car up before the test and did they test it warm?
philski o'flood is offline   Reply With Quote
