Old 06-09-2019, 05:18 PM   #1
940 16 valve
940 16 valve's Avatar
Default Motronic 4.4 waiting questions - RWD swap
Thought I would cross post this from my build thread:
http://forums.turbobricks.com/showthread.php?t=341191
I've got the engine in, and everything wired to the M4.4 ecu but fuel pump and O2 sensors. The piece I'm stuck on is wiring the fuel pump relay, and the purpose of wires B19 and B27.
Sounds to me like B27 should trigger the relay, but then what is B19's purpose. The stock 4.4 fuel pump relay is just a simple 4 prong relay.
1991 940 - stock b234+t -retired http://forums.turbobricks.com/showthread.php?t=243308
1989 760 - T5 +T5 swapped http://forums.turbobricks.com/showthread.php?t=341191
940 16 valve is offline   Reply With Quote
Old 06-09-2019, 06:10 PM   #2
If it is a simple four contact relay. One terminal is 85 and the other is 86 which is the control side of those relays. Since B19 is battery voltage and B27 is half that and according to the notes is a 42hz ac voltage. B19 should go to terminal 86 and B27 would go to terminal 85. That would let the ecu control the fuel pump.
Terminal 30 would go to the power supply and fuse. Terminal 87 would go to the fuel pump.
However, I an not a motronic expert. Just trying to interpret what you posted.
Old 06-09-2019, 09:11 PM   #3
bmdubya1198
You'll have to check a wiring diagram to see exactly which terminals to wire those pins to. I believe all M4.4 diagrams should be the same, let me see if I can post a pic of the ECU wiring.
2000 V70R Venetian Red/Black M56 swapped
2003 S60 2.4T Silver/Black
1992 245 Base White/Beige
1998 V70 GLT Black/Beige- Parts car
1991 944 Turbo Dark Green/Beige- Sold
1993 944 Base Beige/Beige- Sold
2000 S70 GLT Mystic Silver/Taupe- Sold
1998 S90 Silver/Gray- Sold
1988 744 TI M46- Sold
1995 854 GLT Auto- Crushed
2001 S60 2.4T Black/Black- Sold
bmdubya1198 is offline   Reply With Quote
Old 06-09-2019, 09:21 PM   #4
bmdubya1198
Looks like B27 goes to 31B on the relay. B19 goes to the evap valve on the gas tank, it looks like.
Old 06-17-2019, 12:19 AM   #5
940 16 valve
Well that is confusing. It looks like the wire may also continue on at the top of that diagram? I'll have to play with it more...thanks for the replies.
Old 06-17-2019, 10:21 AM   #6
bmdubya1198
The B19 wire? That seems to loop back into itself through two connectors.
