Old 07-10-2019, 04:45 PM   #1
gottarollwithit
Cooks with motor oil
Default Manually activate and pump????
I got an 88í 740t
How the heck do you manually activate the abs pump? Perhaps pull a relay and jump pins? Which ones???
Really donít want to stomp the brakes to trigger the abs. Would prefer to run it for a few pulses while pressure bleeding. I got air in the system that I think is coming in/out of the pump, so I get occasionally mediocre brakes...
1988 740 turbo wagon/squishmobile!
gottarollwithit is offline   Reply With Quote
Old 07-10-2019, 05:12 PM   #2
Bleeding the brakes in the normal method with a pressure bleeder has always gotten the air out of the system on an abs car. At least that is my experience. Maybe get a small hammer and lightly tap on the junctions when bleeding? That should break free any stuck air bubbles.
Old 07-10-2019, 09:03 PM   #3
gottarollwithit
I think Iím beyond the normal situation like that. A couple yes back I had a shop replace my master. I think they somehow got air in my ABS pump and Iíve never gotten it out since.
Iíve pressure bled a couple times since then...
Old 07-12-2019, 02:06 AM   #4
gottarollwithit
Anybody?? I know i've come across this info somewhere...
Old 07-14-2019, 06:07 PM   #5
MasterBlaster
Mitchell manual says bleeding is done with the brake pedal, nothing else.
However (and I take zero responsibility if you fry your entire ABS system).....
RELAYS
Pump Motor Relay
1) With ECU connector still unplugged, turn ignition switch to the "ON" position. Jumper ECU terminal No. 28 to ground.
NOTE: Relay should not remain grounded for more than 2 seconds or damage to relay may occur.
2) Hydraulic Modulator should operate while jumper is installed.
504,000 km so far...
