Old 07-28-2019, 12:50 PM   #1
vintagewrench
vintagewrench's Avatar
Default 1974 and '75 B20 Eight Bolt Blocks
In the planning stages of building a new engine for our 1968 122s wagon which will see HARD high rpm use as the shop "truck," road car, and which will also be used for some towing.
Have access to both 1974 and 1975 B20 eight bolt engines and want to know what will hold up the best in the long run.
It has been reported that the '74 engines in addition to having bad cams suffered from soft blocks and cylinder bores that are also porous and wear out of round quicker. Does anyone know if this is actually true or is it and old "wife's" tale? Did Volvo ever publish anything about this in their service bulletins?
Seeing as the '74 engines supposedly had "soft" cams could the bores have just worn faster because of all of the extra cast iron junk floating around in the oil windage that did not get filtered out?
Old 07-28-2019, 07:00 PM   #2
I like the 75 engines better as they are metric threaded blocks. Also 75 had breakerless ignition which is nice to use. But having owned both with at least 200k on the 74 and over 300k on the 75 we used to have. Both were durable in my experience. It's the fiber cam gear that stopped the 75. It broke apart at about 325k and the engine had that crap everywhere inside. We put a rebuit engine in there and rolled the car for a while longer.
