Old 08-28-2019, 01:55 PM   #1
vwbusman66
Stößelstange über alles!
vwbusman66's Avatar
Default 140 Bilstein HD LCA modification
Read a review on IPD after buying a set pf HD’s.
It read: “installed these on my lowered 69 144s with great results. everything has improved. from braking to freeway driving. you do have to enlarge the lower A-arm shock hole. i love the larger upper mount bushings. almost twice the surface area. these are designed for larger american cars but work out well. i cant speak for a stock height car but they dont feel too stiff for my car”
What is this modification? Does my 71 with the 70-up arms need this? Pictures?
1971 142 beater/fake racecar
1972 145 sh*t hauler
Originally Posted by propav8r
The incest is implied.
Old 08-28-2019, 02:04 PM   #2
Old 08-28-2019, 02:06 PM   #3
vwbusman66
vwbusman66's Avatar
What needs to be clearanced? The hole the shock goes through?
Old 08-28-2019, 03:09 PM   #4
FrankBooth
FrankBooth's Avatar
Yep. Just buy them and you'll see. I think I used an electric grinder of some sort.
FrankBooth is offline   Reply With Quote
Old 08-28-2019, 04:34 PM   #5
planetman
planetman's Avatar
The opening in the lower A-arm has to be slightly enlarged so the shock tube goes through without scratching the paint.
Eric
Torrance, CA 90502
