Old 11-07-2019, 11:01 AM   #1
propav8r
F*ck Edgar
propav8r's Avatar
Default Boxing Control Arms...Worth It?
I've got the front and rear control arms off my 240 at the moment, and Yoshi's plates are only about $100 total.
Question for anyone that's done it...has it made a difference in handling or (especially in the back) do you view it more as an insurance policy against bending stuff under power?
Originally Posted by Hockey930
Jb welding tiny pieces of a fuse to the injectors seems to have worked perfectly
Originally Posted by Quin
i improved my life by just getting rid of my 940
nipple farts
My Project
K-Jet to Megasquirt Article
Old 11-07-2019, 11:14 AM   #2
JohnLane
Just do it. /thread.
Old 11-07-2019, 11:16 AM   #3
I have never boxed the stock stuff but I know that putting my stiffer units on was a noticeable improvement so i would assume that boxing the stock stuff would probably be as well.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 11-07-2019, 11:25 AM   #4
kyote
Living The Dream
kyote's Avatar
Boxing the back would be nice in conjunction with BNE's Spherical TABs.
As far as the front, if I popped a curb I'd rather replace a control arm than a crossmember or worse.
Old 11-07-2019, 11:27 AM   #5
propav8r
F*ck Edgar
propav8r's Avatar
That's what I needed to hear.
Old 11-07-2019, 11:31 AM   #6
JohnMc
JohnMc's Avatar
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 11-07-2019, 12:05 PM   #7
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
box or fabricate better ones for the rear.
Megasquirt Tuning!
Old 11-07-2019, 12:07 PM   #8
#boughtnotbuilt
https://shop.klracing.se/sv/artiklar...-special-.html
Old 11-07-2019, 12:19 PM   #9
F*ck 12
I did the front and back with 3/16" plate, overkill but it's what I had on hand. Definitely notice the difference.
"i will destroy all of you!"
-Sheldon Plankton
Booty Scooty
https://youtu.be/i4oAOZ8nbq4
Old 11-07-2019, 12:24 PM   #10
JohnMc
JohnMc's Avatar
I'm getting a few clunks out of the rear on mine already. And I already swapped the ovalized and shredded torque rods for IPD's with poly.
I'm guessing when I swap the 8.8 in I'll try to make everything stronger.
Old 11-07-2019, 12:30 PM   #11
white855T
You can buy sheet metal home at home depot or ace hardware and just trace the pieces and cut them to size. You can make 2 pieces from one piece of sheet metal if you do the yoshifab style. If you do Volvo taxi style plate, it will require 2 pieces of sheet metal(still have to cut to size).
Old 11-07-2019, 12:43 PM   #12
tjanson
tjanson's Avatar
When I slid into a curb during a parking lot snow hoon session, the impact to the front wheel bent my stock control arm. Would it have bent the unibody if it was boxed, or just bent up my wheel more?
1993 245 DL; LH2.4, M47 - DD & Winter Beater
1978 242 GT - To Be Restored, someday
1993 245 DL - OEM+ Project
tjanson is online now   Reply With Quote
Old 11-07-2019, 01:41 PM   #13
F*ck 12
Old 11-07-2019, 03:24 PM   #14
kyote
Living The Dream
kyote's Avatar
Tis my concern as well
Old 11-07-2019, 03:25 PM   #15
kyote
Living The Dream
kyote's Avatar
Installed a set on my brother's car last weekend.
Nice piece of kit, but no provision for swaybar, if you're in to that kinda thing.
Old 11-07-2019, 03:27 PM   #16
I welded some stock brackets on. Better solution would be to weld some U bolts to the arm and a bracket to a removable piece of bar, as the end links want to be right on top of the ball joint.
Old 11-07-2019, 03:27 PM   #17
propav8r
F*ck Edgar
propav8r's Avatar
I generally try to avoid sliding into curbs. Where I'm at, there are precious few curbs anyway. Generally just mountainside dropoffs.
Old 11-07-2019, 03:52 PM   #18
CAPT_BLOTTO
#Crush It
CAPT_BLOTTO's Avatar
The rear ones bend pretty easily. I've bent them before. Now they're boxed.
Hello My Glorious!
Old 11-07-2019, 04:17 PM   #19
tjanson
tjanson's Avatar
I wonder if the KL racing strut mounts are any good. You could pair them with their control arms for more camber and caster without switching to coilovers for spring clearance.
IF their strut mounts don't self destruct like all other stock replacement strut mounts.
https://shop.klracing.se/sv/artiklar...240-_260-.html
Old 11-07-2019, 06:52 PM   #20
MikeSr.
What, me worry?
MikeSr.'s Avatar
I used the Yoshifab pieces.
I coulda had a V8!
Old 11-07-2019, 07:30 PM   #21
IansPlatinum
IansPlatinum's Avatar
Volvo offers taxi arms from gcp still. They're boxed but have a provision to allow folding. Idk how important folding really is, seeing how the 850 arms are solid steel.
The rears should be stiffer in theory, but will experience a lot more force if you are using poly bushings in the rear
'96 854 Platinum - "Trusty"
'92 245 - "Boat"
'71 145 - "Rusty"
Previous:
'73 1800es - "Sunny"
'92 940T
'98 S70 T5
'99 S70 GLT
Old 11-07-2019, 07:41 PM   #22
culberro
culberro's Avatar
The KL arms and BNE Select strut mounts set to max caster make a 240 handle very very well (1.5deg neg camber and 7deg caster) . They really need delrin bushings front and rear to make them work well under heavy braking.
As far as boxing control arms...
For a DD: no real need unless your running big rubber up front, doing the occasional track day and really using your brakes. I have yet to fold/bend one at track days or drifting.
If your smashing rough roads: definitely box them.
KL Arms: I bent a set at a drift event. They’re now fully boxed, and now it destroys the rear control arm bushings if I hook a wheel on the inside curbing.
Old 11-07-2019, 07:42 PM   #23
culberro
culberro's Avatar
Rear trailing arms should be reinforced if you’re giving it the beans.
Old 11-07-2019, 08:20 PM   #24
My setup. It's so so so so good.
Old 11-07-2019, 08:38 PM   #25
Tfrasca
Tfrasca's Avatar
Not a direct comparison, but my 142 rear trailing arms were starting to bend a bit. A simple strip of 1/8" steel stitch welded on there stopped the bending.
