body work hell
I'm wondering if I can run a mild ported 531 head and b230f+t @ 7 psi safely on lh 2.2? Will this be to much power for the bottom end on the 88 b230f+t?
#2 | |
ARRRRHARHAR
![]() Join Date: Dec 2002
dont see why not, keep the timing in check tho
"They bum rushed them in their own crib, they drank all their beer, they partied with their ladies and they left with the trophy" Megasquirt Tuning! Plug and play LH 2.4 Megasquirt, now with stealth mode! ported volvo heads |
![]() Join Date: Jul 2002
the 9mm rods should handle that no problem...
the thing u need to watch like kenny said is timing is it a 240. have you added ignition that pulls timing with boost? my lh2.2 240 +T ran 7psi fine on lh but i had to keep the timing a little low and it made off throttle responses so so. |
#4 |
It's a girl!
Heh heh heh..... Those 9mm rods are actually pretty stout, but they will die if you push em too hard. I was running 15psi through a 42 trim for like 5 months, then 15psi through a 60/63 for a few months, then 10-15 psi through my holset and 405 head on my '85 B230f engine for a few months. And now I'm gloriously de-turbo'ed and still running like a champ. Though I'm tempted as hell to throw on a small turbo again, N/A driving SUCKS!
So yeah, you'll be fine with a 531 and 7psi on an F+T, so long as it doesn't ping like morse code. And if it does the translation is that you're engine's gonna splode!
'83 242 '95 T5R '98 S70 |
| Thread Tools | |
| Display Modes | |
