![]() I just got back from racing Lemons in Sonoma and have a problem I cannot figure out.
We raced Buttonwillow in September and car ran very well, it maxed out about 12-13 PSI with the stock actuator T3/T4 turbo. It would build to 10:1 AFR as it reached max boost. We did have problems with the turbo studs/nuts backing off on the 89+ manifold and eventually two busted. I had another 89+ manifold and had Yoshifab do the conversion service for T3. I did swap LH 2.2 distributors, but I did not change anything else on the car. It is running Microsquirt and I did not change the tune. When we started at Sonoma Saturday morning, it was raining hard so we were short shifting. When it started drying up, one of my drivers said it was boosting to 20 psi and would not rev past about 4500 RPM. Sure enough when I got in it, it was boosting way faster than normal and going to full rich on the AFR gauge. I confirmed the boost readings from the MAP sensor. Thinking wastegate flapper was stuck closed or actuator wasn't working, I wired the wastegate flapper open. I did not notice any change, it still was at 20 psi by 4500 RPM. I am going to take the wastegate off later this week to see if I notice anything. Any suggestions on other things to look for? B230FT in 745 T04E 50 trim 2.5" exhaust no cat single muffler DEKA 80# injectors Walbro HP pump in tank pretty much everything else stock except for microsquirt using LH2.2 dizzy |
![]() Join Date: May 2004
![]() Screwed up FPR acting like a rising rate under lots of boost?
Not sure what to say about the turbo still making too much boost with the WG wired open. It can't really be an undersized WG if it was working properly to control boost earlier on. Maybe it's an odd side effect of the rich spike - a bunch of fuel getting dumped into the exhaust and making so much volume that it overwhelmed the WG? Sort of like an anti-lag effect, only at WOT.
#3 | |
![]() Maybe. I plumbed in a fuel pressure sensor, but have not connected it to MS for logging yet. I have a Raspberry PI in the car and fully logged the weekend. FPR is fairly new, but who knows. I should have a spare FPR anyways.
One thing I forgot to mention was idling is very rough now and it will die if you don't feather the throttle. |
#4 |
![]() Check the fuel pressure, check for a leaking injector, do a compression test. Sounds like it's still running rich.
#5 |
BRANDSCHUTZVORSCHRIFTEN!
![]() Join Date: Dec 2002
![]() no power and additional boost? is the timing correct?
"They bum rushed them in their own crib, they drank all their beer, they partied with their ladies and they left with the trophy" Now with in-house Dyno tuning! Megasquirt Tuning! |
#6 |
#7 |
![]() Didn't think of leaking injector or compression test. Injectors have two races on them, but certainly new parts fail. I got them from a known source too, not ebay.
#8 |
![]() may want to verify that the timing isn't drifting with RPM, can do this in neutral with fixed timing set, rev it up as high as you can and watch the timing mark.
#9 |
#10 |
![]() if nothing else works, I'd check that. 3k with stable spark tho is probably pretty good.
#11 |
![]() Rag, or something else, plugging up the exhaust?
What do the plugs look like? |
#12 |
#13 |
I.M. Weasel
![]() The 20 psi has to be something with the waste gate I would think. Plugged exhaust would restrict boost. As far as too rich, I've had the injector drivers on my microsquirt fail and dump fuel but like 6 gals in a couple minutes. I have big injectors though too, close to stock might take longer to empty the tank
Living life one day at a time. Stopping to smell the oil slick beneath my Volvos. |
#14 | |
![]() Quote:
I appreciate all the comments and suggestions from everyone. |
#15 |
![]() Checked ignition at idle and timing belt, both are correct.
Removed and checked wastegate, did not see any issues. Checked compression with engine cold and dry 80 110 110 110. Then connected compressed air to each cylinder at TDC and I can hear air escaping, but it is most noticeable on cylinder #1. It sounds like it is leaking out the exhaust on #1. No air in water, no frothy oil. I did have to add about a gallon of water to the cooling system, but I think my last driver was driving the piss out of it and it started overheating in the long line to get back to our pit. I checked the logs and it was a solid 180 degrees for his 1 hour stint I don't understand how a leaking valve could cause extra boost though. Still need to check injectors and timing at higher RPMs. |
#16 |
bigpimpin740t@yahoo.com
![]() Sounds like boost but no airflo, ms runs fuel off boost so if no flo would give tons of boost and tons of fuel but no power, maybe something in the intake or issue with cam
85 744 Turbo F+T big valved531, stg5 cam, msns, m47, sways, bills, 53mm t3/t4 9lb flywheel, dual 044s, 80lbs, npr og |
#17 |
![]() 20psi with gate open is new tho
#18 |
Bored member
#19 |
![]() It is the 5 bolt garret wastegate that was attached to the stock T3 before I upgraded to a T04e.
#20 |
![]() Pulled the head and #1 exhaust valve is burnt.
![]() I am thinking that might be the problem. Sent head to machine shop for rebuild. |
#21 |
![]() So I had the head rebuilt. We raced Lemons last weekend at Inde Motorsports Park in Willcox, AZ.
Once back on the car, it was running very rich so I tuned what I could in the garage and then ran Tunerstudio VEAL for the first 30 minutes of the race. Boost was back to normal at ~12PSI. The only thing I can correlate the large boost increase to is the burnt valve and the overly rich VE map. |
