Old 02-03-2020, 09:32 PM   #1
James M
Bored member
James M's Avatar
Default We need more BEIGE, 83 242
Introducing a beige 83 242 that I hope to keep a little longer than most of my cars, I have plans for a swap or two down the line. .Currently has a m46, b23 and no AC, just the way I like it B234T5, T5 transmission, still no AC
I’ve been trying to get my friends into Volvos so they don’t keep buying ****boxes that I don’t want to work on, one is in a 244 I bought last year, another wants a 242. After looking for a car for him I bought this 83 242 from Luke, sitting since 2014 and a little smushed in the front but he threw all in the panels I needed. As soon as I saw it in person I knew there is a good chance I’ll have to find another one for him, I can’t pass up 172 rose beige (or any beige as I guess I can’t tell the difference).
In its napping place:
20200201-120351
20200201-120359
After getting the parts collected off the 244 next to it we headed home, the car drove quite well for something with 5 year old gas in it, barely any brake and crusty wiring
20200201-170625
20200201-181004
Sunday I took the panels off and started repairs, looks so naked
20200202-124720
20200202-131449
Pulled in closer to the garage and got a better look at the bumper support, pushed up nicely but only at the tip, core support back looked fine
20200202-115639
20200202-131207
In the process I ran over the can of white lithium grease visible in one of the other pictures
20200202-133720
I found that bracing the lower core support with jack stands, putting a bumper shock into the mounting hole and standing on it, along with some hammer swinging and map gas did a pretty good job of rebending the rail back into place
20200202-134446
20200202-140717
After straightening it out I wire wheeled the rusty spots and poorly painted them, should give me another 50 miles over bare metal
20200202-144100
20200202-144154
Put the front end together and it was looking much better, need to get some bumper trim out of storage for it but otherwise much more complete
20200202-174123
Next was rear sets Luke included, old ones had seen better days at the hands of a long hair pup
20200202-164148
20200202-164211
Door panels needed to be put on but didn't fit over the wood brackets made for the speakers, after trimming them down they slipped right on, definitely going to make some brackets for my wagon when/if I but speaker back in it
20200202-211420
20200202-214648
Cleaned and deletriced all the crusty connectors. Fuses only worked at specific angles when driving it home and I didnt want to lose my lights. Ended up spending an hour or two chasing electrical issues to find it was bad connections at the bulb housings and intermittent bad connection from a bent fuse holder
20200202-165725
20200202-181356
Took a break and went out, got back around midnight, planned on heading up to Chico in the 242 about 100 miles but was greeted with a nice leak under the car
20200202-212437
20200202-212726
Slid under the car to find it was the hose from the sending unit to the main pump, the color (hopefully) coming from dissolving undercoating and gunk on the old hose, pulled the hose to find two holes worn in it, at the clamp and where it goes between the brackets for the tank
20200202-212501
20200202-215434
No place open that sells hose and I tossed the old one I took of my wagon when I converted to a single pump, So I called it quits and drove up in the 245.
Let me know if its too picture heavy, focuses on little stuff too much or whatever. Recording what i'm doing makes working on it even more fun so I'd like to make it as readable as possible
20200201-170852
Current Bricks:
1989 245+t Now with actual FT
1988 245 Gramma gets to drive this one
1983 242 I need more BEIGE
Don't let me get another
1976 245, "Matcha" green, will be restored to stock
1984 245, Flaxon Yellow beute that I didn't know I needed
1982 245t, Something silver that doesn't work because kjet
Old 02-03-2020, 09:34 PM   #2
James M
Bored member
James M's Avatar
Not really, I value the ability to work on the car this week dramatically more then sleep so I pulled everything out of the wagon, stole the hose out of it (I need a better one anyways as it sees full pressure from a bigger in tank pump) and threw it on. Why drive a perfectly functioning car when you just bought a new one.
20200203-001907
20200203-003235
20200203-005111
Fired it up leak free and tossed the tools in the trunk. “Big enough to hide a body” - The guy who sold me my first 242
The 49er tape on the hammer is not mine I was rooting for the Chiefs
20200203-010406
Got halfway out of the driveway and remembered overdrive didn't work driving it home, I was not excited to drive 100 miles in 4th gear, pulled off the boot to find the eco harness was decomposing nicely
20200203-012548
Touched the wires together and on came the light, soldered it up and nothing… pulled off the knob to discover it was unplugged as well. Threw it back together and after a few presses to free up the switch it worked
20200203-014336
Left at 2:30 in the morning, got gas and crossed my fingers
20200203-022554
Drove up great, reminds me how relaxing these cars are when you maintain instead of mod, speedo is about 10mph off at 65, could use a center support bearing and I need to find quiet down the wind noise (looking at you leaky sunroof)
20200203-042326
4:30 AM I ate half a box of Goldfish in the car and “day”dreamed about what to do with it.
For real this time: Let me know if its too picture heavy, focuses on little stuff too much or whatever. Recording what i'm doing makes working on it even more fun so I'd like to make it as readable as possible
Old 02-03-2020, 09:52 PM   #3
Works for me so far
Old 02-03-2020, 10:24 PM   #4
Vol242vo
Keep it clean...
Vol242vo's Avatar
I like it, not too picture heavy. I like what you’re doing and the just ‘go for it’ attitude towards this 242. I love hearing stories about these cars sitting for so long and with very little amount of work, they just keep going...
Derek
1 Owner - 85k mile 1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 02-03-2020, 11:14 PM   #5
122power
dude
122power's Avatar
Nice work man! Glad it went to a motivated owner its what the car needed! Got the od workin too! Woop.
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
Old 02-04-2020, 12:21 AM   #6
James M
Bored member
James M's Avatar
Thanks, Glad the 3 mile long post isn't too much
They do just keep going, It went from a napping in the grass to driving 100 miles by pretty much just cleaning stuff
Old 02-04-2020, 11:10 AM   #7
Broke4speed
Broke4speed's Avatar
I dig it .
1984 244/ AQ140A / M46
Old 02-04-2020, 02:03 PM   #8
J ripper
Stoked to see this car up and running. It spent some time at my place.
People love it when you lose, they love dirty laundry.
J ripper is offline   Reply With Quote
Old 02-04-2020, 02:44 PM   #9
hackster
Love the beige!!
Beige and Brown for the win.
Sean
hackster is offline   Reply With Quote
Old 02-04-2020, 03:32 PM   #10
2manyturbos
It's a great starting place. I think I have both of those front bumper corner trims if you don't have a set.
Old 02-04-2020, 04:08 PM   #11
Estateman
K-Jet or Bust
Estateman's Avatar
Very sweet whip. I love the color and B23 + M46 combo as well. The amount of pics is perfect, can’t wait to see what else happens!
88 245 - M46 3.73 Gears
>>FEEDBACK<<
Estateman is offline   Reply With Quote
Old 02-04-2020, 06:16 PM   #12
James M
Bored member
James M's Avatar
Found a set of rims last night, listing stated they where 5x108 14inch enkei 92 rims. Was skeptical, didn't think they where ever made in 5x108 or 5x4.25
Picture from listing, they are silver but looked goldish in this picture to me
enkei
Went to the ATM and pulled out 160, got to the rims and he accepted an offer of 140 but only had 120 , paypaled him the difference and went back to the ATM to find my $40 still sitting in the cash slot, lucky me
20200203-220827
Test fitted them back at the apartment and HEY, they fit! Not sure if mesh rims are liked around here but I love them, have a set of 15" enkei 92 rims on my datsun and have always wanted them on a volvo. If only someone had a set of 15 inch Multi X rims for my wagon
20200203-234133
20200203-232832
Specs seem to be 5x108, 14x6 et26, they are pretty damn close to the ear(?) on the rear caliper. Think ill have to get ~5 mm spacers to bring it closer to Volvo spec.
20200203-232944
Was hoping to get a set of tires put on and try to mount them today to test for rubbing. Went to a local tire shop and called a few more, best quote was $370 for a set of aspen touring tires mounted and balanced. Thinking Ill order a set of Federal SS595 tires online and find a place that doesn't charge $72 to mount and balance 4 tires that arnt even on a car.
Ordered the tires and spacers, should be here by early next week
Old 02-04-2020, 06:20 PM   #13
James M
Bored member
James M's Avatar
Thanks for all the love on the car, glad to see Beige is well liked, looks so good on these cars in my opinion.
I have the bumper trim I just have to get it out of my storage unit next time I'm down in Davis, you never know how important they are until they are missing!
Old 02-04-2020, 07:35 PM   #14
white855T
Yep those enkeis were made in 5x108. Find a hispanic tire shop in your arear Should be able to get them mounted for about $40. That's what I pay(mount & balance). I just take my wheels and tires and watch them like a hawk to make sure they don't damage wheels. Would of been sweet to find a set in 15s but still cool wheels.
Old 02-04-2020, 08:42 PM   #15
James M
Bored member
James M's Avatar
There used to be a place that would for ~40 but the owner changed management and they bumped up there prices. 15s would be nice but I like the way these look
Old 02-08-2020, 12:23 AM   #16
James M
Bored member
James M's Avatar
Tires arrived and got mounted, cost more then I would like but at-least they are on. New tires are 195/60r14, much smaller then before but I like the look of the rear. The front is way to high, either gonna chop some springs or look for just a front set of lowering springs.
20200207-162525
20200207-162640
Finally washed the car, de-greaser and hot water from a pressure washer took off half a decade of gunk and moss, really looks great but needs waxed
Before:
20200207-133107
20200207-133128
After:
20200207-135307
After the wash idle was a little irratic and I could hear a strange noise, took me a second to spot it but the cap was cracked, full of water and arcing inside, replacing it made a world of difference
Crusty aluminum for you:
20200207-135500
Replaced the voltage regulator within the cluster, fixed my gauge issues and somehow my wipers and door chime, but that might be unrelated.
20200207-140753
Grabbed some armrests from the PnP, old ones where cracked and felt like they where about to tear in half every time you grabbed them. Got some trim for the window handles and finally bolted the drivers one in
20200207-125021
Old 02-08-2020, 04:51 PM   #17
2manyturbos
I have a bunch of brown interior pieces if you need any. Window crank handles, head rest, passenger side armrest etc.
Old 02-09-2020, 12:51 AM   #18
James M
Bored member
James M's Avatar
I got good stuff from the picknpull, the armrest in the pictures is the old one. Just need a second door interior handle bezel but Jack keeps grabbing them all!
Off to the pnp again tomorrow, maybe ill find one there
Old 02-09-2020, 04:08 AM   #19
2manyturbos
If you don't find one I have one in brown.
Old 02-09-2020, 09:49 AM   #20
Vol242vo
Keep it clean...
Vol242vo's Avatar
Before and after difference looks great. Keep it up.
Old 02-11-2020, 06:24 PM   #21
James M
Bored member
James M's Avatar
Looked for any parts forthe 242 at the picknpull and found a black headliner for a sunroof model, hopefully it fits over the massively thicc aftermarket electric sunroof
20200209-144648
Spend the rest of the weekend working on other volvos (anyone against multiple cars showing up in the same thread?)
Did a +t on my buddies 244, already needs a new clutch and its only at 8psi, previous/original owners said they never had it done in its 34 year lifespan
20200210-025320
Started a black interior swap on my wagon, now to tint the windows in 2 cars
Crusty, oily and kinda tan:
20200210-143000
Black and clean, anything dropped on the ground is now invisible in the dark:
20200210-150400
Old 02-11-2020, 10:49 PM   #22
Old Iron
I Roll
Old Iron's Avatar
Great save! Love good old projects like this!
Turbobricked
Originally Posted by Anonymous View Post
No sarcastic replies from Redwood Chair necessary
Old 02-11-2020, 11:26 PM   #23
Vol242vo
Keep it clean...
Vol242vo's Avatar
Carpet looks great, nice progress!
Old 02-14-2020, 01:31 AM   #24
James M
Bored member
James M's Avatar
Is two cars in one thread actually frowned upon? Or too confusing? They are both Beige so it seems to fit for me
This is on my 1989 245, I would make another thread but i'm already pretty far into this car
THEBRICK
Pulled a set of black door cards from storage to match the carpets, a little crusty and water damaged
20200211-103043
Painted them up with some moisture resistant paint, should stop any more rot
20200213-094615
Much closer to a black interior, need the seats and rear carpet to finish the look
20200213-112542
In come a set of WRX seats, because sliding across the seat every turn is a little annoying
20200212-162020
Don't worry ill get back to the 242, but need to get the wagon ready for some spirited driving
Old 02-14-2020, 03:30 AM   #25
Dijon
Commander in Mustard
Dijon's Avatar
Dude! Didn't realize there was someone else in Chico on this board! I'm glad there's someone else close by to help me bother Jack I'm interested to see out the WRX seats work out, I'm in a similar predicament
Dijon is offline   Reply With Quote
