i got this from a buddy for free, it came off an '90 RX7. it needs rebuilding, and i can see i'm going to need to do some work on the exhause side of the thing to make it work, as well as rebuild it, but what do you guys thing? some research has shown this to (most likely) be a t3/t4. it sure is a hell of a lot bigger than my stock turbo.
what do you guys think? ![]() ![]() ![]() ![]() |
ARRRRHARHAR
![]() Join Date: Dec 2002
ht18 eh? you'd be better served making the turbine fit a garrett turbine housing (it will)
"They bum rushed them in their own crib, they drank all their beer, they partied with their ladies and they left with the trophy" Megasquirt Tuning! Plug and play LH 2.4 Megasquirt, now with stealth mode! ported volvo heads |
Its a series 5 turbo II rx7 HT18.
The turbo is a good one for rx-7's but i am not soo sure its a good choice for a volvo. The compressor wheel drops off pretty hard around 12psi.. If you have any questions ask my buddy Brian at BNR Supercars. He builds those turbos for a living. The turbine housing will be difficult to make work but good luck any how. Sam
www.pbase.com/sam3481 One of the corner workers put it best regarding sam's volvo thrashing: "Sam is setting the front up for next turn, whilst the rear of the wagon is still recovering from 3 turns ago."
#4 | |
#5 | |
ARRRRHARHAR
#6 |
a nice spit-shine ought to do the trick!! lol
(you should have asked for the RX-7 too!!)
Derek | this is my sig |
#7 |
Exklusiv Zubehör Klub
![]() Join Date: Sep 2002
Ebay it and buy something more suitable. Not trying to pee on your cornflakes, its just nt a good turbo for a 2.3
#8 |
visst
That twin scroll housing will be difficult to adapt, and without a splitter of some good heat reistant material, it will probably overheat.. And cause more drag.
But it could be a interesting turbo to use, but I think it isn't worth it
240 | 1991 | 271 KKm | B230F+T | M90H | fuel:E85 Amazon/121 | 1968 | finished 2016+? |
#9 |
Would be easiest just to make a new exhaust manifold. If he is a skilled machinist and fabricator as he says it shouldn't be too hard to weld a new exhaust header. Would also be much better flowing than the stock exhaust manifold.
#10 | |
ARRRRHARHAR
#11 | ||
Building a 5.044, slowly
Is that turbo scary white color inside or is that my imagination? What does a pinging/detonating rotary sound like?
#12 |
how about not wasting time trying to do the "square peg in a round hole" thing and ebaying it and buying a turbo that will bolt up and work properly?
#13 | |
#14 | |
On a mission
#15 |
is that what all that tan/whitish stuff is? i assumed that was normal...(i know precisely squat about turbos stilll...aside from the part about being spun by the exhaust and making a crapload more power
#16 | |
He who controls the Spice
Too true ![]() |
#17 | |
Volvospeed Spy
Wanananananana--POP! Time to rebuild it, again! Interesting looking turbo, never seen one of those before.
-Eric -1995 850 turbo - Ridiculous modifications list.. -1984 244 GLT - Blue.. 14.0 at 100.2.. TD04HL-19T-conical (SOLD) FWD versus RWD Project - Who will win? (240 won ET, 850 won trap speed) "...of all the liars among mankind, the fisherman is the most trustworthy." ~William Sherwood Fox |
#18 | |
ARRRRHARHAR
low boost detonation on a rotary sounds like a whistling noise, and contrary to popular belief, they'll take a little abuse (but not much, and really not much above around 15psi i'm told). |
#19 |
visst
Indeed, that white color indicates a very high temperature.. The devider shouldn't be too much of a problem now I think of it....
I have seen truck turbo's that had the devider, and no exhaust manifold with devider. The devider looked like someone cut a inch of it away with a angle grinder.. totally cut in half.. ![]() |
#20 | ||
Mens Classic Fit Polo
![]() The Belgian Wonder Quote:
#21 |
ok, so its not a good turbo for a volvo. what makes it bad? other than the work involved, what makes it "bad"? is it just a matter of the way it makes power?
#22 |
What Deathwagon said:
"The compressor wheel drops off pretty hard around 12psi." It isn't designed for the high pressure ratios that our motors need to make good power. It gets inefficient and starts to superheat the air past 12psi. |
#23 |
in other words...too small and inefficient
"I like anything fast enough to do something stupid in." - Xander Cage, xXx |
#24 |
No, not too small or inefficent, it does not support the pressure ratio required. It is entirely efficent within it's operating range, and a turbo can be capable of 500hp and still have a map that falls of at 12psi. It would not be "too small", it would simply be wrong.
#25 |
i apparently need a lesson in understanding turbo maps...
| Thread Tools | |
| Display Modes | |
