Old 04-09-2021, 04:36 PM   #1
DailyDriverMods
DailyDriverMods's Avatar
Default The excessive TD04 turbo guide ®™
For a while now i have researched most of the details of the TD04 turbo family, specifically those that are relevant to redblock usage. I hope this could function as an end all be all guide for TD04 related info.
Compressor type:
Let's start with the most common question, how many T's or G's do i need? Generally you want to keep your turbocharger as small as reliably possible for your power goals, this will generally give you the most responsive setup. I'll give a rough estime of crank hp that the turbine will support maximum at PR = 2.0, estimated HP is crank. (output pressure = 2 times input pressure)
Tiny:
-13C: ~200HP
Small:
-13G: 360cfm ~ 240HP
-13T: 400cfm ~ 265HP
Medium:
-15G: 428cfm ~ 285HP
-16T: 435cfm ~ 290HP
Large:
-18T: 488cfm ~ 325HP
-19T: 500cfm ~ 333HP
Turbine output flange:
There are multiple types of TD04 turbine sizes. The stock turbo uses a TD04H 6cm2 turbine which is a medium sized TD04 turbine. Since the TD04 family is already quite small for our redblocks, it is adviced to directly go to the (relatively) large turbine family, the TD04HL turbines.
The TD04HL turbines comes with 3 different outlet flange types:
- The conical flange is the smaller outlet flange and fits directly onto the stock downpipe. It doesn't flow that well and spool is a bit slower compared to the other outlet flange types. It's nice as a drop-in replacement but don't expect to make big power efficiently with this type of outlet flange. A small or even a medium sized compressor would be a nice match.
- The flat flange is the medium sized outlet flange and mounts easily to the stock manifolds. The original downpipe will need to be converted to this flange type but that is an easy fix. Matches great with any compressor size and probably gives almost all attainable TD04 performance.
- The angled flange is the biggest outlet flange and needs a bit of extra work to fit the stock 90+ manifold. This flange is the best flowing of the three, but won't give that much of a gain compared to the flat flange, especially when running a 2.5" or smaller exhaust. Generally it isn't worth the extra trouble for the performance gain but it is the most common exhaust flange so availability is good compared to the others.
Turbine size: (A/R-ish)
The most common turbine sizes for the TD04HL turbine houses that fit our manifolds are 6cm2 and 7cm2. The size of the turbine can be readen from the serial number that's on the turbine itself or from the shape the turbine has.
- The 6cm2 turbine has got a smaller outer radius and is a bit square-ish on the outside. I would use this one for up to about ~260HP crank or until the EGT's start to approach 900*C. This will be a nice fit for a small or medium sized compressor and will give a quick spool.
- The 7cm2 turbine has got a bigger outer radius and is more rounded on the outside. This one obviously flows better than the 6cm2 housing and is a nice match for the large compressors. It spools a bit slower than the 6cm2 housing but flows better up top.
The turbine size is NOT dependent on the opening size of the turbine input flange that meets with the exhaust manifold. Let's scroll into the next section to give some clarity about that subject.
Turbine input flange:
Now comes a, in my opinion, somewhat overlooked part of choosing the right turbo. Exhaust gas velocity and a smooth transition from the collector to the turbine is key for maximum responsiveness. There are at least two different turbine input flange types for the Volvo TD04HL turbo's:
- When using a 90+ manifold, you want to have the input flange with the smaller opening. This opening fits nicely to the opening of the manifold. Porting of either the turbine or manifold is not adviced since this will unneccessarily reduce the exhaust gas flow velocity without any gain on a TD04. The stock exhaust collector has got a free flowing port with a surface area of about 15cm2. The largest turbine area is 7cm2, which is restricted in flow as well by the turbine. The wastegate port generally has a free flow opening of around 3cm2. Well, you see where this is going... More than 15cm2 is just not needed to feed the TD04HL and will just kill the gas velocity by creating an expansion chamber thus reducing responsiveness.
- When using an old-style manifold, you want to have the input flange with the large opening since the "collector" opening is quite large.
With a bit of experience:
Originally Posted by ipdown View Post
I know this is old thread.. but. Ported manifold gain is slower spool.
What makes real difference was post turbo. Note - that is on 2.0 liter engine.
I tried 19t with 7cm2 conical housing (cast nr. 89-11800 7) - awful response and awful overall.
Then it was full 3" exhaust with heavily ported both manifold and 7cm2 flat flange housing (115 89 11810 7) - a lot better, but still slow response. Full boost hit at ~3200 and boost rise was kinda slow.
Then it was unported manifold and unported 7cm2 (115 89 11810 7) flat flange housing - full boost at 2800, hit much harder, boost rise faster, felt even better.
Finally I settled with unported manifold and 6cm2 (115 89 11710 6) flat flange housing - the car is a blast, response is as with stock 13c if not better.
Test was made with A and T cams. I finally stick with T cam. A cam wakes above 3k RPM, but
low down feels anemic. Again, this is daily driver and I don't care much about high top end, altough the car makes good 220 whp. With T cam and unported manifold and small 6cm flat flange housing I have a nice torque curve all over the place.
This is my take on understanding all the turbo talk, i hope this helps with finding the right turbo setup.
[1991 Volvo 240 sedan, daily driver ] [B230F|IPD Turbo Cam -2*|MS3x|145HP/215NM|M47]
~Gotta love that GL trim~
MS3 thread including MS3 tune
DailyDriverMods is offline   Reply With Quote
Old 04-09-2021, 08:21 PM   #2
Swedbrick
Swedbrick's Avatar
Thanks, this is amazing reference! This might be worth pinning in my opinion
Volvo 745 - Turbo, LH2.4, M90 swap, IPD springs, 25mm/19mm swaybars, 3.54 \w racingdiff lsd, track/daily
Volvo 363 - N/A, Speeduino, GSXR ITB's, half-cage, work in progress
Old 04-09-2021, 09:30 PM   #3
volvo 4 life
volvo 4 life's Avatar
Great info, mods please make this a sticky!
Originally posted by Forg: "How To Properly Seafoam A Saab In One Easy Steps":
Step 1. Push into sea.
Originally Posted by Tenacious Todd View Post
I was hitting the brakes real hard and the grille flew out and I ran it over
Only on a Volvo...
Originally Posted by isaac View Post
A volvo 240 with the front wheels chopped off would be a reliable all wheel drive vehicle.
volvo 4 life is offline   Reply With Quote
Old 04-14-2021, 04:47 PM   #4
Wilford Brimley
Is posting from the grave
Wilford Brimley's Avatar
265hp on 13t? I'd say you're pushing it at that point
Deb the 940T Tina XC90 T5
Old 04-15-2021, 02:31 PM   #5
DailyDriverMods
Thank you for the appreciation of this guide. The horsepower numbers are based on the compressor maps and a HP = CFM/1.5 calculation. The 13T numbers seem to be a bit high, especially when it's considered that the G wheels flow more than the T wheels at the same size number. And the 19T numbers seem to be a bit low, i can change them if anyone has better numbers on this.
Old 04-17-2021, 01:34 AM   #6
Wilford Brimley
I'd think the compressor maps are relative to the motor too...ours would be hard pressed to put 265hp out on a 13x id think
Old 10-31-2021, 10:40 AM   #7
pathfinder
Hi
nice write
i drive stock standard 940 FK. low pressure turbo. 13C turbocharger. i think low pressure version power just 135bhp and 230nm. Good for city driving, stop-go traffic
but asthmatic on highways
i have Rica ignition and fuel chips and Hallman manual boost controller. Didn't fit them yet
Still searching for better turbocharger. Im not interested with big bhp n big torque. Realistically to preserve reliability, with 23 yrs old car, 240,000km odometer, i think 200bhp and 280nm just nice for highways.
15G turbo (from 850-T5) is very hard to get now. This 15G is nice balance power from low to mid range rpm.
12T , 14T and 13G got plenty. Do u know guys 12T, 14T and 13G CFM
flows ?
As for exhaust system, is it okay if i use 3" turbo downpipe and cat back use original size 2.2" pipe ... and end up with 2.5" S flow muffler?
pathfinder is offline   Reply With Quote
Old 10-31-2021, 10:57 AM   #8
pathfinder
im worry by using 13C and up power to 180-200 bhp, the turbine side and EGT easily get hot
Old 11-01-2021, 05:56 AM   #9
SkeTchy-MechAniC
SkeTchy-MechAniC's Avatar
Dyno'd roughly 300 crank on an b5254t with one of these, Should be possible. Definitely not a very durable combo though.
Never have i ever .... Seen a 242 with two motorcycles in the back
SkeTchy-MechAniC is offline   Reply With Quote
Old 11-01-2021, 06:30 AM   #10
Fa182
Stage 1
Fa182's Avatar
Originally Posted by pathfinder View Post
I have a 1997 940 with a 16T set to a max. of 0,9bar boost.
Along with that turbo, I have a KL Racing Intercooler, which made an even bigger improvement than the actual turbo swap.
I use chips from "redblockpowered" on here.
Stock exhaust system.
I am very happy with the power it currently has and it's more than enough for every kind of daily use.
I rarely use max boost / full throttle, only when overtaking etc.
If I need to estimate, I would say I currently have around 30hp more than stock, so something between 190-200.
I also wasn't able to find a 16T turbo locally so I bought one from on here and even with the international shipping from US to Austria, it was considerably cheaper than finding one around here (or in the countries around me).
Just a thought for you, you can make a post in the "wanted" section.
Old 11-01-2021, 08:09 AM   #11
Chilm
Double Dutch
Chilm's Avatar
Hi
nice write
flows ?
Hi, do you live in the Netherlands?
I have ported my 13c and done the cylinder inlet and outlet extensively too.
Wasted spark, 3 inch exhaust together with 3 inch downpipe, chipped ECU and EZK (bla bla chips) and I can tell you that it's a very fast package especially when standing for traffic lights, that 13c spools like hell and that is what you want imho, humiliating the Honda's etc.
I've got a completely ported 15G too but I'm not sure if I'll put it in cuz the 13c combination is so fast from scratch
Bottomline is when and where are you gonna drive plus 150km? Accellerating fast is much more fun =P
Flying Dutchman - Build and goodies thread ;P
Volvo 945 - Blue Pearl - LPT Polar 2.3 Limited Edition
B230-FK Turbo - 90+ ported - 15G Ported - Airintake
Erland Cox Regrind - Blabla Chips - 3 inch exhaust
MBC on 0.95 - Wasted Spark - Sponsored by my wife
Chilm is offline   Reply With Quote
Old 11-01-2021, 06:52 PM   #12
90volvo
Nice write up, one of my best dd combo was 15g, Vcam, 3inch ex, 90plus manifold, NPR ic, 650cc inj on E85. Was my daily and man was it fun to drive with 5 speed. I kinda wish I just left it alone but just couldnt. lol
B230ft rebuilt -MS-Turbo-E85
1985 240 Work in progress.
Old 11-02-2021, 09:05 PM   #13
Rat Dangerous
I am in the process of a +T on my auto 1994 940. I was told by a local Volvo/turbo rebuild guy that I should upgrade my compressor (15g) during my rebuild as the 13c just aren't good. Is this still worth doing on an automatic car with such high compression? I don't want to boost the car so much it breaks just want a fun project that I can keep upgrading slowly with time.
Rat Dangerous is offline   Reply With Quote
Old 11-03-2021, 12:53 PM   #14
Bloody244
mine was a 87 +t with a 19t and it was fun until it blew up stay around 8-10 psi she'll be mint. not like me who had a couple months of 28+psi and bad ignition timing
'87 244 B230R @14psi 19t, V16t cam, Haltech Elite 1500, Stage 3 overboostracing.se 530 Head, ACM H-beam rods, Do88 intercooler, Accumulator Mod AW71
Instagram https://www.instagram.com/blue__244/
Rip '87 B230f+t it did not stay window free 25.06.2021
Bloody244 is offline   Reply With Quote
