Go Back   Turbobricks Forums > Symposium > article composition
Old 04-28-2004, 10:07 AM   #101
blu92in99
Originally Posted by pengee
I got the fiber-carbon disk, and the clutchnet pressure plate and had my flywheel resurfaced and the pressure plate balanced with it. Everything is back together and I adjusted the clutch to where it should be sitting. Could not get the car in gear as the pressure plate was not disengaging the clutch. After a million different adjustments and notching the bellhousing I can adjust it in so far that the fork hit the pressure plate?!?! Still with it that far in it was engaged.
(I'm gonna make an assumption that with the engine off you can row through all 5 gears with no difficulty, and with the engine running it won't go into gear) You might want to make absolutely sure that you put the disc in the right way. A buddy of mine did that on his Jeep, he installed the clutch disc backwards, not allowing it to go into gear when running. Just my $0.02
I'm not here anymore! Find me on BrickSpeed if you need to contact me.
blu92in99 is offline   Reply With Quote
Old 04-28-2004, 11:08 AM   #102
pengee
Yes, with the car off I can go into any gear with out problem. When the car is running it can't.
When I did the clutch the first time I found that it could not even be put in backwards as the springs in the hub would hit the bolts on the flywheel.
In my 740wagon I was able to put it in backwards one time but it was obvious when I started the car.
pengee is offline   Reply With Quote
Old 04-28-2004, 01:03 PM   #103
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
I had this problem when I did my T5 swap. Are you using one of JP's pressure plates?
I have a feeling that the "teeth" on the PP aren't tall enough. Noah is using an OEM pressure plate and his works fine, mine however I needed to extended my throw out bearing. It did the exact same thing.
History: Car 1 | Car 2 | Car 3
Old 04-28-2004, 02:18 PM   #104
pengee
This is the pressure plate that JP sells, he gets them from clutchnet. I know I saw a picture of it in someone’s install, maybe it was dbartons, I could be wrong though. They used all the same parts as I have and I don't recall them having problems.
That was another thought, to extend the bearing. Do you have any pictures of yours? Also, are you using the same one that you mentioned at the beginning of the thread.
Or do you think it would work very well to make the pivot ball on the other side of the fork stand off farther?
Thanks for the info.
Old 04-30-2004, 08:13 AM   #105
Turborg
Turborg's Avatar
I have the same equipment and the same problem. My best guess at this point is that more travel is needed from the Volvo clutch. I'm going to check out under the pedal first to see if I can do anything there first. I don't think we need more than about half an inch. If the tranny has to come out, at least everything is clean.
Turborg is offline   Reply With Quote
Old 04-30-2004, 09:56 AM   #106
Turborg
Turborg's Avatar
clutch travel is not the problem-hours wasted
Old 04-30-2004, 12:03 PM   #107
Hank Scorpio
Great bud! Glad you've semi figured it out ;)
I think we need to let JP know whats going on with these pressure plates.
Old 04-30-2004, 12:13 PM   #108
pengee
I agree, when I started this I had a centerforce pp and it requires a lot less travel than the clutchnet pp to disengage the clutch. When I talked with JP he wanted me to use that one in the long run so that we could see if it was a better solution than the to the swap. However, he said that he was going with clutchnet, reguardless I think, because centerforce would not sell the volvo pp with the ford clutch.
I got another flywheel yesterday, it is stock and about twice as thick as the lightened one that I have in now. I am going to put it in today when I get it back from the shop and maybe extend the pivot a little. I am guessing this will help out if not solve the problem.
I am also considering getting a new centerforce pp since the old one worked so well.
Old 04-30-2004, 12:36 PM   #109
Turborg
Turborg's Avatar
This post was inaccurate
Old 04-30-2004, 08:16 PM   #110
noah244ti
noah244ti's Avatar
To Dave or Turborg,
I understand you both are using the new t5"Z" transmission. If you dont mind me asking, where did you guys get them and what did you pay? I cant seem to find any sources for the "Z" online. Thanks, Noah
noah244ti is offline   Reply With Quote
Old 05-01-2004, 12:06 AM   #111
Turborg
Turborg's Avatar
Default Shifting problem
I think Pengee has solved our problem!
Old 05-01-2004, 01:21 AM   #112
pengee
well I just thought I would let you guys know that I have narrowed down the problem to the pressure plate. I pulled everything out today and found that the teeth on the pp are not even. I played with it and found that one of the outer springs is, I think, more firm than the rest. I must not have noticed this when I installed it. So, I tossed in my old centerforce pp and clutch just to get me by. I am going to be ordering a new centerforce pp this week and I am saving my other new clutch to go with it. I practically have two of everything now.
As for the centerforce pp I have been more than happy with it. The travel involved was no different than the factory volvo pp. The fork does not come too close to the bellhousing under propper adjustment and the clutch is spinning free. With this pp I can shift into reverse all the time with no grinding and never having to hit first gear before doing so.
Anyways....correct me if I am wrong but it seems that everyone running the clutchnet pp setup has had some problems here and there. Let me know what you all think. Maybe I am just irritated
Old 05-01-2004, 01:40 AM   #113
Turborg
Turborg's Avatar
Default clutch problem
Pengee: I am really surprised it could be the pressure plate, but it does make sense as the guys running OEM plates are having no problems. And your expirence speaks volumes. Are you going to try to get your money back? I am if I can prove it is the plate. Does anyone have a positive expirence I felt that the pressure plate was weak from the get go but I thought it was other problems. Thanks for the post.
Old 05-01-2004, 02:25 AM   #114
pengee
Being that all pressure plates are just modified oems for the most part I have no way of knowing if what clutchnet is selling is no good. Maybe I just got a bad one, or maybe they just don't have them dialed in yet.
In any case I am not getting another one, but I will be trying to get a refund. Who knows how good they are with that, I guess I will find out.
As far as everything sold or recommended by JP I am happy with it, including the clutchnet clutch, but not the pp.
Seems that oem, centerforce or maybe something else would be the way to go.
Old 05-01-2004, 12:01 PM   #115
Hank Scorpio
Yep, sounds like the issue to me. Im running the CN pressure plate/disc, and it works great BUT, I had all those T/O bearing problems.
Turborg, I would defiently swap on an OEM pressure plate or what not or the drive.
Old 05-01-2004, 05:48 PM   #116
Turborg
Turborg's Avatar
I guess there is no getting around pulling back out the trans. It is just that on my car the problem does not seem to be the clutch not disengaging. Usually when the clutch is not releasing, the car wants to move as you "chirp" it into gear. And when you start it in gear, the car wants to move a little in the direction of the gear. Neither of these happen on my car. The fact that I could easily turn the tailshaft with my hand with the clutch fork depressed before I installed the engine and trans, and not having the above symptoms is not mechanically logical to me. The fact that it shifts very easy as soon as the engine is shut off to me eliminates a trans related problem. Something is causing that input shaft to spin and I think it is something to do with pilot being. But it has to come out now.
Doug: Is your clutch working now? I thought the last we spoke you were having the same problem as Pengee and myself. Did you go back to an old set up?
Old 05-01-2004, 06:52 PM   #117
Hank Scorpio
No, this was way back when I first did the swap. My problem was the fork would hit the PP before disengaging the clutch. Ended up making a taller T/O bearing.
Sounds to me like your pilot bearing is goofed.
Old 05-02-2004, 01:11 AM   #118
Turborg
Turborg's Avatar
I too think that it is the pilot bearing. I shimmed the trans away from the adapter and the trans stopped making noise(I think the noise is gone because the input shaft bearing is now free to float as it should instead of being pressed back to a rearward position)and I have a quick strong engagement of the clutch now. I actually backed off the adjustment of the clutch and the above resulted. I still have noise that I think is a result of a damaged pilot bearing but I am not going to pull the trans for a while as it is working OK for now. I think the pilot bearing was damaged by having the input shaft forced into it by improper clearance. Still just a theory til I pull it. Anyway, Davis here I come! Two days ago I didn't think there was anyway I could possibly make it. All these trans problems has also kept me from enjoying a exceptionally nice running B23FT. I should be happy that it was trans rather than motor problems.
Old 07-02-2004, 11:34 PM   #119
coondog240
Homing Pigeon
1/4" thick plate steel welded to the bottom of the crossmember. Couldn't have been easier.
could I get some dimensions for this plate so I can make one?
Thanks,
Jeremy
coondog240 is offline   Reply With Quote
Old 07-03-2004, 12:27 AM   #120
Hank Scorpio
Jeremy, I'll take them this weekend for you (I have it sitting on the ground). IIRC it wont need much, 2x4 I think
Old 07-03-2004, 06:03 PM   #121
noah244ti
noah244ti's Avatar
4"x6"........ ; )
Old 07-03-2004, 07:44 PM   #122
coondog240
Homing Pigeon
Hey Thanks abunch. It should be in this weekend.
Old 07-06-2004, 03:07 AM   #123
RvolvoR
Master Troublestarter
so has anybody attempted this swap w/ the 700/900 series volvos? if so what tranny did you use? do you use the one from a camaro, if so i need some info on how it worked out. if you used the ford one , how much hacking was involved for the shifter to work?
Old 07-07-2004, 08:35 AM   #124
volvo9
volvo9's Avatar
I've got a mustang T5 in my 94 940. To get the shifter to fit you have to cut some of the metal at the front of the shifter hole in the body of the car. I made my own shifter from a piece of scrap metal. In the picture I haven't installed the trans mount yet, the little shifter piece on the trans that the shifter bolts to riases up when the mount is installed.
volvo9 is offline   Reply With Quote
Old 07-10-2004, 01:31 AM   #125
Mach375
Bored Member
I'm the fist (only?) to have put a Ford T5 in my 700.
You need to re-read through the thread more carefully (at all). Your question is answered in detail, sans pictures on my behalf. (DON"T JUST PERUSE THROUGH, IGNORING ANYTHING THAT'S OLDER THAN A WEEK. THIS THREAD HAS LOADS OF HELPFUL INFO IF YOU JUST SPEND THE TIME TO READ IT)
"The trouble with quotes on Internet Message Boards is that you can never know if they are genuine." -Abraham Lincoln
Mach375 is offline   Reply With Quote
