Old 06-20-2022, 11:21 PM   #1
VolvoLatAm
Default door card backside plastic
what type of plastic is typically used on the backside of the 240 doorcards?
Old 06-21-2022, 01:03 AM   #2
Kjets On a Plane
Kjets On a Plane's Avatar
Depends on year? The '89+ white style are more UV resistant & were riveted over the tops of the speakers even & tucked into the doors to shed water, but the window scrapers being intact is still important for the health/longevity of the door cards. '89+ style a bit more tyvek like, but don't have fiberglass/fibers in them.
They're not that expensive new & they often get chucked or molested when people hack stereos in the cars.
The '85?-'88 style are a sorta thicker but more brittle/easily torn or cracked clear plastic / poly vinyl it would seem?
-'84 are some waxy paper that rots and molds in the PNW, especially if the window scraper seals aren't perfect or are broken/old by now & car wasn’t garaged its whole life…
Or do you mean the actual door card/panel itself & not the vapor barrier?
I think it's just masonite or some kind of fiber board, don't know of any plastic on the back of 200 series door cards themselves?...
How PSI a stock can support?
Always Be Crushing!
Old 06-21-2022, 04:12 PM   #3
nel621
You could DIY a shower curtain liner into a vapor barrier.
Old 06-21-2022, 04:25 PM   #4
rearwheelpeel
Slow Learner
rearwheelpeel's Avatar
This is exactly what I did. I cut a shower liner to fit the door and sealed it around with butyl tape. It works very well.
rearwheelpeel is offline   Reply With Quote
Old 06-21-2022, 05:17 PM   #5
Kjets On a Plane
That's how they do it on the Japanese cars (effectively in some cases though the window regulators can gum up on those/stop working in rainy drippy salt air?) , but Volvo literally sorted out the Vapor barrier nicely on the ~'89+ models, why reinvent the wheel?
They're still in the junkyards (not for 242 I guess?) or were actually not that expensive new from the dealer...
Old 06-23-2022, 09:51 AM   #6
mikep
The MP
mikep's Avatar
Moisture barrier for floors is usually “6 mil” (.006”) and available in small rolls cheap.
12 mil is more rare, then it jumps to the 20 mil, usually only found in huge rolls.
Originally Posted by megulon-7 View Post
You Oregon beavers keep your hands off our sweet Cali redwood and we won’t touch your Portland $8 doughnuts.
Old 06-27-2022, 10:31 PM   #7
- Stock PSI Or Bust -
how psi stock cna sprout?
Old 06-28-2022, 10:29 AM   #8
Fa182
Stage 1
Fa182's Avatar
It should just be a simple PE foil that you can get at every hardware store.
