Old 04-04-2005, 03:14 PM   #1
air_cooled
Default Oil filter housing o-ring
I just received the oil filter housing o-ring from fcp but it seems a bit too small. The old one was black and flatened out, but the new green one won't stay in. It wants to pop out.
Part # is VOL-967343 Any help appreciated. Also have a new diff cover gasket. Do
I have to put any sealant on it?
Thanks alot
Steve
1990 740 Turbo 285000 mi.
1993 850 GLT 169000 mi.
1966 Corvair Monza Convertible 38000 mi.
1965 Corvair Monza Sport Sedan 18000 mi.
air_cooled is offline   Reply With Quote
Old 04-05-2005, 12:52 AM   #2
Three Fat Tigers
Three Fat Tigers's Avatar
Location: ↓ Lynchburg, VA →| '89 740Ti | '90 760Ti | '92 240 | '94 940T | '96 960 | '96 M1
Shouldn't do that, not sure what to do except give FCP a call.
You shouldn't have to. If you choose to do so anyway, I recommend using Permatex Ultra-Copper, I've found it far superior at preventing leaks.
Three Fat Tigers is offline   Reply With Quote
Old 04-05-2005, 01:19 AM   #3
is this the same as the oring that sits behind the oil cooler sandwich plate?
mine has started to leak and i cant find the replacement for it anywhere?
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 04-05-2005, 01:31 AM   #4
smith_t240
Abnormally Aspirated
smith_t240's Avatar
Damn it!!! I can't find the Volvo part numbers for these rubber o-rings. I bought 3 for my 240 turbos.
Just to clarify: Oil cooler thermostat assembly to engine block right??
240s same as 740s??
I'm still looking........
Smith
Smith T.
83 244Ti white project car
07 S60R 6spd black the better DD
Originally Posted by Ktown_Brick View Post
I stubbed my toe while getting a beer this afternoon. I feel both your guy's pain. What a crappy day, ohh well, tomorrow can't get much worse for me
smith_t240 is offline   Reply With Quote
Old 04-05-2005, 01:43 AM   #5
smith_t240
smith_t240's Avatar
Okay guys, not completely positive, the receipts I get from the dealership aren't very detailed. You definitely want to double check when you get there. BTW, the o-ring is black.
part number: 925093 list: 1.39
Old 04-05-2005, 05:52 AM   #6
air_cooled
Well I went to Volvo dealer with the housing in hand. They had two different part #s. One green, one black. The green did not fit, same one fcp sent. The black fits perfectly. (smith_t240 is correct!) I've been calling it the oil filter housing - It's the part that the oil filter screws into. The large round end fits up to the block with one large bolt. Not much fun
to get to. I need a better way to tighten it back up now. I'll post the $1.50 part # later, the receipt is at my shop. Thanks much for the replies.
Old 04-05-2005, 07:32 AM   #7
foxtrapper
There's two different o-rings, and you got the wrong one. FCP lists them both, with the instructions on how to chose. Since they were only a dollar each, I bought both so I wouldn't have to worry.
No sealant necessary on the diff gasket, but you can use it if it makes you happier. I probably would myself.
foxtrapper is offline   Reply With Quote
Old 04-05-2005, 07:58 AM   #8
Morley
Barbie Ken
Morley's Avatar
925093 is also what Vadis lists....dunno what that dealer did, to get 2 different o-rings?
Morley is offline   Reply With Quote
Old 04-05-2005, 09:27 AM   #9
air_cooled
O-ring #925093 is what Volvo sold me. After re-installing the assembly, I installed a new oil filter, oil etc, and tried to fire it up. After about 20-30 sec turning enging over, big puddle of oil. Can't tell yet where it's coming from. This is all after installing rebuilt turbo. I guess I still have a ways to go.
I wish I had something to offer in return for this great info but being new to Volvos it may take a while. Thanks guys.
