Old 04-09-2005, 07:43 PM   #1
volvorod85
volvorod85's Avatar
Default T-5 transmission converson questions answered!!
Mod, if I put this in the wrong place please move accordingly.
Just finished my T-5 swap a few days ago!!
Ford T-5 transmission swap for 700 series.
The reason I swapped my M-46 for the T-5 was the fact my M-46 leaked pretty bad, and I never liked the gear ratios. With the T-5 you can go as far as to turn it into a straight cut gear dog tooth trans. There are many different gear sets avaiable for it, part are easy to come by, and the transmissions are easy to find. For 5th gear, there also also 2 different options, the second option is of course an aftermarket gear set.
Im writing this to hopefully fill in any gaps and answer questions reguarding the swap on a 700/900 series. This swap was done on my 1990 765 turbo, which only came auto, but I had previously converted it to the M-46 with the hydralic setup.
I picked up my T-5 from an ad in the Recycler (local classifidies) This is the parts list.....
T-5 Transmission.
Ford pilot bearing and release bearing (throw out bearing) for 87-93 V-8 5.0 mustang.
Ford clutch disc from 84-86 Mustang SVO 2.3 turbo. This is the 10 spline disc for the T-5, but is also 9" for those of you with the 9" flywheels. Or you can of course have your clutch custom made also. I used the factory Volvo pressure plate.
An adaptor plate to match the Volvo bell housing to the T-5. I used www.v-performance.com for the adaptor plate. The plate did not come with bolts, so your standard grade 5, 7/16" course thread bolts is what you need to get. There are 8 total. Also the 4 bolts in the T-5 input shaft need to have the lip ground down so the Volvo bell housing fits flat onto the adaptor, as you can see from the pic below.
Clutch fork modified to work with the Ford release bearing. V-performance also modified my clutch fork. They can set up your cable or hydralic forks.
A driveshaft yoke for the T-5 transmission. I went with the 2 peice Volvo driveshaft and had the Ford yoke mated to it with a U-joint. Vibration isnt an issue and it all fits nicely. You will have to talk to your local drivesahft shop about length. I was told to push the yoke in the trans all the way, pull it out once inch and measure from the center of the U-joint cap on the yoke, to the middle of the center support. Your driveshaft shop amy also be able to get you the correct yoke for the transmission.
The stock Mustang transmission mount for the T-5.
A 4x6" peice of 1/4 inch steel is what i used to bolt the mount to. Basically it gets welded to the Volvo crossmember in the middle. The trans mount will fit just in front of the crossmember, and all you have to do is drill 2 holes into the peice welded to the crossmember. The only problem I ran into here is the trans does not sit perfectly level, so the mount is cocked slightly. I put a few washers under one side to level out the mounting surface, I will soon have to adjust how its setup, im not sure what I will do yet.
Now onto the shifter mystery. Everyone says you have to cut the floor, which I did not want to do unless I had to. Maybe my car is different, but this is what I did. I put the trans in, shifter and all, but no handle on the shifter and no clutch for ease of installation. I saw where the shifter hit the floor, about 2 inches or so in front of the hole. I took the trans back out and took a hammer and pounded on the floor to move it up slightly, and I ground about 1/8-3/16" off the top of the ford stock shifter. I have almost 1/2 inch clearance between the top of the shifter and the floor with the trans fully installed. Now remember your results may vary, the only thing you can do is get it in there, and see where everything is. As for a shifter handle, I went to the local hardware store, grabbed a 3' peice of 1/2 roundbar. Took my torch and got the end red hot, and flattened it with a hammer to bolt onto the ford shifter. I made 2, 90 degree bends. The stock shifter handle goes straight up onto the shifter. I did mine upsidown. Basically the handle looks like a U as you can see in the picture. The bend into the car was not enough, so I bent it a bit more and it's perfect. I went to pepboys, picked up this trick shifter knob with a light up shift pattern it in, put it on the end. Painted the handle Cast Cote color. (its a dark brownish grey) I still need to work out a boot and insulation for the floor. I pull probably get a sheet of rubber and fabricate that, then find a universal boot for the rest.
Overall its a simple conversion, just takes time and money. Fabrication is minimal. I hope this clears up any holes that I noticed in the "acrives" about this swap on the 700/900's
Pic of shifter before floor mod
http://www.we-todd-did-racing.com/we...MXk1NDE%3D.jpg
Pic of floor after hammering
Pic of handle attached to ford shifter
Pic of shifter in floor (I bent the shifter up a bit more to make the handle a bit farther forward
Pic of modded clutch fork
Pic of T-5 ready to go with Volvo bell housing installed
Pic of my shifter at night
Pic of shifter daytime. The knob comes with different size nylon inserts and 3 set screws
Pic of inputshaft bolts ground down
1995 E320 wagon AMG 3.6 swap <-- Daily driver
2009 Honda Fit <-- Wifeys ride
1959 Austin Healey Sprite <--something completely different (my project)
1974 Fiat X1/9 <--Mom's little toy (next project)
1982 Olds Custom Cruiser LQ4 <--Dad's beast (current project)
"Driving the old 2 valve 740 is a bit like driving an IKEA wall unit, so leisurely is its acceleration, so angular its lines."
My former brick saved my life 6/25/03....Volvo for Life
volvorod85 is offline   Reply With Quote
Old 04-09-2005, 08:06 PM   #2
grebnut
TheSlovo
grebnut's Avatar
Very nice writeup! I much appreciate someone spelling it out for the 7 series like you did. Well written and great pictures. Thanks! later,
Ben
Pics
grebnut is offline   Reply With Quote
Old 04-09-2005, 08:56 PM   #3
rallyvovo
ooo, this is a swap that has been lurking in my mind since day 1! Thanks.
:::: 9 series pimpin' ::::
rallyvovo is offline   Reply With Quote
Old 04-09-2005, 11:25 PM   #4
the poi
Has been
the poi's Avatar
quite comprehensive, kick ass work mark. howd it do on the dyno?
Old 04-10-2005, 01:23 AM   #5
volvorod85
volvorod85's Avatar
Dyno results were
158 HP @ about 4700 RPM
220 lb. ft. torque @2800 RPM
Mark
Old 04-10-2005, 01:38 AM   #6
InferiorWang
InferiorWang's Avatar
great write up. I keep thinking that it would be nice to do that swap eventually. I just gotta not be broke before I can get serious about it.
"I like anything fast enough to do something stupid in." - Xander Cage, xXx
InferiorWang is offline   Reply With Quote
Old 04-10-2005, 02:18 AM   #7
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
Originally Posted by volvorod85
Dyno results were
Mark
what boost? mine made 230 hp (4500-6500) and 280 tq, boost was 17psi on the spike, but it droped sharply to 11 before 4000
Megasquirt Tuning!
Old 04-10-2005, 04:24 AM   #8
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
T5 transmission swaps are one of the best upgrades around for manual RWD volvos imo. I was very happy when I did mine.
Old 04-10-2005, 08:42 AM   #9
joereese2
Default t-5 swap
i know its already been covered but on a 240 you dont have to modify the floor or the shifter,right?
joereese2 is offline   Reply With Quote
Old 04-10-2005, 01:56 PM   #10
Two 87s
Default Warning!
I covered the installation of the T5 into a 245 on my website. This isn't so much a plug for the write-up as a warning. I was mistaken on the bolt sizes for two pieces. If you were relying on me for the right info, make a note.
I assumed that the adapter plate from v-performance.com used the Volvo bellhousing bolt size (M10 x 1.5). It does not. The plate is tapped at 7/16" course thread, as the post above states.
If you use the lightweight aluminum flywheel from John Parker, also note that it is tapped at an SAE thread size. I used the Volvo pressure-plate-to-flywheel bolts, and they were the wrong size (metric -- M8, I think).
The result is that my swap has taken much longer. Obviously using the wrong thread sizes causes big problems with stripped threads! The lesson here is not to make assumptions, and to ask questions whenever you don't know something.
My write-up has been updated with this information:
http://www.aaronreedbaker.com/t5swap.html
Be smart and pay attention to details, guys! (Not like me!)
Swallowing my pride,
Aaron
Two 87s is offline   Reply With Quote
Old 04-10-2005, 07:00 PM   #11
volvorod85
volvorod85's Avatar
I too made the same mistake with the adaptor bolt sizes, but quickly realized after the first one didnt thread perfectly, they had to be different. My dyno results were on a bone stock B230FT 3" exhaust turbo to tail, A T03 with a .52/.48 on a ported 90 manifold running 10 PSI. The 3 pulls were in 4th gear, on 91 pump gas. I also have brown top injectors, and there is no O2 sensor right now, so its running default mode on the LH 2.4 ECU which is set up for the stock injectors, so its a bit on the rich side. Still had a little ping as you can hear in the video which i will hopefully post soon, but clears up after id say 4500 RPM. I dont really have a boost spike either, maybe 1.5 lbs at the most, maybe.
Mark
Workin on the insulation for the floor around the shifter, hopefully ill have pics up later tonight.
Old 04-10-2005, 07:03 PM   #12
916volvosport
916volvosport's Avatar
Dyno results were
Mark
sounds like a tired engine or out of tune dunno.. sure it's not 168 or something? :-\
my car: 1981 240 turbo
myspace
this is my signature
***You Are a Martini***
There's no other way to say it: you're a total lush.
You hold your liquor well, and you hold a lot of it!
What Mixed Drink Are You?
http://www.blogthings.com/whatmixeddrinkareyouquiz/
this is the end my signature
916volvosport is offline   Reply With Quote
Old 04-10-2005, 08:03 PM   #13
volvorod85
volvorod85's Avatar
Dyno results are at the wheels...there is a 25-30 HP loss through all the drive train. Stock its supposed to be 162 HP at the crank...i figured with my mods 170-180 HP, therefore about 150 at the wheels...i was pretty close actually
Mark
Old 04-10-2005, 08:05 PM   #14
stylngle2003
stylngle2003's Avatar
~160 at the wheels isnt bad at all for 10psi and a 3" exhuast, 162 is stock flywheel hp...maybe a bit low, but not too bad
15% losses would put that right around 182hp
-Billy
1990 Mazda Miata (track toy)
Old 04-10-2005, 08:23 PM   #15
916volvosport
i pulled 168.6 at the rear wheels that's why i was curious.. b21ft later manifolds 2.5" exhaust piping, 10 psi mitsu 13c turbo.. engine prolly had a couple thousand miles on it since the overhaul..
Old 04-10-2005, 09:12 PM   #16
Boosted2003
Boosted2003's Avatar
I pulled 183whp and 231 torque with 13c at 12.5psi and 3inch exhaust. 201whp and 263 at 17psi.
2006 VW Passat 2.0t 6 Speed - Current
2005 Dodge Magnum R/T - Sold
2005 Dodge Ram 2500 - Sold
1998 Dodge Ram 1500 - Sold
1990 Volvo 760 Turbo - Sold
Boosted2003 is offline   Reply With Quote
Old 04-10-2005, 10:51 PM   #17
boosted12a
weapon of mass detonation
boosted12a's Avatar
this is great! makes me think twice about getting an m90...... are you having any of the vibrations with the 2 piece drive shaft that other people have talked about? im much more apt to spend 1000$ on something i KNOW i can get parts for and replace easly
91 940 SE, 119K, GOLD
05 S80 2.5T, RED
09 XC70 3.2L wifes gas sucking DD, BLUE
04 GTI VR6 (6 gears of fun) Silver
85 RX-7 GSL SE(efi'ed), BLACK
76 Suzuki RE5, BLACK
07 Suzuki SV1000S, BLACK, but turing white slowly
Old 04-10-2005, 11:04 PM   #18
Body Massage
ಠ_ರೃ
Body Massage's Avatar
I thought the M90 was nearly identical to the M55(or whatever the 850 5-spd is) just a RWD tranny and not a FWD one.
But I'd imagine a t-5 swap could easily be cheaper than an M90 swap.
-The other other Dana
Body Massage is offline   Reply With Quote
Old 04-10-2005, 11:22 PM   #19
boosted12a
boosted12a's Avatar
good point, but i can get parts to fix a t5 at almost any local parts store and if i realy trash the tranny, i can get another one from a junk yard the same day
Old 04-10-2005, 11:28 PM   #20
stylngle2003
the M90 and the FWD M56H share the same internals
Old 04-10-2005, 11:52 PM   #21
916volvosport
i never see v8 t5's in the pick n pulls.. the wreckers here buy them out since they have good markup value.. getrag 265s on the other hand can be found easily in sacramento county.. 70-80 a pop for the getrag.. wreckers want a couple hundred for a t5.. i'm jealous that you can get one from a junkyard
Old 04-11-2005, 01:22 AM   #22
volvorod85
volvorod85's Avatar
I dont have any vibration at speed, infact I thought I had a rear wheel balance problem, I could not drive the car over 80MPH with out getting a hellish vibration since i put the tires on...after this swap i drove 100MPH and it felt just like 60MPH. I have a slight vibration on take off, in first gear, much less noticable in 2nd, prolyl cause of the angle of the trans mount.....i think i wrote in the main post its slightly off center, which can easily be fixed by rewelding the bracket on the crossmember, and would prolly solve my take off vibration.
Mark
Old 04-11-2005, 02:29 AM   #23
boosted12a
boosted12a's Avatar
i think the main vibration problem was on decell in gear... but thats great!!!!
Old 04-15-2005, 08:52 AM   #24
str8krewzn
str8krewzn's Avatar
Default T-5 or BMW getreg Witch should i do to my 87 740
Should i put the T-5 in my 87 740 or the BMW GETREG witch is easier and witch is strong anyone help??
str8krewzn is offline   Reply With Quote
Old 04-15-2005, 09:47 AM   #25
302CAMARO650HP
first let me say great job!!!
clean installation and very helpful details on the job
we are looking to do the same swap on Citysurf740's wagon (that is if he ever gets off his ass to work on his car)
anyway, the only thing I would do different is pictured here, I am no expert, nor am I am artitst (as is witnessed by my ****can diagram below)
I tend to drive cars pretty hard and have broken more than one shifter...I borrowed and photoshopped your picture, I hope you dont mind, thought it may be helpful....
if needed I would trim the floor area near the console, above the shifter to compensate, make room for the use of a rectangular type plate for the shifter handle relocation
regards, tim
surf, skate, car pictures at: www.sfaboston.net
302CAMARO650HP is offline   Reply With Quote
