i don't know where to post this so i am starting it here i want to fix up the new volvo i got it is 90 760 turbo (had an 87 760) it just got as new raditor and new injectors ...i want to crank the boost up asap but not sure what steps i should go thru to do this safley this will be my daliy driver til i can afford to buy a turboed 240 ...that one i am going wild with....but i want to acheive 16-18 psi of boost on pump gas and still be ok to drive back and forth to work and such ..i have read alot on this site and just confused information over load ..i will be working at a shop this summer so i can work on my new baby ..should i just do a b23 swap ? any ideals any informaton please help ...thank guys
More capitalization and punctualization will go a long way brother. This is the best all-around resource for what you want. http://www.mcbrooms.com/volvo/fast700.htm Do a tune-up if needed, the rad. and injectors should be fresh like you said, that's good. Before raising the boost, slap on a cone filter, check the compression and turbo, fresh oil, and all the basic systems should be in order. Plan on running premium gas if you want 16-18psi, though 14-15 is probably as far as the stock injectors/fuel pumps will take you. A better/bigger exhaust would be nice, but not necessary. Then get a boost gauge before you proceed. Good luck
mods: ---> to performance Last edited by medfurd; 04-23-2005 at 11:21 PM.. |
Traitor
copy my sig under "old and ugly." but all that was really neccissary for 16 psi was brown top injectors and colder spark plugs. everything else just made the car faster... ha
'92 944 Turbo:13.400@99.68. Sold. '90 744 16 Valve. 16.317@85.55. Sold '92 244 http://pbase.com/740weapon |
#4 |
Ok thanx. i am getting it tuned up this weekend and will plan on a cone filter upgrade. and am looking into a 3" single muffler upgraded exhaust...and ofcourse and a/f gauge and new turbo gauge then a mbc ... is that really all i need to run 12-15 psi ???
#5 | |
The MP
#6 | |
http://forums.turbobricks.com/showth...ight=browntops. LH2.4 will adjust for the increased fuel flow. The guages you listed are good for monitoring and making sure you don't overboost - exhaust will really liven things up in fact you'll find you have more boost with the new exhaust without doing anything. Next upgrade is different turbo - See guidom on this board he sells 15gs already modified to drop right in. Have fun - go to the track and get some times posted. Renny
90 740 T with a dented S90 exterior and interior, front mount fleabay 24x12x3 almost bumper cooler, 3"inch exhaust, IPD springs, Bilstien HD, KG2T cam, LSD, MSD 6A, CFIs @ 46psi, 960 amm, SSautochrome flipped header and Holset hy35 goodness and extra hp in a gymbag.. |
| Thread Tools | |
| Display Modes | |
