Chubfest 2009 Survivor
![]() Join Date: Nov 2002
![]() ![]() 1995 Volvo 850T5R Engine: B5234FT SPM Rods Mahle OS2 pistons RKautotechnik STG3 head (OEM Valve size, ported, polished, 3 angle valve job 44CFM improvement @ .300lift per intake port, 43CFM @ .300 lift per exhaust port) S60R Exhaust manifold (35% gain in flow) GT3071R 63AR 5bolt, small inlet compressor, ATP Ultimate Internal Gate NA cams 960 65mm Throttle Body, Ported intake manifold UR crank pulley, entire rotating assembly balanced to with in .1gram Eurospec T5R Manual ECU (dialed for 550's and an approximation based on mods fuel map) + Civinco BC500 Piggyback tuning system Precision Core custom built FMIC S60R IC upper pipe, 2.5" Hard piping Turbosmart Sleeper Series Megasonic Blow Off Valve Quickbrick Motorsports (QBM) Delrin upper engine mount QBM Polyurathane reinforced upper firewall mount QBM Polyurathane reinforced lower torque mount 3" Downpipe, ATPturbo 3" Cat, 3" Dynamax Bullet Muffler (middle), 3" HKS Carbon/Ti muffler (rear) Eurosport Tuning Intake (Heat Shield, larger K&N Cone filter used) OEM wiring harness converted to MT config Samco Cooling hoses ATPturbo.com Silicone Vacuum lines Gemini Composites Carbon Kevlar throttle and cam covers The entire Motor build, 5spd swap ect blog ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Transmission M56H 5 speed transmission (swapped from the OEM automatic) 850R clutch Suspension/Brakes: RKautotechnik/Kaphlenke Adjustable Lower Control Arms RKautotechnik/Kaphlenke Coil Overs - Custom developed Koni inserts (front) single adjustable - 450# front springs - Koni adjustable rear shocks - 375# rear springs, custom adjustable perches RKautotechnik/Kaphlenke Camber Plates Quick Brick Motorsports Sway Bar End Links Stoptech ST40 BBK 332x32MM 2pc discs (front) S60R 4piston Brembo Rear calipers, 330x28mm rear discs Braided SS lines Dot4 Motul fluid Volvo Pegasus 18x8 Wheels (ET42) Falken Azenis RT615 225/40/18 ![]() ![]() ![]() ![]() ![]() ![]() Stereo: Kenwood Headunit Delphi Roady2 XM unit iPod JL Audio 12W3V2 JL Audio 250/1 JL audio 5.25 (front doors) JL Audio 350/1 Morel Componets (rear shelf and front dash) Infinity Reference 5.25 (rear doors) Strike 1f capacitor ![]() ![]() Interior: Yazaki Gauge Cluster, QBM trim rings EST Short Shifter Momo Combat EVO Shift Knob Momo Suede Shift Boot Lotek 3 pillar gauge pod Autometer Boost, Oil Temp, Oil Pressure gauges Innovate Motorsports XD1 (Stand Alone Gauge kit-Wideband) Factory T5R Suede trim package ![]() ![]() (old pictures) Exterior: Gemini Composites CF/Kevlar piece between the tails iPd mesh grille 5%tint Saab lip spoiler ExExPat'erized Projectors ![]() ![]() Projects Im working on: Over the last two months I've been building, collecting parts and doing a few things. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Dyno Heres the thread: http://www.forums.turbobricks.com/sh...ad.php?t=75131 ![]() ![]() finally a couple nice pictures ![]() ![]() ![]() ![]() ![]() ![]() For more pictures: http://www.pbase.com/dkauer744/1995_volvo_850_t5r Videos
Hank Scorpio is from the Simpsons. You can call me Doug ;) Will trade guitars/guitar parts for go fast goodies or stuff I need. Just PM. www.kauerguitars.com the second best way to upset neighbors and alienate people. History: Car 1 (242) | Car 2 (t5r) | Car 3 (255) Last edited by Hank Scorpio; 01-26-2007 at 01:08 PM.. |
SAAB defector
![]() I love the stereo install, that car is the inspiration for how I plan to install any subs and amps I might get. I heart woodworking, it be a fun time indeed
F*ck the police
![]() You should list "has been driven by Isaac" as a mod.
"If you, the citizen, deliberately vote for someone who won't give you health care over someone who will, you need to have your head examined, except you can't afford to have your head examined." - Bill Maher 1998 Volvo V70T5 1989 Volvo 244DL 1990 BMW 52(3)5i and Matt Dionne still rides with me |
#4 |
An Anomaly
![]() That's worth about as much hp as a ricer sticker. Looking good Doug. I'd put up a project thread for my 744, but it'd just say "pending" for like 17 years....
1994 945ti | 15g @ 15psi, Turbosmart EBC, AEM Failsafe WB, 3"/2.5" exhaust, do88 intercooler, iPd cam, STS cam gear, Ostrich LH tune, sbabbs EZK chip, green giants, K&N, Yoshifab CCV/Can/Cap, iPd SS brake lines, TME, Eibach, BNE, Koni suspension, iPd sways, iPd panhard, TME upper/CT lower braces, forged BBS RG-Rs, Michelin Pilot SS, ecodes, V90 bits. 1985 744ti | 13.8 @ 100.5 mph - Sold after 20 years. ![]() |
#5 |
2nd gear burnouts...
![]() I dont know why you torture me.
man, im really getting annoyed driving around a beatup 242..class and leather T5-R make more sense, and with those mods, corvettes are pish posh.. I still dont see how you can grow out of a done up 242..another enigma of Doug.
81' 242 Ti- 23PSI, 91 B230FT Block, 8:0:1 comp. Built 164 Head w/B230 intake, Port/Polish, Cc'd, 3 angle, Decked, B-Cam, 740 Pumps, 110 octane, PS/AC Delete, Hi-Velocity steel elec. fans...yadda yadda. **Sold and Shipped to Norway** ![]() 92' 244- E-Fan, PS/AC Delete, Cut Springs, Single Muffler-No Cat **Burned to the Ground** Now I drive a Honda Pilot... Last edited by Neil Peart; 06-23-2005 at 10:25 PM.. |
#6 |
![]() Lookin good Doug.
2013 C30 Polestar 1998 C70 Coupe |
#7 | ||
Really?????
![]() Quote:
![]() ![]() really good job on the boot install doug - shows me how mine SHOULD look!! ![]()
#8 |
![]() Thanks guys
![]() Well in one respect, if the part I think is still at my PnP this weekend theres going to be a SEMA car thread starting weeery soon |
#9 |
![]() I guess its time for an update! lol
S60R rear discs/calipers (4 piston brembo's, 328x28mm discs) ![]() Modded CRX projectors ![]() Wideband ![]() Engine bay as it sits atm: ![]() A couple current(ish) pics ![]() ![]() ![]() Couple of pics of the new projects ;) ![]() ![]() ![]() ![]() :D |
#10 |
has a large member
![]() Nice smile. You should paint over the Porsche logo on the front calipers. Just doesn't seem right haha. I'm interested in those CRX projectors. How did you do that?
#11 | |
![]() Quote:
#12 |
has a large member
![]() What's wrong with that? I wouldn't want it to say Porsche on my Volvo, even if the calipers did come from a nice porsche and they are better brakes.
#13 | |
![]() Quote:
#14 | |
Barbie Ken
![]() Quote:
But it's your car. ![]()
#15 | |
![]() Quote:
#16 |
![]() Put "Hyundai" on the front calipers.
- Patrick 83 244ti - rally 73 1800es - resto mod cruiser 83 244ti - road race 79 262c - road race in the works 08 c30 T5 - daily recce car - M66, Lifted 1.5'', 215/65/16 Falken All Terrains on Method MR502's, iPD skid plate 97 Dodge Dakota 5.2 4x4 70 Ford F100 2WD 351M/C6 |
#17 | |
![]() Quote:
#18 | |
![]() Quote:
![]() ![]() ![]() ![]() btw, did a new gauge cluster setup today ![]() ![]() |
#19 | |
Barbie Ken
![]() Quote:
#20 | |
![]() Quote:
#21 |
![]() Got bored and reversed the trim bezels on the cluster today.
![]() I like it more this way me thinks |
#22 |
Barbie Ken
![]() Much bettar!
WTF? 1.59 and there's sun? Stupid AM/PM clock ![]() |
#23 | |
![]() Quote:
#24 |
OG 5EURO OG
![]() those trim rings look so much better reversed than regular ways. kevin did that with his, right?
2006 Tundra ![]() |
#25 | |
![]() Quote:
