Old 06-22-2005, 01:33 PM   #1
cid499
Default what noise does a broken strut mount make...
A couple months after installing B+G springs and bilstein TC's in my car, the front end started to squeak. Not a high pitched squeak, but like a groany squeak when I go over speed bumps at any speed.
I'm going to hav the control arm bushings replaced soon, but I wonder if I should go ahead and have the strut mounts done too. Do broken strut mounts groan? And how much should I expect to pay for labor for having the strut mounts/control arm bushings done?
cid499 is offline   Reply With Quote
Old 06-22-2005, 01:57 PM   #2
r3ckl1ss
r3ckl1ss's Avatar
strut rod or mount?strut rod will make a clicking sound every time you hit a bump. im not to sure on a strut mount though
high on boost
r3ckl1ss is offline   Reply With Quote
Old 06-22-2005, 08:43 PM   #3
18yr240t
18yr240t's Avatar
It might just be your sway bar bushings at the " frame" mine groans ther once in a while.
83 242ti Flatnose. New project much work to do...
18yr240t is offline   Reply With Quote
