Old 06-22-2005, 11:18 PM   #1
Volvo740Ti
Volvo740Ti's Avatar
Default A/C Question
I'm new to this thing called Air Conditioning, But in my 92 960, is it normal for the 2 outside vents to be colder then the ones above the radio? They seems a good couple degrees hotter then the smaller ones on the outter edges of the dash. Oh and do i have R134? Theres a stamp on top of my A/C Can by the firewall that has 1999 on it, Dunno if it was replaced then or if thats when they changed to 134
Any Idea's?
H22 VX Hatch, LSD M2B4 Trans, CAI, DC Sports 4-2-1, Test Pipe,
3" Catback Exhaust With Vibrant Flat-Black Muffler, Skunk2 Cam Gears, Tuned on Crome Pro
187whp/148wtq All Motor
251whp/209wtq Nitrous
Mustang Dyno
Volvo740Ti is offline   Reply With Quote
Old 06-22-2005, 11:25 PM   #2
Three Fat Tigers
Three Fat Tigers's Avatar
Location: ↓ Lynchburg, VA →| '84 242Ti | '90 760Ti | '92 240 | '94 940T | '96 960 | '96 M1
Center vents hotter= not normal, dont know what the issue could be.
R134: you should have a sticker under the hood some where that states it was converted. Otherwise if your dryer or whereever you put your freon in (could be at the compressor) has exposed threads then it's likely still R12.
Three Fat Tigers is offline   Reply With Quote
Old 06-23-2005, 01:02 PM   #3
945TurboTwins
Board Blue Devil
945TurboTwins's Avatar
I've got the same center vent hotter issue. Not hot, just not as cold as the outer ones.
Chris
'95 945T - 102k miles...11 psi.....ipd Turbo Cam....
945TurboTwins is offline   Reply With Quote
