Old 07-05-2005, 04:55 PM   #1
JayPSC
JayPSC's Avatar
Default Permatex Copper gasket Spray in UK
Right my head gasket has blown AGAIN by the looks of it as I'm getting exhaust gas bubbling up through the header tank :(
I wanna make sure it doesn't happen again so I wanna do it with Permatex spray or something similar this time, but where the hell can I get some of this stuff in the UK??
Jay
'89 760 - B230ET - MS - EDIS - CFI injectors - N2O - 3" Side exit - TXS BOV - Veilside - Greddy B-Spec II - Induction
'92 Corrado G60
'92 Nissan 300ZX TT
RCR GT40 ordered
Wideband tuning software VexME
JayPSC is offline   Reply With Quote
Old 07-05-2005, 05:33 PM   #2
suterman
suterman's Avatar
Default not sure
but I`d get a proper gasket set. you`ll need intake and exhaust gaskets and a cover seal too. cost about 40 to 80 quid from partco or similar or volvo garage
1985 Bedford cf. B230e aw71L
1990 240 turbo. b230ft m47 chips
suterman is offline   Reply With Quote
Old 07-05-2005, 05:57 PM   #3
JayPSC
JayPSC's Avatar
Yeah I'm gonna get another gasket set (even though these have only been on there about 2 weeks) but I wanna make sure it doesn't blow again, hence why I wanna spray the HG with Permatex first.
Old 07-06-2005, 07:43 AM   #4
foxtrapper
Carefull, depending on the type of gasket, you'll make it blow with the spray on stuff. Get the head and block checked to make sure the mating surfaces are truly flat. Then, install a good gasket, but do it the way they say to do it.
foxtrapper is offline   Reply With Quote
Old 07-07-2005, 06:41 PM   #5
suterman
suterman's Avatar
Default head
make sure the heads in good nick too check around the hole on the mating surface my one is wrecked and I need a new one . we should start a uk head changing club. hahahahaha.
Old 07-07-2005, 06:59 PM   #6
MikeHardy
The Sirius/Nova Police
MikeHardy's Avatar
mine will be going on soon, but by choice not because it blew
MikeHardy is offline   Reply With Quote
