Old 07-13-2005, 02:40 AM   #1
the poi
Has been
the poi's Avatar
Default Make your 960 ridiculous: Put some paddle shifters on it!
Why?
960's are really slow, thats why. I'm slapping a turbo on mine and Megasquirting it. This means Motronic is out, along with its coded load signal and various torque limiting response commands. The stock transmission controller being as nervous as it is, won't enjoy working without the motronic box, and I didn't really feel like spending a lot of time analyzing the signals simply to replicate stock performance.
So, the obvious solutions is hijackign the electronic controls that cause the problems in the first place, and shift it manually. Naturally, flappy paddles will be the ideal control mechanism.
Also, they look rockin'.
Why not a manual?
Two major reasons: I live in LA, and I like brake boosting. Most people will never understand the concept of LA traffic without actually living here. The idea of pushing in and out on a clutch pedal for literally an hour without ever touching the stick is an experience I'd rather avoid. And as far as brake boosting goes: this car is going to see a lot more drag-strip time than road racing time, and being able to leave the line with a few pounds of boost is something I like.
The other problem is the cost. I don't want to spend a grand or so to get an M90 over here and install it, and get something I wasn't really looking for in the first place.
And hey, how many people have paddle-shifted a 960, eh?
What needs to be done...
Cooling
If I take over the TCM's controls, the lockup clutch will no longer be constantly popping on and off to control heat production of the relatively high stall TC (2700 rpm). Also, when decellerating or bogging the motor in heavy traffic, it's going to heat up, and I'd like capacity to cool it down and a way to keep an eye on it.
Lets start with the gauge, and AutoMeter Cobalt trans temp. It's purdy! (and won't be alone for long). Here's a horrible looking picture in its equally horrible looking temporary mount (sharp-eyed readers will note that that is the box it came in )
Fantastic, now where do we put the probe? The stock location would be the best, right on the exit to the cooler, the hottest point. Should be easy too. Here's how to install it:
Get a 14mm bolt, and chop it down so its short. Drill a hole in its middle and tap for the 1/8NPT thread that's on the autometer sensor. Screw the sensor in real good, and yoink the o-ring off the stock sensor.
Now screw onto the fancy adapter Volvo uses that the stock sensor T's into:
Here it's installed with the stock sensor hanging forlorn next to it, cleary upset at its removal:
Now that that's taken care of, lets put in the biggest B&M trans cooler Jeg's sells. Here's a nice spot for it:
Route the rubber lines that come with the kit through the hole conveniently left from aw71 days:
And connect them to some shiny AN fittings. There's two here, a 6AN to hose barb fitting, connected to a 6an to 3/8" tube fitting. These use compression fittings, so it's a matter of cutting the tube cleanly and clamping the fitting on.
Speaking of that tubing... Go down to NAPA, spend 15$ on two 3/8" 5ft lengths, and get to work with your bare hands and a cheap tubing bender. Here's how I fit mine. Re-using stock lines won't be the best for turbo projects, as stock, they come flying up from under the car and go straight through the prime turbo real estate before dropping to the radiator. Pretty dumb really.
And finally, the trans. I re-used the metric flare fittings, just slipped them over the cut end of the lines (make sure to do this before you start bending ) and they seat against the flares that come on the lines. With the pre-flared lines and the compression type AN fittings on the other end, you don't have to hand-flare a thing!
The electronics!
This is where the fun happens! First, gotta figure out how you want it to behave. I settled on slapping the paddles from 1st to 4th and another "upshift" will engage the lockup clutch in thr torque converter for cruising. The line pressure solenoid will be left disconnected, meaning line pressure will be maxed. This will probably mean harsher reverse and drive engagement, but it shouldn't hurt anything and it will save me a hell of a lot of development.
I was starting from scratch, so I needed to start with some manuals. Thanks to tjts1 (who I generally refer to as "tits" cause really thats what it looks like) I got this helpful info straight from Volvo: http://caunter.ca/volvo960/ce14807.pdf . So the control algortithm is pretty simple:
With the PNP switch not in a "Drive" mode, set to 1st gear. In a drive mode (D,3,L), turn on the paddles. Set the shift solenoids as needed for each gear. Pretty simple algorithm.
But how to get that to happen? I looked into using basic components and IC's (counters and the like) but it was pretty much over my head, and I realized that this is the perfect project for a microcontroller. So thats what I got, in the form of a BASIC Stamp from www.parallax.com . I've heard of stamps before, never used one before though. The code is really easy to use though, and within a couple hours of downloading the compiler, I had the controller code roughed out.
Here's what I eventually came up with:
[code]
' {$STAMP BS1}
' {$PBASIC 1.1}
'The Poi's (Chris Wiita's) AW30-40 paddle shifter code
'v1.1
'I/Os:
' 0 is Upshift button input - set to input with BUTTON function
' 1 is Downshift button input - set to input with BUTTON function
' 2 is Solenoid 1 - engages when 1
' 3 is Solenoid 2 - engages when 1
' 4 is Lockup Solenoid - engages when 1
' 5 is Ground for "drive" funcitons of PNP switch. When grounded, flappy
' paddles work. Whenever it loses ground, switches back to 1st
'Shift Table:
' Gear Sol1 Sol2 TCC
' 1 1 0 0
' 2 1 1 0
' 3 0 1 0
' 4 0 0 0
' 4+TCC 0 0 1
' "1st Gear" for P N and R.
SYMBOL Gear = B0 'Current gear
SYMBOL UpBtnWrk = B2
SYMBOL DwnBtnWrk = B3
SYMBOL DriveBtnWrk= B4
UpBtnWrk = 0
DwnBtnWrk = 0
DriveBtnWrk = 0
'Start in first gear
Gear = 1
GOTO SetGear
'Start loop by checking that PNP is in drive mode, if its grounded, start loop,
'otherwise, set gear to 1, keep checking till drive
ChkDriveBtn:
BUTTON 5,0,255,0,DriveBtnWrk,1,Go
PAUSE 100
Gear = 1
GOTO SetGear
'Clear button work so it keeps checking if its down, chk upbtn
Go:
DriveBtnWrk = 0
GOTO ChkUpBtn
'Check up button, if grounded, upshift, else, check down button
ChkUpBtn:
BUTTON 0,0,255,0,UpBtnWrk,1,UpShift
GOTO ChkDwnBtn
UpShift:
Gear = Gear + 1
GOTO SetGear
'Check down button, if grounded, downshift, else, check drive button
ChkDwnBtn:
BUTTON 1,0,255,0,DwnBtnWrk,1,DownShift
GOTO ChkDriveBtn
DownShift:
Gear = Gear - 1
GOTO SetGear
SetGear:
BRANCH Gear, (SetGear0,SetGear1,SetGear2,SetGear3,SetGear4,SetG ear5,SetGear6)
SetGear0:
Gear = 1
GOTO ChkDriveBtn
SetGear1:
LOW 4 'Lockup
HIGH 2 'Sol1
LOW 3 'Sol2
GOTO ChkDriveBtn
SetGear2:
LOW 4 'Lockup
HIGH 2 'Sol1
HIGH 3 'Sol2
GOTO ChkDriveBtn
SetGear3:
LOW 4 'Lockup
LOW 2 'Sol1
HIGH 3 'Sol2
GOTO ChkDriveBtn
SetGear4:
LOW 4 'Lockup
LOW 2 'Sol1
LOW 3 'Sol2
GOTO ChkDriveBtn
SetGear5:
HIGH 4 'Lockup
LOW 2 'Sol1
LOW 3 'Sol2
GOTO ChkDriveBtn
SetGear6:
Gear = 5
GOTO ChkDriveBtn
[/code]
And a short vid showing how the solenoids work with each shift: < Dead! >
Now, the outputs are controlled by logic level outputs, so I need to step up the power with some transistor switches. The tricky thing is that i need to send 12v to the solenoid, which requires a PNP/NPN circuit. Got some help from usegroups, and figured out the output circuit I needed to use for each of the solenoids.
edit:// I ended up switching the circuit to something a lot simpler. Just use high-side switch ICs, and just wire the output to the HSS input, and have at it. I used Infineon BTS409L1IN
The next challenge was managing to fit all the components onto the pretty limited proto-space on the Stamp project board... but I did get it, and put the whole thing in an attractive case.
The frickin paddles!
So now we need something to slap when we want the gear to change. I decided to mount the assembly fixed to the steering column (not the wheel)-- seems more comfortable to me, as I always know where the paddles are. Unfortunately, there is no room really in the plastic case around the column to fit much of any mechanism, so I had to figure out something else. After a failed attempt at moutning something on the bottom, and another failed attempt on the top when using simply the wrong hardware... I settled on this trippy in-line skate bearing voodoo:
Some description: The arms come out slots through the side, and are bolted to the bottom of the bearing. The actuator arms are on top (obviously). The nut is a ny-lock, and I slotted the bolt so i get hold it with a screwdriver while tighetening the nut. This lets me adjust the angle between the actuator arm and the paddle arm with the column completely installed.
I put the pivots out as far as possible and the buttons all the way in. This minimizes mechanical advantage, which reduces the throw of the paddle and makes it harder to pull (resulting in a snappy, quick, and positive pull).
The switches are NO microswitches that give a good positive click when actuated. The result of all of this makes for a very smooth actuation, with essentially no drag-related resistance.
Now we get to posistion the arms, which was a right bitch really. There's very little wiggle room with these things. You have to make sure both stalks still work, and the wheel doesn't contact anything during turns. After some time with cardboard models and a lot of swearing, I got this:
And now to make it all artistic and crap!
Here's what I came up with:
Rockin'.
The paddles came from Home Depot... sorta. Started as 3in by 3ft 1/8" aluminum. After some more cardboard models, I cut the rough shapes out with my angle grinder, filed down the edges, and got to work. I ground the edges round with a Dremel with a sanding roll, and finished them with a wetsanding from 100 to 400 to 600 grit. They look great, and aren't shiny so they won't blind you if they catch the sun right .
They're mounted with 10/32 SS cap screws, cut and smoothed flush with the mounting point.
Those mounts were also kinda annoying. Had to weld em on with a MIG welder, and they're only about 3/4" . Once I got the welds down, I ground them smooth. Then the whole thing got sanded and painted with engine enamel. The holes are drilled and tapped to recieve the moutning bolts.
And that's that. Still need to figure out something to cover the mechanism. I have a good plastic case, but I think I'm going to want to incorporate some nice leather on it somehow...
Some finished pics:
Well then... how's it work?!
It's ****ing fantastic.
I never knew you could have so much fun with a mere 200hp and 3700lbs of bulk It's just like a manual as far as putting it in the right gear, so it's pretty damn awesome. The shifts are as fast (as slow...) as full throttle shifts on the stock TCM, so theres a about a half second delay. I could "fix" this by shimming up the accumulators a bit... but I'm afraid of getting too greedy and breaking something. It's awesome as it stands though.
Highway driving is great: no traffic means leaving it in 4th+L, light traffic means a but of shifting between lockup and no lockup, but it's not a problem at all seeing as its just a tap of the paddle. Heavy traffic is way better than witht he auto, which seemed to always pick bad gears, and always making it lug around and making throttle response nonexistant before slamming it into third and shooting you foward. I can keep it in 3 and crawl along without having the annoying lug. Stop and go traffic is just as easy. Leave it in 1st, with the occasional slap into 2nd.
City driving is hilarious, and I'll probably end up with several tickets because of it. I'm probably burning through oil now seeing as I love keeping the big sewing machine at atleast 3 grand .
To conclude: **** ya.
edit:// ya ya, I'll get video sometime My vid-capable camera is 100 miles away!
Old 07-13-2005, 03:13 AM   #2
tjts1
tjts1's Avatar
Thank you thank you thank you thank you. Looks like I have a long weekend ahead.
Greed is good.
tits for president
tjts1 is offline   Reply With Quote
Old 07-13-2005, 03:16 AM   #3
Marvelous3
Who engineered this?
Marvelous3's Avatar
That's the most amazing thing I've ever seen! This topic deserves a sticky like no other!
Are you considering maybe selling portions or all of this kit to the rest of us?
Marvelous3 is online now   Reply With Quote
Old 07-13-2005, 03:21 AM   #4
tjts1
tjts1's Avatar
You realize this would also work on an 850 turbo or R? The trasmission control is exactly the same. I like the way you set up the relay. Thats the part I was missing. Also the torque converter lock up as 5th gear is very elegant. Sure beats my separate switch idea. I think I'll skip on the paddles and just use sterring wheel mounted buttons. And I still want to be able to use it as an auto trasmission. damn. Well I guess its time to bust out the old 8051 again.
Thanks again for the write up. Also yes it is TITS. Most people don't get it. Even my professors. But you can call me Justin.
Old 07-13-2005, 03:24 AM   #5
Marvelous3
Marvelous3's Avatar
I was thinking the exact same thing...Do you think this would work on my 40? If so, omg this bring all new life into my car.
Old 07-13-2005, 05:30 AM   #6
Darmo
hurray
Darmo is offline   Reply With Quote
Old 07-13-2005, 05:31 AM   #7
volvorsport
price please ?
muhahhahahhhahhaha !!!!!!!!!!!!!!!!!
volvorsport is offline   Reply With Quote
Old 07-13-2005, 05:58 AM   #8
dirtbike
cutting, welding, bashing
Well done Chris this is f**king awesome!
Crazy mad props to yo mofo!
Am I right in thinking that the belhousing is removable on the AW30-40?
It sure looks like there is a split around the bellhousing, if so there is potential to put one of these behind a redblock?
Laters
Nick
Volvord Project Thread :http://forums.turbobricks.com/showthread.php?t=184497
1972 Mk1 Escort, B230, 16v, T5/4L60E, 8" Axle, KMS MD35, AIM EVO Datalogger
"Volvord MK1 Escort Project" : http://www.jwbr29544.pwp.blueyonder.co.uk/escort
dirtbike is offline   Reply With Quote
Old 07-13-2005, 06:12 AM   #9
740Weapon
Traitor
740Weapon's Avatar
someone is going to steal your car thinking the paddle shifters are a simple bolt on for any transmission and car.
'90 744 16 Valve. 16.317@85.55. Sold.
'92 244. Sold. http://pbase.com/740weapon
Old 07-13-2005, 07:32 AM   #10
volvorsport
nick , the bellhousing does indeed seperate . Didnt they come behind redblock cars anyway ?
Old 07-13-2005, 07:40 AM   #11
RedFridge
RedFridge's Avatar
What a great job....thank you for the writeup and the pics.
I also thank you for introducing me to some new tablecloths.
You score high on the Invento-meter.
Bravo.
RedFridge is offline   Reply With Quote
Old 07-13-2005, 08:07 AM   #12
Volvo740Ti
Volvo740Ti's Avatar
this is what i have been waiting for. You complaints are exactly as mine about the 960 but your solution is fantastic (mine was deal with it). I am also one to agree on how much to get one made? absolutly fantastic
H22 VX Hatch, LSD M2B4 Trans, CAI, DC Sports 4-2-1, Test Pipe,
3" Catback Exhaust With Vibrant Flat-Black Muffler, Skunk2 Cam Gears, Tuned on Crome Pro
187whp/148wtq All Motor
251whp/209wtq Nitrous
Mustang Dyno
Volvo740Ti is offline   Reply With Quote
Old 07-13-2005, 08:58 AM   #13
pwschuh
Rolling...
Chris, you're awesome. Thanks for the great write-up and for tackling an exceptional project that will be useful for the many autobox owners out there.
"No man would listen to you talk if he didn't know it was his turn next." E. W. Howe
Old 07-13-2005, 08:59 AM   #14
Matt Dupuis
Matt Dupuis's Avatar
Damn, Chris - I've been watching your project casually, but I've got to say that you've certainly pulled the big kahuna whiz-bang mod of 2005!
[eyes up wife's 855t]
Matt Dupuis is offline   Reply With Quote
Old 07-13-2005, 09:06 AM   #15
choice_of_beverage
choice_of_beverage's Avatar
well i didn't understand any of that write up except for "paddle shifters" and i think thats enough for me. awesome job man. very nice.
john-lee
- John-Lee
Silver 1992 244
1981 244 Turbo intercooler
choice_of_beverage is offline   Reply With Quote
Old 07-13-2005, 09:21 AM   #16
Fastmoving?
That´s a serious and cool modifikation, never heard anyone in Sweden wanting to try that.
Fastmoving? is offline   Reply With Quote
Old 07-13-2005, 09:38 AM   #17
resa850
QOPregnancy
resa850's Avatar
Holy **** man thats incredible!!! I am beyond impressed (not that Im never not) flat out incredible!
Hmm... now running EMS on a 850 and using this for the transmission control seems like an intresting way to go!
resa850 is offline   Reply With Quote
Old 07-13-2005, 09:41 AM   #18
dirtbike
From what I could see in Vadis the red blocks got lumbered with the AW71, only the white blocks had the AW30-40. But it would be nice if I'm wrong.
Laters
Nick
Old 07-13-2005, 09:50 AM   #19
olov
doing something stupid
so all you need is an electronically controlled auto box? mmmmmm
great writeup, you are the man
hip hip....
Old 07-13-2005, 02:52 PM   #20
great write up, if you need some help packaging it let me know i may be intersested in coming up with something for yah.
my moms got a 960,,,
oh the ideas oh the ideas
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 07-13-2005, 03:17 PM   #21
cst805
is so rude.
cst805's Avatar
Its been said before, but damn nice work. I know what the S90's getting in the event this fookin GT ever gets finished. So you gonna start makin kits?
cst805 is offline   Reply With Quote
Old 07-13-2005, 03:29 PM   #22
nohbudi
Jesus Christ...
nohbudi's Avatar
Has anyone ever tried to bolt an aw71 bellhousing to a aw30-40?
Originally Posted by MacRaperLinuxBoy View Post
Can I convert my car 740 to front wheel drive? I really want to keep my PRV so please suggest ways of converting my car to FWD while retaining my Renault motor.
nohbudi is offline   Reply With Quote
Old 07-13-2005, 03:36 PM   #23
Manbeard
OG
Manbeard's Avatar
do you still have to use the stock auto stick for park and neutral?
2006 Tundra
Manbeard is offline   Reply With Quote
Old 07-13-2005, 03:46 PM   #24
Marvelous3
Marvelous3's Avatar
It sounds like the paddles don't come into play until the car is put in "D". So Park, Reverse, and Neutral all work with the shifter.
What do you think I would need to adapt this to my S40?
Old 07-13-2005, 03:49 PM   #25
acbarnett
SAAB defector
acbarnett's Avatar
that really rocks, and my mom may well be getting a 960. Between the t6+m90+IRS for the 944, the various v8/SHO v6+TT+MS ideas I've been tossing around for the red 945, and the fact that my mom is looking to get a 960/v90, it looks like I will be needing alot more money for the coming year.
acbarnett is offline   Reply With Quote
