Old 09-06-2008, 11:43 AM   #26
SL8Brick
yea, I'm THAT guy
SL8Brick's Avatar
Well, you know what they say about opinions.......
Here's mine:
On non-lowered 245s, I believe 205/65R15 would be the most logical choice to maintain OE sidewall height and minimize speedo error. If I had Virgos(or any other 15" wheel for that matter) that's the size I'd choose.
1993 240 Wagon - 326k miles
1999 Audi A6 Avant 2.8 Quattro - 134k miles
SL8Brick is offline   Reply With Quote
Old 09-06-2008, 12:11 PM   #27
towerymt
the real Towery
towerymt's Avatar
205/60 is not so great on a Virgo because the wheel is only 6" wide, so the tire is not well supported by the wheel. I just had 205/60 put on my 7" wide MSW wheels, and the sidewall is straight. The tire fits well on a 7" wheel. I also wouldn't personally choose 205/65, because even more sidewall on a 205 on a 6" wheel is going to have poor steering response. If you don't mind that feeling, 14" wheels/tires are cheaper.
185/70/14 5.5"x14" to 195/60/15 6"x15" was a nice improvement on my car. 205/60 on 7"x15" is another step in the right direction while still maintaining a rather tall tire with a lot of sidewall.
Old 09-06-2008, 01:40 PM   #28
SL8Brick
yea, I'm THAT guy
SL8Brick's Avatar
towery, I'm aware we're coming from different camps(and I do value your opinion)...but most tire mfgs specify a rim width range of 5.5"-7" for 205/65R15. Granted, the 7" wide wheel will offer better support but the tire can be safely mounted on narrower rims. And wouldn't you agree that the steering response, overall lateral traction, and braking distances would be measurably improved when comparing the OE size of 185R14 to 205/65R15(regardless of rim width...within reason)?
Old 09-06-2008, 03:15 PM   #29
Krisverde
Krisverde's Avatar
I run 215/60's with no problems at all. Smooth ride for me, and my car is a cruiser.
Oh and I have no speedo errors either, i've driven buy one of those things that register your speed and it matched with the speedo.
1989 Ford f150 5.0
1991 Ford f150
2013 Ford Focus ST
Krisverde is offline   Reply With Quote
Old 09-06-2008, 03:57 PM   #30
Flux88MPH
Flux88MPH's Avatar
Originally Posted by comforteagle04 View Post
What size tire is a good fit for the virgo rims?
Originally Posted by Marlboroman View Post
195/60/15"
The wheels on mine are the same size as Virgos and are 195/60/15 Bridgestone Potenza G019
Around $300 total for the set of 4.
Dave Campbell
Austin, TX
Volvos:
1998 V70 T5 (Mine)
2004 V70 2.5T (Wife's)
Editor - Smells Like Screen Spirit
Flux88MPH is offline   Reply With Quote
Old 09-06-2008, 04:15 PM   #31
towerymt
the real Towery
towerymt's Avatar
I went to 15" wheels to get a smaller sidewall with a similar overall diameter. 205/65 wouldn't do it for me, but maybe wagon owners might like it. I'd still choose anything bigger/wider than the 14"s just for braking. However, I wanted to improve transitional response as well as grip.
Most people may not use the extra grip and response on a daily basis, but if you ever have to avoid accidents or deer or anything else, it's nice to be confident in what the car will do when you have to use it. I just practice it more than most do. Shocks/struts and tires are the two most important upgrades I've made that have changed how the car feels.
My dad uses 215/60/14 on 14x6 (mk3 VW Golf). They have more grip than the 185s or 195s that came on the car. But it doesn't FEEL good to me when I drive it. High speed sweepers on the highway took some getting used to. The tire bulges over the rim. The rim width is within the manufacturers range, but it would perform better with a wider wheel.
Old 09-06-2008, 05:28 PM   #32
daijoubanai
waste of skin and blood
daijoubanai's Avatar
if you're not lowering your car, go with 195/60/15. seriously, its a good choice.
daijoubanai is offline   Reply With Quote
Old 09-06-2008, 05:32 PM   #33
Jerd
Jerd's Avatar
I have 205/55/15's on my dracos
my track tires are 205/50/15's i really dont recommend this size for street because freeway driving your at about 3,200 rpm with an m47
general uhp 205/55/15
Old 09-07-2008, 11:34 AM   #34
J_Westy
Thanks for the pictures everyone.
Definitely between the 205/55 and 195/60 for me so far.
J_Westy is offline   Reply With Quote
Old 10-12-2009, 01:09 PM   #35
McBlaze
Default will a set of virgo rims fit on a 1990 240 dl?
I just bought a 1990 240 DL and was thinking about getting a set of virgo rims, does anyone know it they'll fit?
McBlaze is offline   Reply With Quote
Old 10-12-2009, 10:36 PM   #36
Crazychopstick
(/// _ - )
Crazychopstick's Avatar
Location: Receiving Transmission from David Bowie nipple antenna
Yesh.
Crazychopstick is offline   Reply With Quote
Old 10-12-2009, 10:39 PM   #37
GhengisKhan
Yesh.
GhengisKhan is offline   Reply With Quote
Old 10-12-2009, 11:21 PM   #38
SLOTh_244
Originally Posted by crazychopstick View Post
yesh.
Originally Posted by ghengiskhan View Post
yesh.
lolz
SLOTh_244 is offline   Reply With Quote
Old 10-12-2009, 11:22 PM   #39
Kind of a shot in the dark without intended purpose.
For practical purposes,to get a 25" wheel,and to keep the wheels from getting bent,
as they often do with the stock size,I use Falken Ziex 912's in 195-65-15.
Steering feels right,economy is good,the car really rolls,and they stick pretty good for touring tires.
Photobucket
how psi a stock can support?
Old 10-12-2009, 11:34 PM   #40
morganpartee
I'm running 205/50's, and I like them. They look good, and handle a little better than the taller sidewall tires I had.
Pictures in my thread! =D
Finally back in the 740 game.
morganpartee is offline   Reply With Quote
Old 10-12-2009, 11:43 PM   #41
Crazychopstick
(/// _ - )
Red, that was 6 years ago.
I'm sure he's already put tires on his Virgos.
Old 10-12-2009, 11:45 PM   #42
Old 10-12-2009, 11:46 PM   #43
morganpartee
Wow, I didn't read this thread very well... I think this is its fourth resurrection?
Old 10-12-2009, 11:47 PM   #44
Thumbs up
I did,but thought it would be fun to beat it to death.
Old 10-12-2009, 11:48 PM   #45
morganpartee
So guys... Same place in a year?
Old 10-12-2009, 11:50 PM   #46
Crazychopstick
(/// _ - )
Deal.
Old 10-12-2009, 11:52 PM   #47
Yesh.
Old 10-12-2009, 11:52 PM   #48
Crazychopstick
(/// _ - )
Yesh.
Old 10-12-2009, 11:54 PM   #49
morganpartee
Hmm... http://www.bored.com/emailcapsules/
I'll remember.
Old 10-13-2009, 12:03 AM   #50
brakedust
brakedust's Avatar
Anyone recommend a tire? I live in michigan and am not putting winters on this year. So I need an Affordable all season. Ive Looked at the Michelin Primacy MXM4 & Yokahama Avid H4s. I've decided on the area of 195 60 15. Virgo rims.
I like good wide grooved rain tires cause they work well in the snow as well. but.. I don't want to spend to much$$$ for the Traction/safty. I kind of enjoy a good 50mph snowy drift! I wish they made a good All season set for $320...
brakedust is offline   Reply With Quote
