On a mission
Okay, since I started the header I guess I'll start a thread. Anyway, idea:
![]() Parts: ![]() First, cut all the bends to the right radius. 10 of the 20 bends are 90* so hey, easy. The other 10* are cut thusly: ![]() 200$ harborfreight bandsaw. fantastic! ![]() Set the angle on the frame, tape the frame down. Set elbow in the "box" and clamp it down. ![]() Fancy! ![]() Holy macaroni! Next up, straight pipes cut to length and I mark all the pipes with their mating angles. Then I simply weld it together! ![]()
unbalanced chemical
![]() Join Date: Jun 2002
it'll never work
looks pimp
![]() Chip Feedback Thread / PM Current Chip Prices / PM for DownPipe & Exhaust Price / Silicone Cooling Hose Sets 2/7/9
He who controls the Spice
So wheres your flange
*whistles* |
#4 |
what? a band saw? you're cheating! j/k
looking good so far. what wastegate are you planning on running?
-jesse 1971 142e 16v/MSNS/m47/18" Kinesis K20s etc 1988 244dl 16v+T/18" HREs/ corbeus / MSNS etc "...i often drift when i drive..." - the ghetto boys newest pictures here:https://www.facebook.com/pages/J9Fab/399942106768777 and lots of old ones here:www.pbase.com/jaodesign/jesse |
#5 | |
On a mission
#6 |
ARRRRHARHAR
![]() Join Date: Dec 2002
anyone else had issues with their tial creeping? mine creeps like a bitch in 4th, starts at 7, by redline its at 14 (this is a big problem when your injectors are at 135% DC by 6800 rpms). open dump no bleeder or anything, 7.5 spring.
sorry, thread jack. looks good, get er welded
"They bum rushed them in their own crib, they drank all their beer, they partied with their ladies and they left with the trophy" Megasquirt Tuning! Plug and play LH 2.4 Megasquirt, now with stealth mode! ported volvo heads |
#7 | |
On a mission
#8 |
lookin good so far man, keep it up
-Billy 1993 945ti "titebox" (DD) 1985 744GLE (perpetual +t project) 1996 Chevrolet Tahoe Vortec 2WD 1990 Mazda Miata track toy |
#9 |
There's a gif for that.
It'll never...
...err... ...weld. |
#10 |
Spool. The word you're all looking for is spool. The exhaust manifold will never spool.
Evan 1996 850T - Bilsteins all around, a homebuilt MBC, Samcos, backcut SS valves, and R manifold, and an obscene amount of luck. Have owned: 1996 960 - Totaled |
#11 | |
![]() Looks good dude.
![]() 1995 855T - stock, for all intents and purposes |
#12 | |
But it'll never weld. |
#13 |
Looks hot man... When are you going to start releasing paddle shift kits? I'll mail you my car so you can test one on a 240 wagon
#14 |
![]() Join Date: Jul 2002
Looking good,
Sometimes simple methods can yield get products with some time thrown in for finishing work. How do you plan to tackle the collector portion? |
#15 | |
ARRRRHARHAR
#16 |
Chubfest 2009 Survivor
![]() Join Date: Nov 2002
My tial was ALWAYS rock stable. +/- 1 psi.
What boost controller setup are you using (if any)? Chris, make sure you use a flex joint on the downpipe and the wastegate (either before or after doesn't matter)
Will trade guitars/guitar parts for go fast goodies or stuff I need. Just PM. www.kauerguitars.com the second best way to upset neighbors and alienate people. History: Car 1 | Car 2 | Car 3 |
#17 | |
ARRRRHARHAR
#18 | |
#19 | |
ARRRRHARHAR
#20 | |
On a mission
#21 |
![]() Join Date: Jan 2005
Nice SolidWorks model!
![]() im just learning how to use it. then ill have access to machine galore. ill post up when i need to do a project for ideas on what to design/model. this is for school out at CU Boulder where another Tbrickers is also residing! |
#22 |
On a mission
Alright, update time. Since the last update, I was preoccupied with a series of things. First, had to replace the starter in my dad's frontal-accident-victim project audi a4 (we've put no miles on the car, and the starter has gone. volkswagen!). Then we got to puttering it around, and I learned how to stall an audi a4. During this learning experience, I discovered the timing belt tensioner did not like being tight, and so it loosened it else. volkswagen!. After fixing that, I successfully learned how to drive stick (which is hilariously fun for some reason...I'm very conflicted now
However, my greatest achievement actually had to do with this thread's topic. After spending quite literally over 10 hours in front of a damn 15" monitor, I figured out how to coax solidworks into doing what I wanted it to do. But that waits till later, lets get all the little things out of the way. Firstly, cut all the straight sections, and cut 45* notches on the pipe ends for easy welding. All the pipes are now completely done, and ready to be marked, alligned, and welded. All assembled: ![]() ![]() 20 noodles and 4 straight sections. Nice shiny angle cuts on em. Now, these I got, like, a few days back, but I don't recall posting them. Laser cut from 3/8" mild steel, the manifold flange was drawn up in solidworks, converted to DWG, and sent off to own6's former machine shop guy: ![]() ![]() oo, sharp! And now, as I alluded to earlier... wait for it... waaaaait for it.... ![]() Collector's done! First time this was assembled was no less than 20 minutes ago (with quite possibly the worst choice of bonding material imagineable, masking tape). With the exception of a little extra material on the front most "point", all the ****ing vertexes line up perfectly. And the little bits of inconsistency I attribute to my use of a rather ungainly angle grinder to cut around the marking, rather than the markings themselves. Solidworks usage tip for those who give a ****-- It took ****ign forever to get working, but essentailly, each pipe is created as a sheet metal part--rolled into a pipe shape. Assembled the pipes in the main header assembly, and edited each pipe part in context--for each pipe, I started a 3d sketch, and dropped in the intersection curve from the neighboring pipes. Then I edited each part, and made 4 closed body sketches around the circumference of the pipe in the shape I needed cut out, and then made an extruded cut from that drawing surface in towards the center. Flatten the part gives a perfect "unwrapped" cutout drawing (an be sure to kill any external relations int he drawings, when you go back to the assembly, the intersection curves tend to totally get hosed!) Then I just unfolded the parts, dropped them into a drawing, printed them, wrapped em around the pipes and cut em out.Okay, chances are you've stopped halfway through that up there, but thats okay, this is the good part, ![]() ![]() /\ this is the corner that needs a little encourgement. the gap and the other misalignment is actually being cause by a little point of metal on the nearest pipe-- ill girnd that off and it should fit perfectly ![]() note how the vertices meet right up in both places ![]() (this is modern art) ![]() /\That would look better if that middle pipe wasn't hanging out in space, but eh. In conclusion, the collector turned out several times better than I expected. I was planning on making a whole hell of a lot of mistakes but it came out better than I could have ever hoped. Only thing left now is to mark all the pipes with their mating angles, and then I can start taping everything together... and then I weld it....then I figure out where Im gonna put the wastegate and shove a pipe into the collector accordingly! |
#23 |
Guest
looks awesome dude. well done.
love the HF bandsaw... how well has it held up for you? would you recommend it again? how intuitive is solidworks? I haven't used cad in about 15 years so I'd be a little rusty. more importantly... when do you start welding? Mike Last edited by 740ATL; 08-30-2005 at 06:22 AM.. Reason: can't stop looking at the collector... |
#24 | |
FWDFTW
http://www.pbase.com/765ti/image/45260821
Is that JB Weld holding your oil feed on? Im going to tell you first hand that JB weld doesnt like much heat, and DEFINITELY not any oil! Be careful!
#25 |
Guest
| Thread Tools | |
| Display Modes | |
