Old 09-16-2005, 02:58 PM   #1
harley
harley's Avatar
Default need volvo stroker motor details...
i'm considering doing a build up of a stroker motor. i've heard rumors of a 2.9L monster...i was wondering if a penta crank can be used, types of rods, sources, etc.
thanks
harley
His:
79 244DL 395K, 3.93 rear, upper chassis braces, turbo sways, lowered, B21F, P&P 405 w/B cam +4°
Hers:
91 245SE 191K, upper chassis braces, IPD sways, 8.2mm thundervolt wires, Bilstein TC's, T cam.
RIP:
83 245GLT minus T ~200K. terminal 11 (full throttle actuated), K cam +6º, 2.5" exhaust, dual turbo sways, e-fanned oil cooler, crunchified M46, spun bearings and rod knock from hell.
harley is offline   Reply With Quote
Old 09-16-2005, 03:17 PM   #2
pisco
Cruisin' in my Longboat.
pisco's Avatar
You may be referring to the B30 it is an inline 6 that came in the 164. And yes many penta parts will work, although I don't have a list. The penta versions are known as the AQ170 or AQ 165 (I believe only the carbs were different). Check your local marine suply place because ebay never seems to turn up anything worthwhile.
1973 164e M410 Pacific Blue/Maroon leather int.
1971 164
pisco is offline   Reply With Quote
Old 09-16-2005, 03:35 PM   #3
JW240
All idiot, no savant
JW240's Avatar
A B30 penta engine can be bored out to 3.6 liters, with a different crank I think.
normal B230 / B23 engines can be 2.5 with the super strong 86 mm stroke penta crank, and with bigger bore, 2.6 to 2.8 is possible but I wouldn't go over 2.6 for cylinder wall thickness. 600 hp is possible with a good built penta engine even more...
240 | 1991 | 326 KKm | B230F+T | Cossie T3 60/63 | M90 | TrueTrack
Husaberg FE450 '12
Old 09-16-2005, 03:35 PM   #4
pwschuh
Rolling...
He probably means the 4 cyl redblocks and yes, certain 4 cyl blocks can be taken over 3 liters. Tread very carefully.
"No man would listen to you talk if he didn't know it was his turn next." E. W. Howe
Old 09-16-2005, 04:20 PM   #5
harley
harley's Avatar
Default B30
so the B30 will drop into a 240? can i use fuel injection on that motor?
Old 09-16-2005, 04:39 PM   #6
grizlyadams
ni!
grizlyadams's Avatar
http://www.stenparnermotor.se/default.aspx?NodeId=90
ooo 98mm cranks, make my pissy little 2.5l penta crank look small and wimpy
Griz
I AM THE GRIZ!!! (bit like the brummy stig )
2007 V50 SE - chipped
grizlyadams is offline   Reply With Quote
Old 09-17-2005, 09:29 AM   #7
harley
harley's Avatar
now thats what i'm talking about! too bad i can't read it...i assume they're forged?
Old 09-17-2005, 10:10 AM   #8
Wagner
Tbricks MIG Welding Champion
Wagner's Avatar
It says:
Steel crank shafts of best quality.
All crank shafts have 8 counter weights to give best possible running on high RPM levels.
Cranks with 80, 86, 94,5 and 98 mm stroke are kept in stock.
price: 14800 SEK (approx. 1950 US $) including swedish tax.
Penta marine crankshaft with 86 mm stroke, 55mm main bearings: 4500 SEK.
and at the bottom some stuff about pistons.
Cops pulled me over. Papers, they said. Scissors, i replied. Still i did not win. Go figure.
Wagner is offline   Reply With Quote
Old 09-17-2005, 10:39 AM   #9
Boosted2003
Boosted2003's Avatar
with 97mm bore and 98mm stroke your looking at 2900 cc motor. Im sure u have to cut the block a bit to rotating clearance for the crank.
2006 VW Passat 2.0t 6 Speed - Current
2005 Dodge Magnum R/T - Sold
2005 Dodge Ram 2500 - Sold
1998 Dodge Ram 1500 - Sold
1990 Volvo 760 Turbo - Sold
Boosted2003 is offline   Reply With Quote
Old 09-20-2005, 05:59 AM   #10
Kevin Hawkinson
Better Red than Dead
Kevin Hawkinson's Avatar
If you sleeve the block, you can go up to about 100mm bore.
Wet sleeves involve completely cutting out the old cylinders, and pressing in new liners. Liners are about $50 each, and the machining should be about $120-200.
You can get the 86mm marine cranks here in the states in marine junkyards, although they might be a little rare.
100mm bore x 86mm stroke gets you 2.7 liters for WAY less than the cost of that 98mm crank.
-Kevvie Hoikansanalainenen
Kevin Hawkinson is offline   Reply With Quote
Old 09-11-2012, 08:49 AM   #11
Hayas
we are now 2012 year, i think they are looking much more for a length of stroke and not the bore size, am i right?
Hayas is offline   Reply With Quote
