Go Back   Turbobricks Forums > Mechanical > performance & suspension > aftermarket engine management
Old 09-17-2005, 05:14 PM   #1
str8krewzn
str8krewzn's Avatar
Question MSnS or Haltech
This has probly been talked about
but which would be best to get
for a turbo 95 b230ft in a 740?
Thanks
str8krewzn is offline   Reply With Quote
Old 09-17-2005, 05:18 PM   #2
medfurd
What for? What mods do you have, what goals do you have in mind? That said, you don't need anything more than MS, and it's the cheapest option.
medfurd is offline   Reply With Quote
Old 09-17-2005, 05:25 PM   #3
str8krewzn
str8krewzn's Avatar
Default MSnS or Haltech
Well
t3/t4
Race headers
getrag trans
Sten Parner racing head
95 b230ft BUILT
BIG injecters still choosing
Old 09-17-2005, 05:36 PM   #4
Captain Bondo
Exklusiv Zubehör Klub
Captain Bondo's Avatar
exactly.
Mods? Budget? What version of haltech? Budget? Budget? Goals? Mods?
IMO a properly set up megasquirt with edis is good for 90% of folk building 4 bangers. And I would not choose something like an E6X over megasquirt under any circumstances. The E11 gives me serious wood, but it's overkill for a 4 banger that's doing under 7000rpm and 400hp. Beyond that point things get hairy enough that more control might be worthwhile.
But if you just won the lottery and have money floating around, or you are looking specifically for something that runs as close as possible to as smoothly as OEM , or you want 400hp+ (yeah yeah I know ms will do that, but you could almost replace all your wrenches with a crescent wrench too), or all of those, then an E11 (or actually an E8 would be fine- same feature as e11 but less fuel and spark outputs so it's cheaper) would be great.
But figure on 200-400 for megasquirt depending on what you do, plus 100-200 for tuning.
figure 1300-1800 for haltech plus 200-300 for tuning. So it's a big jump.
-Kenny
Old 09-17-2005, 05:41 PM   #5
PetesDustyVolvo
one car, two bicycles
PetesDustyVolvo's Avatar
*snip* sorry, i guess my 2 cents are off topic but nothing can be done about that now
oh yes there's something that can be done...
Last edited by Captain Bondo; 09-17-2005 at 05:56 PM.. Reason: way ot- send him a pm if need be
PetesDustyVolvo is offline   Reply With Quote
Old 09-17-2005, 06:07 PM   #6
2muchboost4u
Guest
i am running haltech. it is easy to tune, very visual. i know alot of people that have megasquirt but have some problems with tuning it because they dont know how to, even with a wideband, i guess the program is hard to get used to or something. but im sure with some time it would be easy to learn the program. in my opinion, i think that the haltech is worth the extra money... both are great, just like the haltech more, just my 2 cents.
Old 09-19-2005, 10:31 PM   #7
"YOU'RE" is a word.
Why would you chose MS over Haltech E6X?
I plan buying standalone eventually and am really considering Haltech. Seems a lot easier to tune than MS.
1975 244-Turbo. 2550lbs. Ethanol
1990 245-28mpg M47 DD
Old 09-19-2005, 10:37 PM   #8
ashvolvo
2 > 7
ashvolvo's Avatar
I'm also seriously considering the haltech route.
Did you do your own install?
DVS Performance Parts - http://www.dvs.net.au
Find us on Facebook -
http://www.facebook.com/DvsPerformanceParts
1990 240
2004 Holden Commodore wagon
ashvolvo is offline   Reply With Quote
Old 09-19-2005, 10:39 PM   #9
Forg
Forg's Avatar
Kinda depends on where you are as well; and how much it costs to get hold of parts.
You need to work out everything that you need to get your hands on when doing an ECU conversion, and then decide. I started from a point where I had nothing at all apart from a K-Jet harness; if I'd have gone MS instead of MoTeC I would've saved myself about AU$400 (out of a total of probably AU$10k for the entire engine+electronics). For a difference of AU$400, the known brand, without my own bodgy "electronics welding", was definitely a better choice.
Forg is offline   Reply With Quote
Old 09-19-2005, 10:39 PM   #10
medfurd
How does it "seem" like that? Tuning is easy, it's the software/firmware compatibility issues that will drive you insane if you accidentally get mixed up.
Old 09-19-2005, 10:40 PM   #11
Captain Bondo
New the E8 is only a few hundred dollars more than an E6X, and it a way better system. I just think someone considering and E6X might be better off shelling out a tiny bit more for an E8
HOWEVER, don't get me wrong, the E6X is still a nicer system, I'm just not certain it's *enough* nicer for the price. Although you can get used ones for about 500-600 bucks these days, so if you could get a used one actually, go for it. But MSnEDIS with the 12x12 maps would be really close to as good, and cheaper. At that stage the Haltech's major advantage would be the interface.
So, to be more accurate, a used E6x would be great, but in terms of buying new the E8 is a little more buck and a lot more bang, and the MS is a little less bang and a lot less buck. If that makes sense.
Edit: To anyone questioning Haltech being easier to tune. Do this:
Download megatune.
Download halwin from the Haltech website.
Just spend 20 minutes browsing through the menus and etc for each. It is night and day.
Haltech's software setup is killer.
Old 09-19-2005, 11:32 PM   #12
linuxman51
ARRRRHARHAR
linuxman51's Avatar
I would hope haltech's software would be, but then they'dve had to have come a long way since the version I saw, it was horribe (dos based baby, gimmie some more o dat).
works great on my car (obviously), and tuning certain things can be tedious, but I suspect its the same way with all ems's (certain aspects of warmup, etc).
a lot of people dont bother to really really fine tune things, esp if a problem only manifests itself once in a while, so thats something to consider as well.. I've gotten picky lately so ive been spending more time on the mundane details involved in perfect warmup driving than anything else.
oh and 300 miles on 12 gallons with a 300hp volvo doesnt hurt either.
Megasquirt Tuning!
ported volvo heads
Old 09-19-2005, 11:46 PM   #13
socalsean
back in the game
socalsean's Avatar
care to explain how you would have only saved 400AU?
sean
socalsean is offline   Reply With Quote
Old 09-20-2005, 10:25 AM   #14
Morley
Barbie Ken
Morley's Avatar
See sig.
12x12 maps? I'm almost laughing...My 12 year old plain E6 has 20x32...
Morley is offline   Reply With Quote
Old 09-20-2005, 01:06 PM   #15
benflynn
bigpimpin740t@yahoo.com
benflynn's Avatar
go ahead and laugh...it still works great and cost less than tuition...is your old system still under devlopment?ask this same question in a year and i bet we will have more converts
think you got shorted? belive me, we have piles of turbos and ms units, email me w/what ever the hell you think we have of yours and when i am not on a river ill dig it out and send it to ya for shipping, one shotbigpimpin740t@yahoo.com
one down, whose next?
benflynn is offline   Reply With Quote
Old 09-20-2005, 03:54 PM   #16
"YOU'RE" is a word.
The thing I dont like about MS is that you gotta do odd things like add inline resitors, solder, and things like that.
With something like haltech you can just get the proper sensors and wire em in. No resistors in the signal wires or anything like that. It also says the software uses bar graphs that you just click and drag to manipulate. No numerical input.
Another reason it would be beneficial to go with Haltech is you can take it to almost any dyno tuner and they will know what to do. If you go MS, certain dyno tuners probably wont even touch your car.
Old 09-20-2005, 04:38 PM   #17
Morley
Barbie Ken
Morley's Avatar
OMG you guys really don't like critic do you? Get down to earth for fcks sake, I'm not saying Haltech is the only solution, but neither is MS. On a cost vs. options rate, a used Haltech wins.
Apples to oranges.
Old 09-20-2005, 06:04 PM   #18
linuxman51
ARRRRHARHAR
linuxman51's Avatar
I'm not so sure I would count on that, a lot of them require special sensors that you get to fabricate to get to work, be it a trigger wheel or something else along those lines.
And there's nothing odd about an external signal modifier, in all your playing around with lh I'm fairly supprised you havent messed with them
So shift up and shift down is too difficult? maybe you should be working a french fry machine somewhere instead....
Old 09-20-2005, 06:06 PM   #19
linuxman51
ARRRRHARHAR
linuxman51's Avatar
Apples to oranges.
not really, $200 for a used megasquirt vs $5-600 for an old haltech? go check the current list of features against each other..
you are right about apples to oranges....
Old 09-20-2005, 06:19 PM   #20
Captain Bondo
"I'm not so sure I would count on that, a lot of them require special sensors that you get to fabricate to get to work, be it a trigger wheel or something else along those lines."
Haltech actually has the best factory sensor support out there right now. Works directly with motronic 60-2 and cam sync and a ton of other configs. All of the signal conditioners and etc for vr and everything are built in. You tell it what wheel and what sensor, and it does it. The kit comes with AIT and ECT sensors and calibration maps that are factory calibrated. Compensation for AIT heat soak and 3d load/temp/enrichment, better software, better closed loop, more cels with adjustable load points. Dual maps so you can have one for 92 octane and one for 116? And you can switch maps with a toggle switch? Interpolation is great, but 12x12 fixed vs 20x32 variable is no comparison. On and on and on.
For an extra 300 bucks? I'd take it.
MS is great, and a system is only as good as the tuning, so for someone with a pretty stockish drivetrain that wants something that can set up to be decent with the flexibilty of being adjustable, MS it the sh*t. Not trying to flame on MS at all, but I remember any decent mainstream ems was 2 grand when evenryone started doing MS, so it was the greatest thing. But in the few years that we have all had our eyes fixed pretty squarely on MS, the mainstream technology has evolved and gotten more affordable, as it always does.
MS will also continue to evolve, we're just at a point in time where it is a tiny bit behind imo. It's still a great basic system for a lot of people.
Old 09-20-2005, 07:24 PM   #21
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
Man I must be out of date because I thought MS was painfully SIMPLE. I suck at computers to boot.
The software Im using on my T5R is much more complicated.
History: Car 1 | Car 2 | Car 3
Old 09-20-2005, 07:28 PM   #22
Hank Scorpio
btw str8kruzin you have pictures of anything or are we going to just keep feeding the bench racing fire for the next 20 years?
Old 09-20-2005, 08:57 PM   #23
Captain Bondo
MS is definitely very simple, and Haltech is definitely more complex, and ease of use can be somewhat subjective, but the Haltech interface is one of the cleanest imo.
Old 09-20-2005, 11:29 PM   #24
str8krewzn
str8krewzn's Avatar
Question Pixz?
I asked witch EMS to use
you wanna see pixz of me thinkin which to get
Old 09-20-2005, 11:38 PM   #25
Captain Bondo
Thumbs up
OK that was funny. This mental image of a regular dude with this little smiley-head, squinting at a computer monitor. :thumbsup:
