#1 | |
No braptraps here.
OK, so before you all tell me to search, I already have, and while there's a lot of info about doing a +T on a B230F, there's not much to be said about going +T on a B23E.
I plan to use MS or some kind of EMS, etc. so that's not a problem. Anyway, I just bought a 1982 244 with a B23E and only 63,000 miles on it. I did a compression test today and all cylinders show between 160 and 162 psi. Compression ratio is 10.0:1 and I am at 3300 ft above sea level if that makes a difference. Does that sound like a healthy engine? So, I am wondering if it would be a good idea to +T this engine. As it has barely any miles on it, I don't want to rebuild it if I can help it. How much boost could I run safely on stock internals? I am considering the use of water/alcohol injection as well, seems like a good idea. How much extra boost could I run with this installed? Thanks
![]() ![]() ![]() ![]() ![]() http://zyrex.org/gallery/Cars/DauntsVolvo/ http://www.youtube.com/user/Dauntless244 Quote:
#2 | |
Gavri'el
It's not uberdifficult or uberexpensive to get hold of a 740T intercooler & fit it to a +T'd B23E ... that'd give you a handfull of extra PSI. You'd definitely have to be a bit careful, it doesn't seem abnormal for stock B23E's to want to ping even on LRP.
#4 |
Drunk as ****
I think that has alot to do with the 017 distributor which is quite aggressive down low. I can run regular gas with the B21FT dizzy at 12 degrees advance, but not with the B23E (017) dizzy at the stock 5 degrees advance.
As with any motor, but especially one with a high CR like the B23E, spark control will be a big part of the puzzle when looking at boost levels, H20/alky injection and octane requirements among other variables... Oh, and that motor is barely broken in, I wouldn't even bother pulling the head!
1995 945Ti, cushy winter ride aka Darth Wagon 2006 Suzuki GSF650 Bandit |
#5 |
No braptraps here.
Yeah that's what I was thinking. I am wondering what boost figure I could aim for, to see if it's even a good idea to try to +T it.... what's the most anyone has safely ran through a B23F+T in a daily driver?
#6 |
When I did mine, my father and I just kinda set the wastegate to whatever and viola, 10psi. Now my boost guage runs off the IC and that's after running through an IC from a 1985 760, so the actual PSI the turbo is pushing might be higher.
I also decided to f*** with my daily driver, which isn't smart if you want to get into a +T then screw around with MS, it can be a pain if it wants to be. A long story turned short is that I did my +T around x-mas/the first of this year, and drove it a bit then finally did MS in April. Beyond that I was having huge TPS issues that thus resulted in unreliable drivability for a long time. Turns out I had two signals and one ground going to the thing, and not 5v-signal-ground. Dumbass me. Last night the car ran SUPERB with a bit of tweaking in a couple areas and this morning it ran great as well. Err anyways... back to topic a bit, depending on how brave you are is what you start at with boost have fun though, all in all it's been a heck of a ride. And last time I dyno'd I had almost 80rwhp and 100rwtq gain from stock! I'm sure I'll be at 200 when I'm done. |
#7 |
No braptraps here.
OK, thanks a lot for that info mate
I plan to do it the right way the first time. I have 2 cars to drive until half way through next year, so that helps too |
#8 |
Drunk as ****
Dauntless, the point I was trying to make, is that it all depends on how far you want to go. You could shoot for 20psi. With really well tuned EMS, alcohol injection, big turbo, etc, it would be possible. Of course at that point, you'd need a new tranny, but you get the idea. The other trade-off is without any knock sensing or other safe-guards, the motor would be extremely sensitive to any detonation.
With some form of EMS (including spark control!), lots of patience tuning, a stock T3 and intercooler, I would *guess* you could safely run upwards of ~10psi on pump gas. There are too many variables to say for sure, alot of them related to what lengths you're prepared to go to get there. Even at 10psi, you could be pushing the limits of your transmission anyway.... |
#9 |
No braptraps here.
Trans is no problem, I have a Getrag M51 sitting here
![]() And to help things along I was thinking of using EMS, a 60/63 turbo, a decent intercooler, and water/alcohol injection. Does 12 psi sound reasonable with that? Last edited by Dauntless; 09-21-2005 at 07:53 PM.. |
#10 |
Gut-feel says you'll be borderline, but it should be possible. Current factory cars running 15psi+ are up close to 10:1, they've got better combustion-chambers & knock-control, but they're also not running water injection.
Dunno ... I'd probably make sure the timing's very conservative. Maybe have a look at DIY knock-sensor stuff, so you have instant notification if it does knock. B23E's are cheap, and a DIY engine-swap isn't terribly nasty, maybe try it with an older engine first? [Don't think I'd do that, but then I don't know if I'd try 12psi on a 70's 10:1 CR engine either *edit* Oh, BTW; where's the 60/63 turbo coming from? Is it a cheapie? Remember that we don't necessarily have the same cheapness of parts here as in North America where most contributors around here come from ... you might find a better alternative for the same price in Oz (&/or from Japan). Last edited by Forg; 09-21-2005 at 11:58 PM.. |
#11 | |
No braptraps here.
#12 |
update anyone? i wanna do this too an im wondering how much it set you back.
#13 |
as far as i know dauntless's project has been shelved indefinately and didnt get off the ground. so no luck with an update.
![]() 244GLE Project - The fun daily driver. Rebuilt B23, ported 405, 37.5 exh. valves, BMW oil squirter's, MS2e, VX3 cam, King Springs, Bilstein HD's, upper+lower chassis braces, 26mm Falcon front sway bar, 21+19=24mm rear sway bar, SAAS bucket seats, hi flow rear muffler, almost every factory option. 164 Project - The impulse buy 242GT Project - who likes rust? |
#14 |
No braptraps here.
I've decided not to +T my car.
#15 |
Good choice.
Polaris: Air Jordans for your car |
| Thread Tools | |
| Display Modes | |
